Data rejestracji: 11.09.2002
Błąd kalibracji mocy! na TEAC CD-W540E
przy nagrywaniu plyt wyskakuje mi taki oto komunikat:
XXXX XXXX XXX-XXXX-XXXX-XXXX-XXXX-XXXX Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56 ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06 Wersja Nero: 6.3.0.2 (Nero Express) Nagrywarka: <TEAC CD-W540E> Wersja: 1.0D - HA 1 TA 0 - 6.3.0.2 Sterownik adaptera: <atapi> HA 1 Drive buffer : 8192kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <TEAC CD-W540E >Wersja: 1.0D - HA 1 TA 0 - 6.3.0.2 Sterownik adaptera: <atapi> HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD800JB-00ETA0 atapi Port 0 ID 0 DMA: On DiskPeripheral : ST320423A atapi Port 0 ID 1 DMA: On CdRomPeripheral : TEAC CD-W540E atapi Port 1 ID 0 DMA: On CdRomPeripheral : LG CD-ROM CRD-8483B atapi Port 1 ID 1 DMA: Off === CDRom-Device-Map === TEAC CD-W540E G: CDRom0 LG CD-ROM CRD-8483B L: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 95MB (97528kB) Memory in use : 81 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 20.3.2004 Audio CD 11:51:41 #1 CDADOC -1 File Cdadoc.cpp, Line 1508 Audio item log info: Audio document burn settings: ============================= Burn mode: DAO, CD Text: On, Cache disk or network files: No, Cache small files: No, Cache files smaller than 65536 bytes. Audio Multisession: No List of audio tracks: ===================== Track 01: Length: 02:09.42, Pause frames: 150, Filters: 0, Name: '01 XXX.aif. Track 02: Length: 02:04.53, Pause frames: 150, Filters: 0, Name: '02 XXX.aif. Track 03: Length: 02:15.58, Pause frames: 150, Filters: 0, Name: '03 XXX.aif. Track 04: Length: 02:44.44, Pause frames: 150, Filters: 0, Name: '04 XXX.aif. Track 05: Length: 02:36.10, Pause frames: 150, Filters: 0, Name: '05 XXX.aif. Track 06: Length: 02:00.12, Pause frames: 150, Filters: 0, Name: '06 XXX.aif. Track 07: Length: 01:49.08, Pause frames: 150, Filters: 0, Name: '07 (XXX.aif. Track 08: Length: 02:37.15, Pause frames: 150, Filters: 0, Name: '08 XXX.aif. Track 09: Length: 02:51.23, Pause frames: 150, Filters: 0, Name: '09 XXX.aif. Track 10: Length: 01:56.71, Pause frames: 150, Filters: 0, Name: '10 XXX.aif. Track 11: Length: 02:34.62, Pause frames: 150, Filters: 0, Name: '11 XXX.aif. Track 12: Length: 02:41.62, Pause frames: 150, Filters: 0, Name: '12 (XXX.aif. Track 13: Length: 02:16.72, Pause frames: 150, Filters: 0, Name: '13 XXX.aif. Track 14: Length: 02:20.60, Pause frames: 150, Filters: 0, Name: '14 XXX.aif. Track 15: Length: 03:17.73, Pause frames: 150, Filters: 0, Name: '15 XXX.aif. Track 16: Length: 03:08.51, Pause frames: 150, Filters: 0, Name: '16 XXX.aif. Track 17: Length: 02:04.27, Pause frames: 150, Filters: 0, Name: '17 XXX.aif. Track 18: Length: 01:55.32, Pause frames: 150, Filters: 0, Name: '18 XXX.aif'. Track 19: Length: 02:08.70, Pause frames: 150, Filters: 0, Name: '19 XXX.aif. Total size: 46:13.20 11:51:41 #2 Phase 72 File dlgbrnst.cpp, Line 1800 Włączono system BURN-Proof 11:51:41 #3 Text 0 File Reader.cpp, Line 118 Reader running 11:51:41 #4 Text 0 File Writer.cpp, Line 124 Writer TEAC CD-W540E running 11:51:41 #5 Text 0 File Burncd.cpp, Line 3101 Turn on Disc-At-Once, using CD-R/RW media 11:51:41 #6 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 207844 ( 46:13.19) 11:51:41 #7 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 11:51:41 #8 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: TEAC CD-W540E; CDR code: 00 97 15 37; OSJ entry from: NAN-YA Plastics Corporation ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 0F 25 (LI 97:15.37), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid) 11:51:41 #9 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= 11:51:41 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 9717 (9717) = #9717/2:9.42 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9717 blocks [TEAC CD-W540E ] 1: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 9353 (9353) = #9353/2:4.53 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9353 blocks [TEAC CD-W540E ] 2: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 10183 (10183) = #10183/2:15.58 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10183 blocks [TEAC CD-W540E ] 3: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 12344 (12344) = #12344/2:44.44 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12344 blocks [TEAC CD-W540E ] 4: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 11710 (11710) = #11710/2:36.10 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11710 