Data rejestracji: 12.03.2004
Problem z teacem :(
Jesli ktos wiec niech mi pomoze. Podaje log:
Tu byly dane personalne/Zbieg12 Windows 2000 5.0 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06 Nero version: 6.3.0.2 Recorder: <TEAC DW-224E> Version: 1.0A - HA 1 TA 0 - 6.3.0.2 Adapter driver: <atapi> HA 1 Drive buffer : 1658kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <TEAC DW-224E >Version: 1.0A - HA 1 TA 0 - 6.3.0.2 Adapter driver: <atapi> HA 1 === Scsi-Device-Map === DiskPeripheral : IC25N040ATCS04-0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TEAC DW-224E atapi Port 1 ID 0 DMA: Off CdRomPeripheral : Generic STEALTH DVD st3wolf Port 2 ID 0 DMA: Off === CDRom-Device-Map === TEAC DW-224E E: CDRom0 Generic STEALTH DVD F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 32505856 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 189MB (194032kB) Free physical memory: 36MB (36916kB) Memory in use : 80 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 12.3.2004 CD-ROM (ISO) 23:21:55 #1 Text 0 File Isodoc.cpp, Line 6029 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 23:21:55 #2 Phase 75 File dlgbrnst.cpp, Line 1800 JustLink activated 23:21:55 #3 Text 0 File Reader.cpp, Line 118 Reader running 23:21:55 #4 Text 0 File Writer.cpp, Line 124 Writer TEAC DW-224E running 23:21:55 #5 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) 23:21:56 #6 Text 0 File Burncd.cpp, Line 3101 Turn on Track-at-once, using CD-R/RW media 23:21:59 #7 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 348911 ( 77:34.11) 23:21:59 #8 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 23:21:59 #9 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: TEAC DW-224E; CDR code: 00 97 24 11; OSJ entry from: SONY Corporation ATIP Data: Special Info [hex] 1: D0 40 98, 2: 61 18 0B (LI 97:24.11), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 23:21:59 #10 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert the disc to write to. (Medium in drive: CD-R. Medium required by compilation: CD-R/RW.) 23:21:59 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 348912 (348912) = #348912/77:32.12 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 348910 blocks [TEAC DW-224E ] -------------------------------------------------------------- 23:21:59 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [TEAC DW-224E ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 714878976, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 348912 | lead-out | 1 | 0x00 | 0x41 23:21:59 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994 Removed 2 run-out blocks from end of track 1. Length: 348912 -> 348910. 23:22:00 #14 Phase 24 File dlgbrnst.cpp, Line 1800 Caching of files started 23:22:00 #15 Text 0 File Burncd.cpp, Line 4073 Cache writing successful. 23:22:00 #16 Phase 25 File dlgbrnst.cpp, Line 1800 Caching of files completed 23:22:00 #17 Phase 36 File dlgbrnst.cpp, Line 1800 Burn process started at 4x (600 KB/s) 23:22:00 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 23:22:00 #19 Text 0 File Mmc.cpp, Line 19451 Set BUFE: JustLink -> ON 23:22:23 #20 SCSI -1106 File Cdrdrv.cpp, Line 1431 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x06F70000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 23:22:23 #21 CDR -1106 File Writer.cpp, Line 301 Power calibration error 23:22:23 #22 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 23:22:23 #23 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 23:22:23 #24 CDR -201 File WriterStatus.cpp, Line 196 Invalid write state TEAC DW-224E\H1 T0 23:22:23 #25 TRANSFER -18 File WriterStatus.cpp, Line 196 Could not perform EndTrack 23:22:24 #26 Text 0 File Mmc.cpp, Line 14287 <TEAC DW-224E > start Close Session 23:22:24 #27 SCSI -1176 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x04 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x04 23:22:24 #28 CDR -1176 File WriterStatus.cpp, Line 245 Session fixation error 23:22:24 #29 TRANSFER -19 File WriterStatus.cpp, Line 245 Could not perform Fixation 23:22:24 #30 Text 0 File WriterStatus.cpp, Line 254 falling back to disc fixation 23:22:24 #31 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 23:22:24 #32 Phase 38 File dlgbrnst.cpp, Line 1800 Burn process failed at 4x (600 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 11:02:00 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.00.2195.5376, size=86704 bytes, created 2000-08-08 08:08:00 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Po prostu nie wiem co robic, nagrywalem na kilku plytach, pliki po 1mg nawet na predkosci 4x i nic, zawsze ten sam problem. Otoz ta nagrywarka jest w laptopie, kiedys mi dzialala, ale cos sie skopalo . Prosze o pomoc. |
