Stary 14.01.2017, 05:29   #1
GoldStar\LG CED-8080B 2001r
"Ósemka " LG jeszcze sygnowany logiem GoldStar.....
Napęd jeszcze bardzo skomplikowany technicznie i technologicznie.....Aktualizacja firmware jedynie możliwa pod DOS ...
Hardware = chipsety OAK OTI 9790 +Sony CXA255AR + Hitachi HB\3062 + OPU Sony KRS-202A
Specjalne podziękowania dla Adama z Gdyni za ten "skarb"...
Stary 14.01.2017, 05:33   #2
GoldStar\LG CED-8080B fw.1.06
Nero 2016 x8
log:
Kod:
Windows 8 6.2
IA32
Nero Version: 17.0.5.0
Internal Version: 17,0,5,0
Recorder         : <GoldStar CD-RW CED-8080B>     FW version: 1.06 - HA 1 TA 1 - 17.0.5.0
 Device bus      :  <>                            HA 1
 Host system bus :  <IDE>
 Drive buffer    :  2048kB
 Bus Type        :  via Inquiry data
CD/DVD-ROM       : <BENQ     DVD DD DW1640   >    FW version: BSRB - HA 1 TA 0 - 17.0.5.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
BENQ DVD DD DW1640         G:   CdRom0
GoldStar CD-RW CED-8080B   H:   CdRom1
ATAPI iHAS224   A          N:   CdRom2
PLEXTOR DVDR   PX-890SA    M:   CdRom3
AutoRun : 0
Excluded drive IDs:
BUFE           : 0
Physical memory     : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use       : 25 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
13.1.2017
Audio CD
06:57:49	#1 Text 0 File SCSIPTICommands.cpp, Line 617
06:57:49	#2 CDADOC -1 File Cdadoc.cpp, Line 1762
	Audio item log info:
	Audio document burn settings:
	Burn mode: DAO,
	CD Text: On,
	Cache disk or network files: No,
	Cache small files: No,
	Cache files smaller than 65536 bytes.
	Audio Multisession: No
	List of audio tracks:
	Track 01: Length: 04:26.63, Pause frames: 150, Filters: 1, Name: '01.Kombi - Na drobre dni.flac'.
	Track 02: Length: 04:11.45, Pause frames: 150, Filters: 1, Name: '02.Kombi - Sen za snem.flac'.
	Track 03: Length: 04:18.29, Pause frames: 150, Filters: 1, Name: '03.Kombi - Niech moc połączy.flac'.
	Track 04: Length: 04:43.35, Pause frames: 150, Filters: 1, Name: '04.Kombi - Nowy rozdział.flac'.
	Track 05: Length: 04:50.32, Pause frames: 150, Filters: 1, Name: '05.Kombi - Miłością zmieniaj świat.flac'.
	Track 06: Length: 04:11.38, Pause frames: 150, Filters: 1, Name: '06.Kombi - Siedem piekieł.flac'.
	Track 07: Length: 04:21.48, Pause frames: 150, Filters: 1, Name: '07.Kombi - Niedopowiedzenia.flac'.
	Track 08: Length: 04:41.38, Pause frames: 150, Filters: 1, Name: '08.Kombi - Gwinea.flac'.
	Track 09: Length: 04:06.16, Pause frames: 150, Filters: 1, Name: '09.Kombi - Jaki jest wolności smak.flac'.
	Track 10: Length: 04:09.21, Pause frames: 150, Filters: 1, Name: '10.Kombi - Słoneczny dzień.flac'.
	Track 11: Length: 05:41.45, Pause frames: 150, Filters: 1, Name: '11.Kombi - bonus- Słodkiego miłego życia (live).flac'.
	Track 12: Length: 04:06.36, Pause frames: 150, Filters: 1, Name: '11 - The Sound Of Silence.mp3'.
	Total size: 54:12.71
06:57:50	#3 Text 0 File AudioCompilationImpl.cpp, Line 838
	DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
	DRM: Beginning burn process.