blocks [TEAC CD-W540E ] 5: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 9012 (9012) = #9012/2:0.12 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9012 blocks [TEAC CD-W540E ] 6: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 8183 (8183) = #8183/1:49.8 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 8183 blocks [TEAC CD-W540E ] 7: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 11790 (11790) = #11790/2:37.15 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11790 blocks [TEAC CD-W540E ] 8: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 12848 (12848) = #12848/2:51.23 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12848 blocks [TEAC CD-W540E ] 9: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 8771 (8771) = #8771/1:56.71 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 8771 blocks [TEAC CD-W540E ] 10: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 11612 (11612) = #11612/2:34.62 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11612 blocks [TEAC CD-W540E ] 11: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 12137 (12137) = #12137/2:41.62 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12137 blocks [TEAC CD-W540E ] 12: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 10272 (10272) = #10272/2:16.72 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10272 blocks [TEAC CD-W540E ] 13: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 10560 (10560) = #10560/2:20.60 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10560 blocks [TEAC CD-W540E ] 14: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 14848 (14848) = #14848/3:17.73 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14848 blocks [TEAC CD-W540E ] 15: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 14151 (14151) = #14151/3:8.51 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14151 blocks [TEAC CD-W540E ] 16: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 9327 (9327) = #9327/2:4.27 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9327 blocks [TEAC CD-W540E ] 17: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 8657 (8657) = #8657/1:55.32 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 8657 blocks [TEAC CD-W540E ] 18: TRM_AUDIO_NOPRE (XXX.aif) 2 indices, index0 (150) not provided original disc pos #0 + 9670 (9670) = #9670/2:8.70 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9670 blocks [TEAC CD-W540E ] -------------------------------------------------------------- 11:51:41 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [TEAC CD-W540E ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 19: 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 23207184, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 23207184 23559984 45558240, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 45558240 45911040 69861456, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 69861456 70214256 99247344, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 99247344 99600144 127142064, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 127142064 127494864 148691088, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 148691088 149043888 168290304, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 168290304 168643104 196373184, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 196373184 196725984 226944480, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 226944480 227297280 247926672, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 247926672 248279472 275590896, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 275590896 275943696 304489920, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 304489920 304842720 329002464, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 329002464 329355264 354192384, ISRC "" 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 354192384 354545184 389467680, ISRC "" 16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 389467680 389820480 423103632, ISRC "" 17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 423103632 423456432 445393536, ISRC "" 18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 445393536 445746336 466107600, ISRC "" 19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 466107600 466460400 489204240, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x01 -150 | 1 | 0 | 0x00 | 0x21 0 | 1 | 1 | 0x00 | 0x21 9717 | 2 | 0 | 0x00 | 0x21 9867 | 2 | 1 | 0x00 | 0x21 19220 | 3 | 0 | 0x00 | 0x21 19370 | 3 | 1 | 0x00 | 0x21 29553 | 4 | 0 | 0x00 | 