Stary 07.06.2005, 20:23   #1
marcinello
Data rejestracji: 07.06.2005
marcinello w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z LG GCE-8524B
witam
nie moge nagrac CD
oto log
CODE
tom
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 2005-03-09 18:14:30
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06
Nero version: 6.3.0.2
Recorder: <HL-DT-ST CD-RW GCE-8524B>Version: 1.00 - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST CD-RW GCE-8524B >Version: 1.00 - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : FUJITSU MPF3102AT atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8524B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.1b axvscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST CD-RW GCE-8524B D: CDRom0
AXV CD/DVD-ROM E: CDRom1
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 15728640 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 63MB (65008kB)
Free physical memory: 5MB (5768kB)
Memory in use : 91 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
7.6.2005
CD-ROM (ISO)
15:18:28 #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Write ISO9660;1 file extensions : TRUE
15:18:28 #2 Phase 90 File dlgbrnst.cpp, Line 1800
Buffer Underrun Protection activated
15:18:28 #3 Text 0 File Reader.cpp, Line 118
Reader running
15:18:28 #4 Text 0 File Writer.cpp, Line 124
Writer HL-DT-ST CD-RW GCE-8524B running
15:18:28 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
15:18:30 #6 Text 0 File Burncd.cpp, Line 3101
Turn on Track-at-once, using CD-R/RW media
15:18:30 #7 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 352674 ( 78:24.24)
15:18:30 #8 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
15:18:30 #9 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: HL-DT-ST CD-RW GCE-8524B;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
15:18:30 #10 Text 0 File DlgWaitCD.cpp, Line 406
15:18:30 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 352675 (352675) = #352675/78:22.25
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 352673 blocks [HL-DT-ST CD-RW GCE-8524B ]
15:18:30 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [HL-DT-ST CD-RW GCE-8524B ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 722585600, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
352675 | lead-out | 1 | 0x00 | 0x41
15:18:30 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994
Removed 2 run-out blocks from end of track 1. Length: 352675 -> 352673.
15:18:34 #14 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
15:18:35 #15 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
15:18:35 #16 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
15:18:35 #17 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 52x (7 800 KB/s)
15:18:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
15:18:35 #19 Text 0 File Mmc.cpp, Line 19451
Set BUFE: supported -> ON
15:19:09 #20 SCSI -1106 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04560000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
15:19:09 #21 CDR -1106 File Writer.cpp, Line 301
Power calibration error
15:19:09 #22 Text 0 File ThreadedTransfer.cpp, Line 229
15:19:10 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
15:19:10 #24 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
HL-DT-ST CD-RW GCE-8524B\H1 T0
15:19:10 #25 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
15:19:10 #26 Text 0 File Mmc.cpp, Line 14287
<HL-DT-STCD-RW GCE-8524B > start Close Session
15:19:10 #27 SCSI -1176 File Cdrdrv.cpp, Line 1171
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
15:19:10 #28 CDR -1176 File WriterStatus.cpp, Line 245
Session fixation error
15:19:10 #29 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
15:19:10 #30 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
15:19:10 #31 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
15:19:11 #32 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 52x (7 800 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 2005-03-09 18:14:30
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 21:51:54 (Adapter driver for rec)
Registry Keys:
dotychczas nagrywarka chodzila dobrze
prosze o pomoc
Ostatnio zmieniany przez Y@nkee_PL : 12.06.2005 o godz. 22:18
marcinello jest offline
Stary 08.06.2005, 00:13   #2
1. Wyedytuj seriala ze swojego loga bo ci sie dostanie od moderatorow.
2. Zmien plyty bo zdaje sie probujesz nagrywac na jakims szajsie od plasmona.
3. Nagrywaj w trybie DAO lub DAO/96.
4. Wyczysc optyke nagrywarki. Nie rozbieraj jej jesli jest jeszcze na gwarancji, najwyzej plyta czyszczaca (czego nie polecam).
Jesli nic z tych rzeczy nie pomoze, to raczej konczy sie nagrywara. Wiec serwis albo nowa.
grzeniu jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 13:10.