06:57:50	#4 PHASE 214 File dlgbrnst.cpp, Line 2095
	Generation of disc structures started
06:57:50	#5 PHASE 215 File dlgbrnst.cpp, Line 2095
	Generation of disc structures completed
06:57:50	#6 Text 0 File Burncd.cpp, Line 4086
	Turn on Disc-At-Once, using CD-R/RW media
06:57:50	#7 Text 0 File DlgWaitCD.cpp, Line 335
	[H: CD-RW CED-8080B ] Last possible write address on media:   359843
	Last address to be written:             243820
06:57:50	#8 Text 0 File DlgWaitCD.cpp, Line 347
	[H: CD-RW CED-8080B ] Write in overburning mode: NO (enabled: CD)
06:57:50	#9 Text 0 File DlgWaitCD.cpp, Line 3127
	Recorder: GoldStar CD-RW CED-8080B;
	   CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
	   ATIP Data:
	     Special    Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
	     Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
06:57:50	#10 Text 0 File DlgWaitCD.cpp, Line 537
	[H: CD-RW CED-8080B ] >>> Protocol of DlgWaitCD activities: <<<
06:57:50	#11 Text 0 File ThreadedTransferInterface.cpp, Line 879
	 0: TRM_AUDIO_NOPRE (01.Kombi - Na drobre dni.flac)
	    original disc pos #0 + 20013 (20013) = #20013/4:26.63
	    relocatable, disc pos for caching/writing not required/not required
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20013 blocks [H: GoldStar CD-RW CED-8080B]
	 1: TRM_AUDIO_NOPRE (02.Kombi - Sen za snem.flac)
	    original disc pos #0 + 18870 (18870) = #18870/4:11.45
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18870 blocks [H: GoldStar CD-RW CED-8080B]
	 2: TRM_AUDIO_NOPRE (03.Kombi - Niech moc połączy.flac)
	    original disc pos #0 + 19379 (19379) = #19379/4:18.29
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19379 blocks [H: GoldStar CD-RW CED-8080B]
	 3: TRM_AUDIO_NOPRE (04.Kombi - Nowy rozdział.flac)
	    original disc pos #0 + 21260 (21260) = #21260/4:43.35
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21260 blocks [H: GoldStar CD-RW CED-8080B]
	 4: TRM_AUDIO_NOPRE (05.Kombi - Miłością zmieniaj świat.flac)
	    original disc pos #0 + 21782 (21782) = #21782/4:50.32
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21782 blocks [H: GoldStar CD-RW CED-8080B]
	 5: TRM_AUDIO_NOPRE (06.Kombi - Siedem piekieł.flac)
	    original disc pos #0 + 18863 (18863) = #18863/4:11.38
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18863 blocks [H: GoldStar CD-RW CED-8080B]
	 6: TRM_AUDIO_NOPRE (07.Kombi - Niedopowiedzenia.flac)
	    original disc pos #0 + 19623 (19623) = #19623/4:21.48
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19623 blocks [H: GoldStar CD-RW CED-8080B]
	 7: TRM_AUDIO_NOPRE (08.Kombi - Gwinea.flac)
	    original disc pos #0 + 21113 (21113) = #21113/4:41.38
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21113 blocks [H: GoldStar CD-RW CED-8080B]
	 8: TRM_AUDIO_NOPRE (09.Kombi - Jaki jest wolności smak.flac)
	    original disc pos #0 + 18466 (18466) = #18466/4:6.16
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18466 blocks [H: GoldStar CD-RW CED-8080B]
	 9: TRM_AUDIO_NOPRE (10.Kombi - Słoneczny dzień.flac)
	    original disc pos #0 + 18696 (18696) = #18696/4:9.21
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18696 blocks [H: GoldStar CD-RW CED-8080B]
	10: TRM_AUDIO_NOPRE (11.Kombi - bonus- Słodkiego miłego życia (live).flac)
	    original disc pos #0 + 25620 (25620) = #25620/5:41.45
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25620 blocks [H: GoldStar CD-RW CED-8080B]
	11: TRM_AUDIO_NOPRE (11 - The Sound Of Silence.mp3)
	    original disc pos #0 + 18486 (18486) = #18486/4:6.36
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18486 blocks [H: GoldStar CD-RW CED-8080B]
06:57:50	#12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
