| czary2mary |
14.01.2017 07:33 |
Ilość załączników: 8
GoldStar\LG CED-8080B fw.1.06
Nero 2016 x8
log:
Kod:
Windows 8 6.2
IA32
Nero Version: 17.0.5.0
Internal Version: 17,0,5,0
Recorder : <GoldStar CD-RW CED-8080B> FW version: 1.06 - HA 1 TA 1 - 17.0.5.0
Device bus : <> HA 1
Host system bus : <IDE>
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD/DVD-ROM : <BENQ DVD DD DW1640 > FW version: BSRB - HA 1 TA 0 - 17.0.5.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
BENQ DVD DD DW1640 G: CdRom0
GoldStar CD-RW CED-8080B H: CdRom1
ATAPI iHAS224 A N: CdRom2
PLEXTOR DVDR PX-890SA M: CdRom3
AutoRun : 0
Excluded drive IDs:
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 25 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
13.1.2017
Audio CD
06:57:49 #1 Text 0 File SCSIPTICommands.cpp, Line 617
06:57:49 #2 CDADOC -1 File Cdadoc.cpp, Line 1762
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:26.63, Pause frames: 150, Filters: 1, Name: '01.Kombi - Na drobre dni.flac'.
Track 02: Length: 04:11.45, Pause frames: 150, Filters: 1, Name: '02.Kombi - Sen za snem.flac'.
Track 03: Length: 04:18.29, Pause frames: 150, Filters: 1, Name: '03.Kombi - Niech moc połączy.flac'.
Track 04: Length: 04:43.35, Pause frames: 150, Filters: 1, Name: '04.Kombi - Nowy rozdział.flac'.
Track 05: Length: 04:50.32, Pause frames: 150, Filters: 1, Name: '05.Kombi - Miłością zmieniaj świat.flac'.
Track 06: Length: 04:11.38, Pause frames: 150, Filters: 1, Name: '06.Kombi - Siedem piekieł.flac'.
Track 07: Length: 04:21.48, Pause frames: 150, Filters: 1, Name: '07.Kombi - Niedopowiedzenia.flac'.
Track 08: Length: 04:41.38, Pause frames: 150, Filters: 1, Name: '08.Kombi - Gwinea.flac'.
Track 09: Length: 04:06.16, Pause frames: 150, Filters: 1, Name: '09.Kombi - Jaki jest wolności smak.flac'.
Track 10: Length: 04:09.21, Pause frames: 150, Filters: 1, Name: '10.Kombi - Słoneczny dzień.flac'.
Track 11: Length: 05:41.45, Pause frames: 150, Filters: 1, Name: '11.Kombi - bonus- Słodkiego miłego życia (live).flac'.
Track 12: Length: 04:06.36, Pause frames: 150, Filters: 1, Name: '11 - The Sound Of Silence.mp3'.
Total size: 54:12.71
06:57:50 #3 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
06:57:50 #4 PHASE 214 File dlgbrnst.cpp, Line 2095
Generation of disc structures started
06:57:50 #5 PHASE 215 File dlgbrnst.cpp, Line 2095
Generation of disc structures completed
06:57:50 #6 Text 0 File Burncd.cpp, Line 4086
Turn on Disc-At-Once, using CD-R/RW media
06:57:50 #7 Text 0 File DlgWaitCD.cpp, Line 335
[H: CD-RW CED-8080B ] Last possible write address on media: 359843
Last address to be written: 243820
06:57:50 #8 Text 0 File DlgWaitCD.cpp, Line 347
[H: CD-RW CED-8080B ] Write in overburning mode: NO (enabled: CD)
06:57:50 #9 Text 0 File DlgWaitCD.cpp, Line 3127
Recorder: GoldStar CD-RW CED-8080B;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
06:57:50 #10 Text 0 File DlgWaitCD.cpp, Line 537
[H: CD-RW CED-8080B ] >>> Protocol of DlgWaitCD activities: <<<
06:57:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 879
0: TRM_AUDIO_NOPRE (01.Kombi - Na drobre dni.flac)
original disc pos #0 + 20013 (20013) = #20013/4:26.63
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20013 blocks [H: GoldStar CD-RW CED-8080B]
1: TRM_AUDIO_NOPRE (02.Kombi - Sen za snem.flac)
original disc pos #0 + 18870 (18870) = #18870/4:11.45
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18870 blocks [H: GoldStar CD-RW CED-8080B]
2: TRM_AUDIO_NOPRE (03.Kombi - Niech moc połączy.flac)
original disc pos #0 + 19379 (19379) = #19379/4:18.29
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19379 blocks [H: GoldStar CD-RW CED-8080B]