0x21 29703 | 4 | 1 | 0x00 | 0x21 42047 | 5 | 0 | 0x00 | 0x21 42197 | 5 | 1 | 0x00 | 0x21 53907 | 6 | 0 | 0x00 | 0x21 54057 | 6 | 1 | 0x00 | 0x21 63069 | 7 | 0 | 0x00 | 0x21 63219 | 7 | 1 | 0x00 | 0x21 71402 | 8 | 0 | 0x00 | 0x21 71552 | 8 | 1 | 0x00 | 0x21 83342 | 9 | 0 | 0x00 | 0x21 83492 | 9 | 1 | 0x00 | 0x21 96340 | 10 | 0 | 0x00 | 0x21 96490 | 10 | 1 | 0x00 | 0x21 105261 | 11 | 0 | 0x00 | 0x21 105411 | 11 | 1 | 0x00 | 0x21 117023 | 12 | 0 | 0x00 | 0x21 117173 | 12 | 1 | 0x00 | 0x21 129310 | 13 | 0 | 0x00 | 0x21 129460 | 13 | 1 | 0x00 | 0x21 139732 | 14 | 0 | 0x00 | 0x21 139882 | 14 | 1 | 0x00 | 0x21 150442 | 15 | 0 | 0x00 | 0x21 150592 | 15 | 1 | 0x00 | 0x21 165440 | 16 | 0 | 0x00 | 0x21 165590 | 16 | 1 | 0x00 | 0x21 179741 | 17 | 0 | 0x00 | 0x21 179891 | 17 | 1 | 0x00 | 0x21 189218 | 18 | 0 | 0x00 | 0x21 189368 | 18 | 1 | 0x00 | 0x21 198025 | 19 | 0 | 0x00 | 0x21 198175 | 19 | 1 | 0x00 | 0x21 207845 | lead-out | 1 | 0x00 | 0x01 11:51:41 #12 Phase 36 File dlgbrnst.cpp, Line 1800 Rozpoczęto zapis z prędkością 32x (4 800 KB/s) 11:51:41 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 11:51:41 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #9867 11:51:41 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #19370 11:51:41 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #29703 11:51:41 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #42197 11:51:41 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #54057 11:51:41 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #63219 11:51:41 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #71552 11:51:41 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #83492 11:51:41 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #96490 11:51:41 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #105411 11:51:41 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #117173 11:51:41 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #129460 11:51:41 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #139882 11:51:41 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #150592 11:51:41 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #165590 11:51:41 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #179891 11:51:41 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #189368 11:51:41 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #198175 11:51:41 #32 Text 0 File Mmc.cpp, Line 14845 StartDAO : CD-Text - On 11:51:41 #33 Text 0 File Mmc.cpp, Line 19451 Set BUFE: BURN-Proof -> ON 11:51:41 #34 Text 0 File Mmc.cpp, Line 15134 CueData, Len=320 21 00 00 41 00 00 00 00 21 01 00 00 00 00 00 00 21 01 01 00 00 00 02 00 21 02 00 00 00 02 0b 2a 21 02 01 00 00 02 0d 2a 21 03 00 00 00 04 12 14 21 03 01 00 00 04 14 14 21 04 00 00 00 06 24 03 21 04 01 00 00 06 26 03 21 05 00 00 00 09 16 2f 21 05 01 00 00 09 18 2f 21 06 00 00 00 0c 00 39 21 06 01 00 00 0c 02 39 21 07 00 00 00 0e 02 45 21 07 01 00 00 0e 04 45 21 08 00 00 00 0f 36 02 21 08 01 00 00 0f 38 02 21 09 00 00 00 12 21 11 21 09 01 00 00 12 23 11 21 0a 00 00 00 15 1a 28 21 0a 01 00 00 15 1c 28 21 0b 00 00 00 17 19 24 21 0b 01 00 00 17 1b 24 21 0c 00 00 00 1a 02 17 21 0c 01 00 00 1a 04 17 21 0d 00 00 00 1c 2e 0a 21 0d 01 00 00 1c 30 0a 21 0e 00 00 00 1f 05 07 21 0e 01 00 00 1f 07 07 21 0f 00 00 00 21 1b 43 21 0f 01 00 00 21 1d 43 21 10 00 00 00 24 2f 41 21 10 01 00 00 24 31 41 21 11 00 00 00 27 3a 29 21 11 01 00 00 28 00 29 21 12 00 00 00 2a 04 44 21 12 01 00 00 2a 06 44 21 13 00 00 00 2c 02 19 21 13 01 00 00 2c 04 19 01 aa 01 01 00 2e 0d 14 11:52:40 #35 SCSI -1106 File Cdrdrv.cpp, Line 1431 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04ED0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0xFF 0xFF 0xCF 0x38 0x00 0x02 0xAA 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 11:52:40 #36 CDR -1106 File Writer.cpp, Line 301 Błąd kalibracji mocy! 11:52:40 #37 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 11:52:40 #38 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 11:52:40 #39 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 11:52:40 #40 Phase 38 File dlgbrnst.cpp, Line 1800 Zapis z prędkością 32x (4 800 KB/s) nie powiódł się! Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02 File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 11:02:00 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 2002-08-29 00:27:50 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 1 (Security Option) po restarcie kompa nagrywa spoko, czemu tak sie dzieje?dac ja do serwisu?