	Prepare [H: GoldStar CD-RW CED-8080B] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: "             "
	 Tracks 1 to 12:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800      47423376, ISRC ""
	   2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      47423376      47776176      92158416, ISRC ""
	   3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      92158416      92511216     138090624, ISRC ""
	   4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     138090624     138443424     188446944, ISRC ""
	   5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     188446944     188799744     240031008, ISRC ""
	   6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     240031008     240383808     284749584, ISRC ""
	   7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     284749584     285102384     331255680, ISRC ""
	   8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     331255680     331608480     381266256, ISRC ""
	   9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     381266256     381619056     425051088, ISRC ""
	  10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     425051088     425403888     469376880, ISRC ""
	  11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     469376880     469729680     529987920, ISRC ""
	  12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     529987920     530340720     573819792, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	     -150 |  lead-in |   0 |    0x01 |        0 |        0 | 0x00
	     -150 |        1 |   0 |    0x21 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x21 |    20013 |        0 | 0x00
	    20013 |        2 |   0 |    0x21 |        0 |        0 | 0x00
	    20163 |        2 |   1 |    0x21 |    18870 |    20163 | 0x00
	    39033 |        3 |   0 |    0x21 |        0 |        0 | 0x00
	    39183 |        3 |   1 |    0x21 |    19379 |    39183 | 0x00
	    58562 |        4 |   0 |    0x21 |        0 |        0 | 0x00
	    58712 |        4 |   1 |    0x21 |    21260 |    58712 | 0x00
	    79972 |        5 |   0 |    0x21 |        0 |        0 | 0x00
	    80122 |        5 |   1 |    0x21 |    21782 |    80122 | 0x00
	   101904 |        6 |   0 |    0x21 |        0 |        0 | 0x00
	   102054 |        6 |   1 |    0x21 |    18863 |   102054 | 0x00
	   120917 |        7 |   0 |    0x21 |        0 |        0 | 0x00
	   121067 |        7 |   1 |    0x21 |    19623 |   121067 | 0x00
	   140690 |        8 |   0 |    0x21 |        0 |        0 | 0x00
	   140840 |        8 |   1 |    0x21 |    21113 |   140840 | 0x00
	   161953 |        9 |   0 |    0x21 |        0 |        0 | 0x00
	   162103 |        9 |   1 |    0x21 |    18466 |   162103 | 0x00
	   180569 |       10 |   0 |    0x21 |        0 |        0 | 0x00
	   180719 |       10 |   1 |    0x21 |    18696 |   180719 | 0x00
	   199415 |       11 |   0 |    0x21 |        0 |        0 | 0x00
	   199565 |       11 |   1 |    0x21 |    25620 |   199565 | 0x00
	   225185 |       12 |   0 |    0x21 |        0 |        0 | 0x00
	   225335 |       12 |   1 |    0x21 |    18486 |   225335 | 0x00
	   243821 | lead-out |   1 |    0x01 |        0 |        0 | 0x00
	MediaType: CD-R
06:58:27	#13 Text 0 File SCSIPTICommands.cpp, Line 404
06:58:27	#14 Text 0 File Burncd.cpp, Line 4984
	Caching options: cache CDRom or Network-No, small files-No (<64KB)
06:58:27	#15 PHASE 36 File dlgbrnst.cpp, Line 2095
	Burn process started at 8x (1*200 KB/s)
06:58:27	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
06:58:27	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #20163
06:58:27	#18 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #39183
