Lite-on Big Problem
witam mam LITE-ON 4064-2200-1335 i wywala mi Błąd Kalibracji mocy.
niemoge odtwarzac płyt nawet przy zgrywaniu wywala bład narzedzia Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-11-11 15:49:52 Wersja Nero: 6.3.0.0 Nagrywarka: <LITE-ON CD-RW SOHR-5238S>Wersja: 4S04 - HA 0 TA 0 - 6.3.0.0 Sterownik adaptera: <atapi> HA 0 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <Generic DVD-ROM >Wersja: 1.0 - HA 2 TA 0 - 6.3.0.0 Sterownik adaptera: <d344prt> HA 2 === Scsi-Device-Map === CdRomPeripheral : LITE-ON CD-RW SOHR-5238S atapi Port 0 ID 0 DMA: Off DiskPeripheral : Maxtor 6Y060L0 atapi Port 1 ID 1 DMA: On CdRomPeripheral : Generic DVD-ROM 1.0 d344prt Port 2 ID 0 DMA: Off === CDRom-Device-Map === LITE-ON CD-RW SOHR-5238S F: CDRom0 Generic DVD-ROM G: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 40894464 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 255MB (261620kB) Free physical memory: 53MB (54940kB) Memory in use : 79 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 3.9.2005 Audio CD 16:46:34 #1 CDADOC -1 File Cdadoc.cpp, Line 1508 Audio item log info: Audio document burn settings: ============================= Burn mode: DAO, CD Text: On, Cache disk or network files: No, Cache small files: No, Cache files smaller than 65536 bytes. Audio Multisession: No List of audio tracks: ===================== Track 01: Length: 04:29.65, Pause frames: 150, Filters: 0, Name: '01 - Hard As A Rock.mp3'. Track 02: Length: 06:03.70, Pause frames: 150, Filters: 0, Name: '02 - Let There Be Rock.mp3'. Track 03: Length: 04:52.38, Pause frames: 150, Filters: 0, Name: '03 - Thunderstruck.mp3'. Track 04: Length: 04:11.63, Pause frames: 150, Filters: 0, Name: '04 - Dirty Deeds Done Dirt Cheap.mp3'. Track 05: Length: 04:20.01, Pause frames: 150, Filters: 0, Name: '05 - Big Guns.mp3'. Track 06: Length: 05:48.04, Pause frames: 150, Filters: 0, Name: '06 - The Jack.mp3'. Track 07: Length: 03:47.59, Pause frames: 150, Filters: 0, Name: '07 - Heatseeker.mp3'. Track 08: Length: 04:36.69, Pause frames: 150, Filters: 0, Name: '08 - Jailbreak.mp3'. Track 09: Length: 03:30.58, Pause frames: 150, Filters: 0, Name: '09 - You Shook Me All Night Long.mp3'. Track 10: Length: 03:37.01, Pause frames: 150, Filters: 0, Name: '10 - Rock 'n' Roll Damnation.mp3'. Track 11: Length: 04:07.36, Pause frames: 150, Filters: 0, Name: '11 - Shake Your Foundations.mp3'. Track 12: Length: 03:32.47, Pause frames: 150, Filters: 0, Name: '12 - TNT.mp3'. Track 13: Length: 03:24.14, Pause frames: 150, Filters: 0, Name: '13 - Who Made Who.mp3'. Track 14: Length: 03:29.16, Pause frames: 150, Filters: 0, Name: '14 - Highway To Hell.mp3'. Track 15: Length: 04:10.05, Pause frames: 150, Filters: 0, Name: '15 - Whole Lotta Rosie.mp3'. Track 16: Length: 05:45.39, Pause frames: 150, Filters: 0, Name: '16 - For Those About To Rock [We Salute You].mp3'. Track 17: Length: 02:39.31, Pause frames: 150, Filters: 0, Name: '17 - Big Balls.mp3'. Track 18: Length: 02:48.19, Pause frames: 150, Filters: 0, Name: '18 - Rocker.mp3'. Total size: 75:51.35 16:46:34 #2 Phase 90 File dlgbrnst.cpp, Line 1800 Włączono system ochrony zapisu 16:46:34 #3 Text 0 File Reader.cpp, Line 118 Reader running 16:46:34 #4 Text 0 File Writer.cpp, Line 124 Writer LITE-ON CD-RW SOHR-5238S running 16:46:34 #5 Text 0 File Burncd.cpp, Line 3094 Turn on Disc-At-Once, using CD-R/RW media 16:46:34 #6 Text 0 File DlgWaitCD.cpp, Line 239 Last possible write address on media: 359845 (79:59.70) Last address to be written: 341209 (75:51.34) 16:46:34 #7 Text 0 File DlgWaitCD.cpp, Line 244 Write in overburning mode: FALSE 16:46:34 #8 Text 0 File DlgWaitCD.cpp, Line 2068 Recorder: LITE-ON CD-RW SOHR-5238S; CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc. ATIP Data: Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid) 16:46:34 #9 Text 0 File DlgWaitCD.cpp, Line 405 >>> Protocol of DlgWaitCD activities: <<< ========================================= 16:46:34 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (01 - Hard As A Rock.