Stary 21.06.2018, 04:03   #1
Plextor Premium 2 Refurbished -wymiana lasera
Powyższy egzemplarz miał już bardzo duże problemy z odczytem i zapisem . Do tego najcenniejsza wersja hardware i wykonania TLA0303 .. Trzeba było ratować.. i podać mu dłoń..
Demontujemy napęd i do dzieła ...
Stary 21.06.2018, 04:09   #2
Pierwszy test na wysypisku- Platinum CD-R od Plasmon
Platinum CD-R Plasmon 97m27s18f
Plextor Premium 2 Refurbished fw.1.03
ImgBurn 2.5.8.0 x8
Plextor Premium 2 Refurbished -wymiana lasera-magical-snap-2018.06.20-14.52-003.png
Plextor Premium 2 Refurbished -wymiana lasera-magical-snap-2018.06.20-14.31-001.png
Plextor Premium 2 Refurbished -wymiana lasera-magical-snap-2018.06.20-14.42-002.png
log z zapisu :
Kod:
I 13:43:01 ImgBurn Version 2.5.8.0 started!
I 13:43:01 Microsoft Windows 8 Professional x64 Edition (6.2, Build 9200)
I 13:43:01 Total Physical Memory: 4 189 108 KiB  -  Available: 898 452 KiB
I 13:43:01 Initialising ElbyCDIO...
I 13:43:01 ELBYCDIO.DLL - Elaborate Bytes CDRTools - ElbyCDIO DLL - Version 6.1.9.1
I 13:43:01 Searching for SCSI / ATAPI devices...
I 13:43:01 -> Drive 1 - Info: HL-DT-ST DVDRAM GT30N 1.01 (D:) (ATAPI)
I 13:43:01 -> Drive 2 - Info: PLEXTOR CD-R   PREMIUM2 1.03 (F:) (USB)
I 13:43:01 Found 1 CD-RW and 1 DVD***177;RW/RAM!
I 13:44:50 Operation Started!
I 13:44:50 Source File: E:\Pobieranie\MM\Daria.Zawialow.A.Kysz.2017\Daria Zawialow - A Kysz!\01 - Daria Zawialow - Malinowy Chrusniak.cue
I 13:44:50 Source File Sectors: 355 745 (AUDIO/2352)
I 13:44:50 Source File Size: 836 712 240 bytes
I 13:44:50 Source File File System(s): None
I 13:44:50 Destination Device: [0:0:0] PLEXTOR CD-R   PREMIUM2 1.03 (F:) (USB)
I 13:44:50 Destination Media Type: CD-R (Disc ID: 97m27s18f, Plasmon Data Systems)
I 13:44:50 Destination Media Sectors: 359 849
I 13:44:50 Write Mode: CD
I 13:44:50 Write Type: SAO
I 13:44:50 Write Speed: 8x
I 13:44:50 Lock Volume: Yes
I 13:44:50 Test Mode: No
I 13:44:50 OPC: Yes
I 13:44:50 BURN-Proof: Enabled
I 13:44:50 Write Speed Successfully Set! - Effective: 1 411 KB/s (8x)
I 13:44:50 Advanced Settings - PowerRec: Yes
I 13:45:00 Filling Buffer... (254 MiB)
I 13:45:15 Writing LeadIn...
I 13:45:35 Writing Session 1 of 1... (21 Tracks, LBA: 0 - 355744)
I 13:45:36 Writing Track 1 of 21... (AUDIO/2352, MP3, LBA: 0 - 19301)
I 13:46:04 Writing Track 2 of 21... (AUDIO/2352, MP3, LBA: 19302 - 34520)
I 13:46:30 Writing Track 3 of 21... (AUDIO/2352, MP3, LBA: 34521 - 53528)
I 13:47:01 Writing Track 4 of 21... (AUDIO/2352, MP3, LBA: 53529 - 68847)
I 13:47:27 Writing Track 5 of 21... (AUDIO/2352, MP3, LBA: 68848 - 85132)
I 13:47:54 Writing Track 6 of 21... (AUDIO/2352, MP3, LBA: 85133 - 100324)
I 13:48:19 Writing Track 7 of 21... (AUDIO/2352, MP3, LBA: 100325 - 119154)
I 13:48:51 Writing Track 8 of 21... (AUDIO/2352, MP3, LBA: 119155 - 138429)
I 13:49:23 Writing Track 9 of 21... (AUDIO/2352, MP3, LBA: 138430 - 155615)
I 13:49:51 Writing Track 10 of 21... (AUDIO/2352, MP3, LBA: 155616 - 170358)
I 13:50:16 Writing Track 11 of 21... (AUDIO/2352, MP3, LBA: 170359 - 185385)
I 13:50:41 Writing Track 12 of 21... (AUDIO/2352, MP3, LBA: 185386 - 204687)
I 13:51:13 Writing Track 13 of 21... (AUDIO/2352, MP3, LBA: 204688 - 219906)
I 13:51:39 Writing Track 14 of 21... (AUDIO/2352, MP3, LBA: 219907 - 238914)
I 13:52:10 Writing Track 15 of 21... (AUDIO/2352, MP3, LBA: 238915 - 254233)
I 13:52:36 Writing Track 16 of 21... (AUDIO/2352, MP3, LBA: 254234 - 270518)
I 13:53:03 Writing Track 17 of 21... (AUDIO/2352, MP3, LBA: 270519 - 285710)
I 13:53:28 Writing Track 18 of 21... (AUDIO/2352, MP3, LBA: 285711 - 304540)
I 13:54:00 Writing Track 19 of 21... (AUDIO/2352, MP3, LBA: 304541 - 323815)
I 13:54:32 Writing Track 20 of 21... (AUDIO/2352, MP3, LBA: 323816 - 341001)
I 13:55:00 Writing Track 21 of 21... (AUDIO/2352, MP3, LBA: 341002 - 355744)
I 13:55:25 Synchronising Cache...