06:58:27	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #58712
06:58:27	#20 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #80122
06:58:27	#21 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #102054
06:58:27	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #121067
06:58:27	#23 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #140840
06:58:27	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #162103
06:58:27	#25 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #180719
06:58:27	#26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #199565
06:58:27	#27 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #225335
06:58:27	#28 Text 0 File Mmc.cpp, Line 17653
	StartDAO : CD-Text - On
06:58:27	#29 Text 0 File Mmc.cpp, Line 17883
	CueData, Len=208
	21 00 00 41 00 00 00 00
	21 01 00 00 00 00 00 00
	21 01 01 00 00 00 02 00
	21 02 00 00 00 04 1c 3f
	21 02 01 00 00 04 1e 3f
	21 03 00 00 00 08 2a 21
	21 03 01 00 00 08 2c 21
	21 04 00 00 00 0d 02 3e
	21 04 01 00 00 0d 04 3e
	21 05 00 00 00 11 30 16
	21 05 01 00 00 11 32 16
	21 06 00 00 00 16 28 36
	21 06 01 00 00 16 2a 36
	21 07 00 00 00 1a 36 11
	21 07 01 00 00 1a 38 11
	21 08 00 00 00 1f 11 41
	21 08 01 00 00 1f 13 41
	21 09 00 00 00 24 01 1c
	21 09 01 00 00 24 03 1c
	21 0a 00 00 00 28 09 2c
	21 0a 01 00 00 28 0b 2c
	21 0b 00 00 00 2c 14 41
	21 0b 01 00 00 2c 16 41
	21 0c 00 00 00 32 04 23
	21 0c 01 00 00 32 06 23
	01 aa 01 01 00 36 0c 47
06:58:27	#30 Text 0 File CDTextInfo.cpp, Line 225
	CD Text info to be written:
	 Album Title  : Nowy album
	 Album Artist : Kombi
	 12 Tacks [Title] | [Artist] :
	   1: Na drobre dni | Kombi
	   2: Sen za snem | Kombi
	   3: Niech moc połączy | Kombi
	   4: Nowy rozdział | Kombi
	   5: Miłością zmieniaj świat | Kombi
	   6: Siedem piekieł | Kombi
	   7: Niedopowiedzenia | Kombi
	   8: Gwinea | Kombi
	   9: Jaki jest wolności smak | Kombi
	  10: Słoneczny dzień | Kombi
	  11: bonus: Słodkiego miłego życia (live) | Kombi
	  12: The Sound Of Silence | Disturbed
06:58:27	#31 Text 0 File ThreadedTransfer.cpp, Line 275
	Pipe memory size 83836800
07:05:48	#32 Text 0 File WriterStatus.cpp, Line 245
	<H: GoldStar CD-RW CED-8080B> start writing Lead-Out at LBA 243821 (3B86Dh), length 0 blocks
07:05:48	#33 SPTI -1169 File SCSIPassThrough.cpp, Line 225
	CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1169)
	CDB Data:   0x35 02 00 00 00 00 00 00 00 00 00 00
	Sense Key:  0x02 (KEY_NOT_READY)
	Sense Code: 0x04
	Sense Qual: 0x08
	Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08
07:06:03	#34 PHASE 37 File dlgbrnst.cpp, Line 2095
	Burn process completed successfully at 8x (1*200 KB/s)
07:06:03	#35 Text 0 File AudioCompilationImpl.cpp, Line 863
	DRM: DRM burn session terminated.
07:06:03	#36 Text 0 File AudioCompilationImpl.cpp, Line 892
	DRM: Closing entire DRM handling. Bye.
07:06:03	#37 Text 0 File SCSIPTICommands.cpp, Line 454
07:06:03	#38 Text 0 File Cdrdrv.cpp, Line 12297
07:06:03	#39 Text 0 File SCSIPTICommands.cpp, Line 617
Stary 14.01.2017, 18:19   #3
Brak DAO. Oraz ten dreszczyk emocji przy wykresie bufora z powodu braku Burn Proofa...
oraz ta nuda przy wypalaniu CDRW 650MB 4x...
Stary 09.07.2017, 17:27   #4
Arepo
Avatar użytkownika Arepo
Data rejestracji: 30.09.2004
Arepo jest wzorem do naśladowania <650 - 999 pkt>Arepo jest wzorem do naśladowania <650 - 999 pkt>Arepo jest wzorem do naśladowania <650 - 999 pkt>Arepo jest wzorem do naśladowania <650 - 999 pkt>Arepo jest wzorem do naśladowania <650 - 999 pkt>Arepo jest wzorem do naśladowania <650 - 999 pkt>
Znaleziona dzisiaj w szafie, jedna z moich pierwszych nagrywarek. Wyczyściłem, nasmarowałem i porobiłem kilka fotek oraz testów. Napęd został podłączony przez taką przejściówkę SATA.