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 20240 (20240) = #20240/4:29.65 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20240 blocks [LITE-ON CD-RW SOHR-5238S] 1: TRM_AUDIO_NOPRE (02 - Let There Be Rock.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 27295 (27295) = #27295/6:3.70 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27295 blocks [LITE-ON CD-RW SOHR-5238S] 2: TRM_AUDIO_NOPRE (03 - Thunderstruck.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 21938 (21938) = #21938/4:52.38 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21938 blocks [LITE-ON CD-RW SOHR-5238S] 3: TRM_AUDIO_NOPRE (04 - Dirty Deeds Done Dirt Cheap.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 18888 (18888) = #18888/4:11.63 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18888 blocks [LITE-ON CD-RW SOHR-5238S] 4: TRM_AUDIO_NOPRE (05 - Big Guns.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 19501 (19501) = #19501/4:20.1 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19501 blocks [LITE-ON CD-RW SOHR-5238S] 5: TRM_AUDIO_NOPRE (06 - The Jack.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 26104 (26104) = #26104/5:48.4 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26104 blocks [LITE-ON CD-RW SOHR-5238S] 6: TRM_AUDIO_NOPRE (07 - Heatseeker.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 17084 (17084) = #17084/3:47.59 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17084 blocks [LITE-ON CD-RW SOHR-5238S] 7: TRM_AUDIO_NOPRE (08 - Jailbreak.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 20769 (20769) = #20769/4:36.69 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20769 blocks [LITE-ON CD-RW SOHR-5238S] 8: TRM_AUDIO_NOPRE (09 - You Shook Me All Night Long.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15808 (15808) = #15808/3:30.58 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15808 blocks [LITE-ON CD-RW SOHR-5238S] 9: TRM_AUDIO_NOPRE (10 - Rock 'n' Roll Damnation.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 16276 (16276) = #16276/3:37.1 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16276 blocks [LITE-ON CD-RW SOHR-5238S] 10: TRM_AUDIO_NOPRE (11 - Shake Your Foundations.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 18561 (18561) = #18561/4:7.36 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18561 blocks [LITE-ON CD-RW SOHR-5238S] 11: TRM_AUDIO_NOPRE (12 - TNT.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15947 (15947) = #15947/3:32.47 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15947 blocks [LITE-ON CD-RW SOHR-5238S] 12: TRM_AUDIO_NOPRE (13 - Who Made Who.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15314 (15314) = #15314/3:24.14 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15314 blocks [LITE-ON CD-RW SOHR-5238S] 13: TRM_AUDIO_NOPRE (14 - Highway To Hell.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15691 (15691) = #15691/3:29.16 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15691 blocks [LITE-ON CD-RW SOHR-5238S] 14: TRM_AUDIO_NOPRE (15 - Whole Lotta Rosie.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 18755 (18755) = #18755/4:10.5 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18755 blocks [LITE-ON CD-RW SOHR-5238S] 15: TRM_AUDIO_NOPRE (16 - For Those About To Rock [We Salute You].mp3) 2 indices, index0 (150) not provided original disc pos #0 + 25914 (25914) = #25914/5:45.39 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25914 blocks [LITE-ON CD-RW SOHR-5238S] 16: TRM_AUDIO_NOPRE (17 - Big Balls.