I 13:55:40 Exporting Graph Data...
I 13:55:40 Graph Data File: C:\Users\czary2mary\AppData\Roaming\ImgBurn\Graph Data Files\PLEXTOR_CD-R_PREMIUM2_1.03_20-CZERWIEC-2018_13-44_97m27s18f_8x.ibg
I 13:55:40 Export Successfully Completed!
I 13:55:40 Operation Successfully Completed! - Duration: 00:10:50
I 13:55:40 Average Write Rate: 1 387 KiB/s (7.0x) - Maximum Write Rate: 1 402 KiB/s (7.1x)
Stary 22.02.2022, 13:21   #3
Następny tym razem TLA0101 przywrócony do życia
Primera ArchivDisc Plus CD-R Printable MID/ATIP : 97m15s05f (TDK/FalconMedia)
ImgBurn 2.5.8.0 x52
Stary 22.02.2022, 19:40   #4
SEBAW
Stary użytkownik
Avatar użytkownika SEBAW
Data rejestracji: 09.06.2002
Do obsługi napędów ATA używasz adaptera? Mam stare dyski ata, a przydałoby się je uruchomić.
Stary 23.02.2022, 09:48   #5
Napisany przez SEBAW Podgląd Wiadomości
Mam kilka Unitek ale zdecydowane starsze modele tego adaptera lepiej sobie radzą z obsługą interfejsu ATA / IDE w starszych konstrukcjach .
Najnowszy Unitek Y-3324 u mnie na przykład nie obsługuje Plextor PX-W1210A czy wczesnych wersji Plextor PX-712A
Stary 25.02.2022, 10:54   #6
seku
Avatar użytkownika seku
adaptery USB są lepsze i gorsze jedne działały tymi inne nie
SEBAW jeśli masz PC polecam kartę Marvell na PCIe ma 2x SATA6G + natywny kontroler IDE działa mi od lat WIn10 i obecnie Win11 zero problemów
Stary 25.02.2022, 19:36   #7
SEBAW
Stary użytkownik
@seku podaj oznaczenie karty oraz kontrolera, bo nie wiem które to sprzęty są.
Stary 25.02.2022, 21:15   #8
seku
mam taki od 2017r. czyli jak zmieniłem na Intela 7th bez natywnego IDE
Adapter IDE---&gt;SATA
Stary 07.02.2025, 19:42   #9
Stingray
Data rejestracji: 12.02.2024
Stingray w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
could you please advise is this (W37 from SONY CD-RW) laser appropriate for premium 2?
or I need exactly W37SGT0?
Stingray jest offline   Odpowiedz cytując ten post
Stary 19.02.2025, 16:46   #10
Napisany przez Stingray Podgląd Wiadomości
I think the newer version must be Sanyo SF-W37S
Stary 19.02.2025, 18:45   #11
Stingray
Thank you, it seems W37s donors are rare in my country, will order laser from aliexpress.
Stary 18.04.2025, 20:42   #12
Stingray
Maybe someone has unlocked firmware for Plextor Premium 2? (similar to unlocked FW for Plextor 755/760).
The author of QPXTOOL posted it earlier, but all the links don't work anymore. The firmware was called P2-fyp-v103.bin (fyp = free your plextor). There is a program PXFW for flashing in QPXTOOL package.
Stary 24.04.2025, 08:45   #13
If I remember correctly, this unlocked firmware for Premium 2 caused some problems with the drive. I don't have it.
Stary 01.05.2025, 15:57   #14
Stingray
I found it today. but not sure yet try or not
Opcje związane z dyskusją
Tryby wyświetlania
[FAQ] Yamaha CRW-F1 Refurbished -wymiana lasera czary2mary Napędy optyczne CD 9 14.08.2019 08:29
BenQ DW 1640 Refurbished \wymiana OPU Philipsa czary2mary Napędy optyczne DVD 2 28.01.2018 22:02
Plextor PX-712A Refurbished \wymiana OPU Sanyo czary2mary Napędy optyczne DVD 4 03.08.2017 06:41
Wymiana Lasera argonpl Hardware 4 09.02.2011 09:12
Wymiana lasera Kabat Napędy optyczne CD 4 15.02.2002 01:09
Wszystkie czasy w strefie CET. Aktualna godzina: 23:08.