Pozdrawiam Zalo Ostatnio zmieniany przez Zalo : 20.03.2004 o godz. 13:03 |
Stary użytkownik
Data rejestracji: 09.06.2002
Weź zainstaluj nowe ASPI - ForceASPI 1,7 http://seba.wsm.wielun.pl/pliki.htm
Powiedz mi jeszcze, czy ten objaw pokazał się po wgraniu biosu? |
Author
jesli forceaspi nie pomoze to:
na moim teacu w58e tez tak bywalo, tak zaczol objawiac sie poczatek konca lasera - blad kalibracji, ale po odpoczynku napedu ( Twoj restar, z czasem ten czas potrzebny bedzie ulegal wydluzeniu, jesli to to o czym mysle) nagrywara dziala na dluzsza mete pomaga czyszczenie soczewki i palenie na nizszej predkosci, ale soro masz gwarancje to nie rozkrecaj napedu tylko idz z nim do serwisu |
Data rejestracji: 05.07.2002
Hmm ja tez mam ten sam problem
Objawia sie poprostu zwiechą nagrywania i po pewnym czasie wywala Błąd kalibracji mocy! Miałem bios 1.0B dzisiaj zrobiłem update do 1.0K i tak samo. Ne mówcie mi że nagrywarka mi padnie w przeciągu miesiąca !! Mam ja 1.5 roku i sposywała się wyśmienicie. A błąd kalibracji mocy zaczął wystepowac mi dopiero od 2 tygodni. ForceAspi tez nie pomogło Więc co teraz zrobić
Data rejestracji: 03.01.2003
Niestety Nimal ma rację. To jest początek końca lasera. Jeśli jest na gwarancji to zanieść do serwisu. Jeśli nie to można go przeczyścić. Jeśli czyszczenie nie pomoże to niestety niech spoczywa w spokoju R.I.P.
P.S. Czasami taki objaw pojawia się gdy napęd się przegrzewa lub jest za słaby zasilacz. |
- Czyściłem = nie pomogło
- Gwarancja się skończyła - Zasilacz serwerowy 350W Czy jest to możliwe że po 1.5 roku mogła paść takiej dobrej firmy nagrywarka ?? Cóż szkoda będzie trzeba wydac teraz troche pieniążków na nową. Polecilibyście coś ? Będe nagrywał max x16 x24 ale nagrywareczka musi miec wszystkie nowe technologie :zeby: Jest możę taka ? |
Data rejestracji: 15.01.2002
Lepszej nagrywary od TEAC-a już nie znajdziesz Kup jakieś combo albo nagrywarę DVD np. NEC
Stary użytkownik
Z Tikami jest takie coś. Jak wgrywasz bios do nich to musisz jeden po drugim, np. jak posiadasz bios XXX1, a chcesz wgrać XXX4 to musisz wgrać XXX2, potem XXX3 a na końcu XXX4. Jeżeli tak nie wykonasz to nagrywarka będzie źle wypalała krążki. Tego to ja nie wymyśliłem, tylko pobrałem z odpowiedneigo źródła.