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 11956 (11956) = #11956/2:39.31 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11956 blocks [LITE-ON CD-RW SOHR-5238S] 17: TRM_AUDIO_NOPRE (18 - Rocker.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 12619 (12619) = #12619/2:48.19 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12619 blocks [LITE-ON CD-RW SOHR-5238S] -------------------------------------------------------------- 16:46:34 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [LITE-ON CD-RW SOHR-5238S] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 18: 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 47957280, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 47957280 48310080 112507920, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 112507920 112860720 164458896, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 164458896 164811696 209236272, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 209236272 209589072 255455424, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 255455424 255808224 317204832, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 317204832 317557632 357739200, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 357739200 358092000 406940688, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 406940688 407293488 444473904, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 444473904 444826704 483107856, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 483107856 483460656 527116128, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 527116128 527468928 564976272, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 564976272 565329072 601347600, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 601347600 601700400 638605632, ISRC "" 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 638605632 638958432 683070192, ISRC "" 16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 683070192 683422992 744372720, ISRC "" 17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 744372720 744725520 772846032, ISRC "" 18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 772846032 773198832 802878720, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x01 -150 | 1 | 0 | 0x00 | 0x21 0 | 1 | 1 | 0x00 | 0x21 20240 | 2 | 0 | 0x00 | 0x21 20390 | 2 | 1 | 0x00 | 0x21 47685 | 3 | 0 | 0x00 | 0x21 47835 | 3 | 1 | 0x00 | 0x21 69773 | 4 | 0 | 0x00 | 0x21 69923 | 4 | 1 | 0x00 | 0x21 88811 | 5 | 0 | 0x00 | 0x21 88961 | 5 | 1 | 0x00 | 0x21 108462 | 6 | 0 | 0x00 | 0x21 108612 | 6 | 1 | 0x00 | 0x21 134716 | 7 | 0 | 0x00 | 0x21 134866 | 7 | 1 | 0x00 | 0x21 151950 | 8 | 0 | 0x00 | 0x21 152100 | 8 | 1 | 0x00 | 0x21 172869 | 9 | 0 | 0x00 | 0x21 173019 | 9 | 1 | 0x00 | 0x21 188827 | 10 | 0 | 0x00 | 0x21 188977 | 10 | 1 | 0x00 | 0x21 205253 | 11 | 0 | 0x00 | 0x21 205403 | 11 | 1 | 0x00 | 0x21 223964 | 12 | 0 | 0x00 | 0x21 224114 | 12 | 1 | 0x00 | 0x21 240061 | 13 | 0 | 0x00 | 0x21 240211 | 13 | 1 | 0x00 | 0x21 255525 | 14 | 0 | 0x00 | 0x21 255675 | 14 | 1 | 0x00 | 0x21 271366 | 15 | 0 | 0x00 | 0x21 271516 | 15 | 1 | 0x00 | 0x21 290271 | 16 | 0 | 0x00 | 0x21 290421 | 16 | 1 | 0x00 | 0x21 316335 | 17 | 0 | 0x00 | 0x21 316485 | 17 | 1 | 0x00 | 0x21 328441 | 18 | 0 | 0x00 | 0x21 328591 | 18 | 1 | 0x00 | 0x21 341210 | lead-out | 1 | 0x00 | 0x01 16:46:35 #12 Phase 36 File dlgbrnst.cpp, Line 1800 Rozpoczęto zapis z prędkością 52x (7*800 KB/s) 16:46:35 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 16:46:35 