3: TRM_AUDIO_NOPRE (04.Kombi - Nowy rozdział.flac)
original disc pos #0 + 21260 (21260) = #21260/4:43.35
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21260 blocks [H: GoldStar CD-RW CED-8080B]
4: TRM_AUDIO_NOPRE (05.Kombi - Miłością zmieniaj świat.flac)
original disc pos #0 + 21782 (21782) = #21782/4:50.32
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21782 blocks [H: GoldStar CD-RW CED-8080B]
5: TRM_AUDIO_NOPRE (06.Kombi - Siedem piekieł.flac)
original disc pos #0 + 18863 (18863) = #18863/4:11.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18863 blocks [H: GoldStar CD-RW CED-8080B]
6: TRM_AUDIO_NOPRE (07.Kombi - Niedopowiedzenia.flac)
original disc pos #0 + 19623 (19623) = #19623/4:21.48
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19623 blocks [H: GoldStar CD-RW CED-8080B]
7: TRM_AUDIO_NOPRE (08.Kombi - Gwinea.flac)
original disc pos #0 + 21113 (21113) = #21113/4:41.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21113 blocks [H: GoldStar CD-RW CED-8080B]
8: TRM_AUDIO_NOPRE (09.Kombi - Jaki jest wolności smak.flac)
original disc pos #0 + 18466 (18466) = #18466/4:6.16
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18466 blocks [H: GoldStar CD-RW CED-8080B]
9: TRM_AUDIO_NOPRE (10.Kombi - Słoneczny dzień.flac)
original disc pos #0 + 18696 (18696) = #18696/4:9.21
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18696 blocks [H: GoldStar CD-RW CED-8080B]
10: TRM_AUDIO_NOPRE (11.Kombi - bonus- Słodkiego miłego życia (live).flac)
original disc pos #0 + 25620 (25620) = #25620/5:41.45
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25620 blocks [H: GoldStar CD-RW CED-8080B]
11: TRM_AUDIO_NOPRE (11 - The Sound Of Silence.mp3)
original disc pos #0 + 18486 (18486) = #18486/4:6.36
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18486 blocks [H: GoldStar CD-RW CED-8080B]
06:57:50 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [H: GoldStar CD-RW CED-8080B] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
Tracks 1 to 12: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 47423376, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 47423376 47776176 92158416, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 92158416 92511216 138090624, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 138090624 138443424 188446944, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 188446944 188799744 240031008, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 240031008 240383808 284749584, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 284749584 285102384 331255680, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 331255680 331608480 381266256, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 381266256 381619056 425051088, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 425051088 425403888 469376880, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 469376880 469729680 529987920, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 529987920 530340720 573819792, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 0 | 0 | 0x00
0 | 1 | 1 | 0x21 | 20013 | 0 | 0x00
20013 | 2 | 0 | 0x21 | 0 | 0 | 0x00
20163 | 2 | 1 | 0x21 | 18870 | 20163 | 0x00
39033 | 3 | 0 | 0x21 | 0 | 0 | 0x00
39183 | 3 | 1 | 0x21 | 19379 | 39183 | 0x00
58562 | 4 | 0 | 0x21 | 0 | 0 | 0x00
58712 | 4 | 1 | 0x21 | 21260 | 58712 | 0x00
79972 | 5 | 0 | 0x21 | 0 | 0 | 0x00
80122 | 5 | 1 | 0x21 | 21782 | 80122 | 0x00
101904 | 6 | 0 | 0x21 | 0 | 0 | 0x00
102054 | 6 | 1 | 0x21 | 18863 | 102054 | 0x00
120917 | 7 | 0 | 0x21 | 0 | 0 | 0x00
121067 | 7 | 1 | 0x21 | 19623 | 121067 | 0x00
140690 | 8 | 0 | 0x21 | 0 | 0 | 0x00
140840 | 8 | 1 | 0x21 | 21113 | 140840 | 0x00
161953 | 9 | 0 | 0x21 | 0 | 0 | 0x00