GoldStar\LG CED-8080B 2001r-img_3404.jpg GoldStar\LG CED-8080B 2001r-img_3405.jpg
GoldStar\LG CED-8080B 2001r-img_3408.jpg GoldStar\LG CED-8080B 2001r-img_3409.jpg
GoldStar\LG CED-8080B 2001r-img_3411.jpg GoldStar\LG CED-8080B 2001r-img_3414.jpg
Nagranie CD-Audio, prędkość 8x, Cybelink Power2Go 9, nośnik Sony CD-R Supremas x48 700 MB MID: 97m24s16f.
Test jakości na LiteON iHBS112.
Najśmieszniejsze, że jak pamiętam przestałem używać tego napędu, gdyż przestał nagrywać.
Stary 10.07.2017, 09:08   #5
Te lasery Sony KRS-20xA ciężko zajeździć
Ciekawe że mój egzemplarz jeszcze sygnowany logiem GoldStar .
Stary 10.07.2017, 13:58   #6
Arepo
Rzeczywiście ciekawe. Płytę główną mamy dokładnie tą samą z 25 maja 2000 roku. Na etykiecie różnica w dacie produkcji tylko 3 miesiące.
Stary 18.08.2017, 20:59   #7
Loczek
Kocham Agnieszke T. !!!
Avatar użytkownika Loczek
Moja pierwsza nagrywarka... Udupiłem ją jak wgrywałem do niej nowego biosa. Wada - brak subkanałów.
Loczek jest offline   Odpowiedz cytując ten post
Stary 18.08.2017, 22:29   #8
Napisany przez Loczek Podgląd Wiadomości
Taak nieaktywny tryb DAO w Nero, nie dało się tym Diablo 2 zbackupować
Stary 22.08.2017, 11:25   #9
Doszły dwie sztuki na zapas Jedna jeszcze z logo GoldStar , druga już LG
Stary 22.08.2017, 19:11   #10
Arepo
Jak to doszły, skąd je masz ?
Stary 23.08.2017, 06:01   #11
Od Mikołaja
Mam kilka zaprzyjaźnionych firm które ściągają komputery do rozbiórek - mają moje play-listy i jak coś ciekawego znajdą to meldują
Stary 23.08.2017, 21:08   #12
Arepo
Nie ma to jak Mikołaj w sierpniu
Fajne sprzęty, ja na swoim nagrałem już kilka płyt i jestem bardzo zadowolony. Miło jest sobie przypomnieć jaka kultura pracy była w tych napędach. Po przesiadce na Lite-ON, człowiek dostawał prawdziwy szok "toporności"
Stary 24.08.2017, 06:27   #13
OPU Sony KRS-20xA to jedne z najlepszych i najtrwalszych laserów CDRW..
Do tego chip główny OAK OTI (ukochane chipy Yamahy )
Jeszcze tylko jeden model LG miał podobny hardware ( LG -CED-8012B)
"Szesnastka " i wszystkie modele nowsze LG ma już hardware MediaTek \OPU Sony lub Sanyo
[Muzeum] LG -GCE-8160B - 2001r.
Stary 24.08.2017, 19:14   #14
Arepo
Był jeszcze model CED-8083B, wydaje mi się że miał te same bebechy, jedyna różnica do 8080B to wolniejsze nagrywanie 4x.
Stary 24.08.2017, 20:27   #15
Były jeszcze :
x4
LG CED-8043B
LG CED-8042B
LG CED-8041B
x8
LG CED-8081B
Wszystkie bardzo rzadkie dziś do spotkania .
-! POMOCY !- LG CD-RW CED 8080B Nie nagrywa !!! Pavcio Napędy optyczne CD 10 19.11.2004 17:29
Lg Cd-rw Ced 8080b Lukasek Napędy optyczne CD 6 03.04.2003 15:46
nieudany upgrade firmware***39;u (model nagrywary: LG CED 8080b) HELP! boris Napędy optyczne CD 1 04.11.2001 15:01
Mozliwosc rozbudowy CED 8080B??? Chrisu Napędy optyczne CD 2 30.03.2001 00:17
czy bedzie DAO-Raw w Ced 8080B VooDoo Napędy optyczne CD 7 18.01.2001 09:16
Wszystkie czasy w strefie CET. Aktualna godzina: 07:36.