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #20390 16:46:35 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #47835 16:46:35 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #69923 16:46:35 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #88961 16:46:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #108612 16:46:35 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #134866 16:46:35 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #152100 16:46:35 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #173019 16:46:35 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #188977 16:46:35 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #205403 16:46:35 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #224114 16:46:35 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #240211 16:46:35 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #255675 16:46:35 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #271516 16:46:35 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #290421 16:46:35 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #316485 16:46:35 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #328591 16:46:35 #31 Text 0 File Mmc.cpp, Line 14801 StartDAO : CD-Text - On 16:46:35 #32 Text 0 File Mmc.cpp, Line 19397 Set BUFE: supported -> ON , SMART-BURN : ON 16:46:35 #33 Text 0 File Mmc.cpp, Line 15090 CueData, Len=304 21 00 00 41 00 00 00 00 21 01 00 00 00 00 00 00 21 01 01 00 00 00 02 00 21 02 00 00 00 04 1f 41 21 02 01 00 00 04 21 41 21 03 00 00 00 0a 25 3c 21 03 01 00 00 0a 27 3c 21 04 00 00 00 0f 20 17 21 04 01 00 00 0f 22 17 21 05 00 00 00 13 2e 0b 21 05 01 00 00 13 30 0b 21 06 00 00 00 18 08 0c 21 06 01 00 00 18 0a 0c 21 07 00 00 00 1d 3a 10 21 07 01 00 00 1e 00 10 21 08 00 00 00 21 30 00 21 08 01 00 00 21 32 00 21 09 00 00 00 26 1a 45 21 09 01 00 00 26 1c 45 21 0a 00 00 00 29 3b 34 21 0a 01 00 00 2a 01 34 21 0b 00 00 00 2d 26 35 21 0b 01 00 00 2d 28 35 21 0c 00 00 00 31 30 0e 21 0c 01 00 00 31 32 0e 21 0d 00 00 00 35 16 3d 21 0d 01 00 00 35 18 3d 21 0e 00 00 00 38 31 00 21 0e 01 00 00 38 33 00 21 0f 00 00 00 3c 14 10 21 0f 01 00 00 3c 16 10 21 10 00 00 00 40 20 15 21 10 01 00 00 40 22 15 21 11 00 00 00 46 13 3c 21 11 01 00 00 46 15 3c 21 12 00 00 00 49 01 10 21 12 01 00 00 49 03 10 01 aa 01 01 00 4b 33 23 17:03:11 #34 SCSI -1106 File Cdrdrv.cpp, Line 1430 SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x05250000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0xFF 0xFF 0xD4 0x21 0x00 0x02 0xAA 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 17:03:11 #35 CDR -1106 File Writer.cpp, Line 301 [/<b>Błąd kalibracji mocy!</b> 17:03:11 #36 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 17:03:11 #37 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 17:08:12 #38 CDR -1175 File Cdrdrv.cpp, Line 1228 Śledzenie wewnętrzne Resending of command failed after 300000ms CDB Data[hex]: 35 02 00 00 00 00 00 00 00 00 00 00 17:08:12 #39 SCSI -1169 File Cdrdrv.cpp, Line 1229 SCSI Exec, HA 0, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x04 Sense Qual: 0x08 CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x04 0x08 17:14:06 #40 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 17:14:06 #41 Phase 38 File dlgbrnst.cpp, Line 1800 Zapis z prędkością 52x (7*800 KB/s) nie powiódł się! Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-03-12 00:28:13 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 23:51:54 (Adapter driver for rec) File 'Drivers\d344prt.sys': Ver=3.44.0.0 built by: WinDDK, size=5248 bytes, created 2003-12-27 02:38:10 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
Wszystkie czasy w strefie CET. Aktualna godzina: 21:47. |
