Stary 20.04.2011, 14:07   #1
Kowa1
Avatar użytkownika Kowa1
Data rejestracji: 25.08.2010
Kowa1 jest tu z lekka niepopularny <-31- -50 pkt>
Problem kodowania
Witam!
Mam problem z kodowaniem do takiego formatu
General
Complete name : D:\TestersCatalogue\Film-0001.mp4
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 372 KiB
Duration : 21s 600ms
Overall bit rate : 141 Kbps
Encoded date : UTC 2003-11-07 00:00:00
Tagged date : UTC 2003-11-07 00:00:00
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 21s 400ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Width : 176 pixels
Height : 144 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 13.832 fps
Minimum frame rate : 7.463 fps
Maximum frame rate : 15.152 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.365
Stream size : 334 KiB (90%)
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Bit rate mode : Variable
Bit rate : 12.7 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 33.5 KiB (9%)
Writing library : Philips
znajduje w necie bardzo podobne
Video #1
Format settings, BVOP : No
Codec ID : 20
Duration : 1h 27mn
Bit rate : 599 Kbps
Width : 320 pixels
Height : 240 pixels
Frame rate mode : Constant
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.312
Stream size : 375 MiB (92%)
Writing library : Lavc51.10.0
Encoded date : UTC 1970-01-01 00:00:00
Tagged date : UTC 1970-01-01 00:00:00
Audio #2
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 27mn
Bit rate : 48.0 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 32.0 KHz
Resolution : 16 bits
Stream size : 30.1 MiB (7%)
czym rzesz u kaduka to się robi ?
Jakim narzędziem ?
A ponieważ nie jestem orłem w tej dziedzinie, zapytam jeszcze jak ?
Może mam to narzędzie, a mam kilka, i po prostu brak mi wiedzy lub jakiś kodeków. Chociaż sądzę że jak mam ffdshow_beta7_rev3154_20091209 to już raczej nic mi nie powinno, w obszarze kodeków, brakować.
Kowa1 jest offline   Odpowiedz cytując ten post
problem z odczytem tomaszekkkk Napędy optyczne DVD 9 30.07.2008 16:33
Rozwiązany Problem bluetooth HP nx6125 aeiouy Off topic 0 26.05.2006 15:35
problem z zamykaniem plyt krzy4 Napędy optyczne CD 12 07.03.2005 20:07
Problem z nagrywarką. rafkup Napędy optyczne CD 13 07.12.2003 15:36
dziwny problem z nagrywaniem... he-man Napędy optyczne CD 7 09.06.2002 23:29
Wszystkie czasy w strefie CET. Aktualna godzina: 23:33.