162103 | 9 | 1 | 0x21 | 18466 | 162103 | 0x00
180569 | 10 | 0 | 0x21 | 0 | 0 | 0x00
180719 | 10 | 1 | 0x21 | 18696 | 180719 | 0x00
199415 | 11 | 0 | 0x21 | 0 | 0 | 0x00
199565 | 11 | 1 | 0x21 | 25620 | 199565 | 0x00
225185 | 12 | 0 | 0x21 | 0 | 0 | 0x00
225335 | 12 | 1 | 0x21 | 18486 | 225335 | 0x00
243821 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
MediaType: CD-R
06:58:27 #13 Text 0 File SCSIPTICommands.cpp, Line 404
06:58:27 #14 Text 0 File Burncd.cpp, Line 4984
Caching options: cache CDRom or Network-No, small files-No (<64KB)
06:58:27 #15 PHASE 36 File dlgbrnst.cpp, Line 2095
Burn process started at 8x (1*200 KB/s)
06:58:27 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
06:58:27 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #20163
06:58:27 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #39183
06:58:27 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #58712
06:58:27 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #80122
06:58:27 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #102054
06:58:27 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #121067
06:58:27 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #140840
06:58:27 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #162103
06:58:27 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #180719
06:58:27 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #199565
06:58:27 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #225335
06:58:27 #28 Text 0 File Mmc.cpp, Line 17653
StartDAO : CD-Text - On
06:58:27 #29 Text 0 File Mmc.cpp, Line 17883
CueData, Len=208
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 1c 3f
21 02 01 00 00 04 1e 3f
21 03 00 00 00 08 2a 21
21 03 01 00 00 08 2c 21
21 04 00 00 00 0d 02 3e
21 04 01 00 00 0d 04 3e
21 05 00 00 00 11 30 16
21 05 01 00 00 11 32 16
21 06 00 00 00 16 28 36
21 06 01 00 00 16 2a 36
21 07 00 00 00 1a 36 11
21 07 01 00 00 1a 38 11
21 08 00 00 00 1f 11 41
21 08 01 00 00 1f 13 41
21 09 00 00 00 24 01 1c
21 09 01 00 00 24 03 1c
21 0a 00 00 00 28 09 2c
21 0a 01 00 00 28 0b 2c
21 0b 00 00 00 2c 14 41
21 0b 01 00 00 2c 16 41
21 0c 00 00 00 32 04 23
21 0c 01 00 00 32 06 23
01 aa 01 01 00 36 0c 47
06:58:27 #30 Text 0 File CDTextInfo.cpp, Line 225
CD Text info to be written:
Album Title : Nowy album
Album Artist : Kombi
12 Tacks [Title] | [Artist] :
1: Na drobre dni | Kombi
2: Sen za snem | Kombi
3: Niech moc połączy | Kombi
4: Nowy rozdział | Kombi
5: Miłością zmieniaj świat | Kombi
6: Siedem piekieł | Kombi
7: Niedopowiedzenia | Kombi
8: Gwinea | Kombi
9: Jaki jest wolności smak | Kombi
10: Słoneczny dzień | Kombi
11: bonus: Słodkiego miłego życia (live) | Kombi
12: The Sound Of Silence | Disturbed
06:58:27 #31 Text 0 File ThreadedTransfer.cpp, Line 275
Pipe memory size 83836800
07:05:48 #32 Text 0 File WriterStatus.cpp, Line 245
<H: GoldStar CD-RW CED-8080B> start writing Lead-Out at LBA 243821 (3B86Dh), length 0 blocks
07:05:48 #33 SPTI -1169 File SCSIPassThrough.cpp, Line 225
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1169)
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x08
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08
07:06:03 #34 PHASE 37 File dlgbrnst.cpp, Line 2095
Burn process completed successfully at 8x (1*200 KB/s)
07:06:03 #35 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
07:06:03 #36 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
07:06:03 #37 Text 0 File SCSIPTICommands.cpp, Line 454
07:06:03 #38 Text 0 File Cdrdrv.cpp, Line 12297
07:06:03 #39 Text 0 File SCSIPTICommands.cpp, Line 617
Załącznik 86019
Załącznik 86020
Załącznik 86021
Załącznik 86022
Załącznik 86023
Załącznik 86024
Załącznik 86025
Załącznik 86026
