Data rejestracji: 17.06.2004
wklejam loga może ktoś mi pomoże
Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 20:18:06 Wersja Nero: 6.3.1.15 Nagrywarka: <HL-DT-ST RW/DVD GCC-4521B>Wersja: 1.01 - HA 1 TA 0 - 6.3.1.15 Sterownik adaptera: <> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <HL-DT-ST RW/DVD GCC-4521B>Wersja: 1.01 - HA 1 TA 0 - 6.3.1.15 Sterownik adaptera: <> HA 1 === Scsi-Device-Map === DiskPeripheral : QUANTUM FIREBALLP AS30.0 nvatabus Port 0 ID 0 DMA: Off CdRomPeripheral : HL-DT-ST RW/DVD GCC-4521B nvatabus Port 0 ID 0 DMA: Off === CDRom-Device-Map === HL-DT-ST RW/DVD GCC-4521 E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523764kB) Free physical memory: 293MB (300312kB) Memory in use : 42 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 18.6.2004 CD-ROM (ISO) 16:35:10 #1 Text 0 File Isodoc.cpp, Line 6065 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : TAO Mode : 1 ISO Level : 2 (Max. of 31 chars) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 16:35:11 #2 Phase 90 File dlgbrnst.cpp, Line 1845 Włączono system ochrony zapisu 16:35:11 #3 Text 0 File Reader.cpp, Line 118 Reader running 16:35:11 #4 Text 0 File Writer.cpp, Line 124 Writer HL-DT-ST RW/DVD GCC-4521B running 16:35:11 #5 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 16:35:11 #6 Text 0 File Burncd.cpp, Line 3167 Turn on Track-At-Once, using CD-R/RW media 16:35:11 #7 Text 0 File DlgWaitCD.cpp, Line 245 Last possible write address on media: 359846 ( 79:59.71) Last address to be written: 1372 ( 0:20.22) 16:35:11 #8 Text 0 File DlgWaitCD.cpp, Line 257 Write in overburning mode: NO (enabled: CD) 16:35:11 #9 Text 0 File DlgWaitCD.cpp, Line 2137 Recorder: HL-DT-ST RW/DVD GCC-4521B; CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited ATIP Data: Special Info [hex] 1: C0 00 98, 2: 61 18 01 (LI 97:24.01), 3: 4F 3B 48 (LO 79:59.72) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid) 16:35:11 #10 Text 0 File DlgWaitCD.cpp, Line 418 >>> Protocol of DlgWaitCD activities: <<< ========================================= 16:35:11 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 1373 (1373) = #1373/0:18.23 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1371 blocks [HL-DT-ST RW/DVD GCC-4521B] -------------------------------------------------------------- 16:35:11 #12 Text 0 File ThreadedTransferInterface.cpp, Line 983 Prepare recorder [HL-DT-ST RW/DVD GCC-4521B] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 3119104, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 1373 | lead-out | 1 | 0x00 | 0x41 16:35:11 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1029 Removed 2 run-out blocks from end of track 1. Length: 1373 -> 1371. 16:35:11 #14 Phase 24 File dlgbrnst.cpp, Line 1845 Rozpoczęto buforowanie plików 16:35:11 #15 Text 0 File Burncd.cpp, Line 4177 Cache writing successful. 16:35:11 #16 Phase 25 File dlgbrnst.cpp, Line 1845 Zakończono buforowanie plików 16:35:11 #17 Phase 36 File dlgbrnst.cpp, Line 1845 Rozpoczęto zapis z prędkością 16x (2*400 KB/s) 16:35:11 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2343 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 16:35:11 #19 Text 0 File Mmc.cpp, Line 20239 Set BUFE: supported -> ON 16:35:22 #20 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 16:35:24 #21 Text 0 File Mmc.cpp, Line 15064 <HL-DT-STRW/DVD GCC-4521B> start Close Session 16:37:05 #22 SCSI -1176 File Cdrdrv.cpp, Line 1188 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x72 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x02 16:37:05 #23 CDR -1176 File ThreadedTransferInterface.cpp, Line 1182 Błąd fiksacji sesji! 16:37:05 #24 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1182 Wykonanie polecenia Fiksacja nie jest możliwe! 16:37:05 #25 Text 0 File Mmc.cpp, Line 15064 <HL-DT-STRW/DVD GCC-4521B> start Close Session 16:38:26 #26 SCSI -1176 File Cdrdrv.cpp, Line 1188 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x72 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x02 16:38:26 #27 CDR -1176 File ThreadedTransferInterface.cpp, Line 1182 Błąd fiksacji sesji! 16:38:26 #28 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1182 Wykonanie polecenia Fiksacja nie jest możliwe! 16:38:26 #29 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:00,000 (0ms) -> OK 16:38:26 #30 Phase 38 File dlgbrnst.cpp, Line 1845 Zapis z prędkością 16x (2*400 KB/s) nie powiódł się! Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 12:02:00 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
