Stary 10.07.2016, 13:42   #1
Yamaha CRW4260t SCSI 1998r.
Skleiłem jakiegoś kompa dla swoich napędów SCSI \Windows 7 32bit+ kontroler PC-ESCSI Adaptec AHA2910 + stery dla chipsetu AIC 78xx ver. AIC 78u2 -Win 7 ver. 605457.
Więc tym razem dodany napęd SCSI z testem działania ....
Odczyt CD-ROM
Odczyt CD-R
Stary 10.07.2016, 13:45   #2
Zapis x1
log z zapisu
Kod:
9040-0198-Z5EU-U5M9-5422-WC24-****-****
Windows 7 6.1
IA32
Nero Version: 15.0.19.0
Internal Version: 15,0,19,0
Recorder         : <YAMAHA CRW4260>               FW version: 1.0g - HA 1 TA 3 - 15.0.19.0
 Device bus      :  <>                            HA 1
 Host system bus :  <SCSI>
 Drive buffer    :  2048kB
 Bus Type        :  via Inquiry data
CD/DVD-ROM       : <PLEXTOR  DVDR   PX-890SA >    FW version: 1.00 - HA 1 TA 1 - 15.0.19.0
 Host system bus :  <IDE>
=== Scsi-Device-Map ===
CdRomPeripheral      : YAMAHA  CRW4260         1.0g   aic78xx Port 4 ID 1  DMA: Off
=== CDRom-Device-Map ===
PLEXTOR DVDR   PX-890SA    H:   CdRom1
YAMAHA CRW4260             G:   CdRom3
AutoRun : 1
Excluded drive IDs:
BUFE           : 0
Physical memory     : 2047MB (2097151kB)
Free physical memory: 1188MB (1216728kB)
Memory in use       : 59 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
10.7.2016
Audio CD
10:22:04	#1 Text 0 File SCSIPTICommands.cpp, Line 617
10:22:04	#2 CDADOC -1 File Cdadoc.cpp, Line 1739
	Audio item log info:
	Audio document burn settings:
	Burn mode: DAO,
	CD Text: On,
	Cache disk or network files: No,
	Cache small files: No,
	Cache files smaller than 65536 bytes.
	Audio Multisession: No
	List of audio tracks:
	Track 01: Length: 03:27.63, Pause frames: 150, Filters: 0, Name: '01 - Slow Motion.flac'.
	Track 02: Length: 04:16.63, Pause frames: 150, Filters: 0, Name: '02 - I Can't Stay Long.flac'.
	Track 03: Length: 04:26.62, Pause frames: 150, Filters: 0, Name: '03 - Someone Else's Clothes.flac'.
	Track 04: Length: 03:09.16, Pause frames: 150, Filters: 0, Name: '04 - Blue Light.flac'.
	Track 05: Length: 02:28.57, Pause frames: 150, Filters: 0, Name: '05 - Some Of Them.flac'.
	Track 06: Length: 04:11.19, Pause frames: 150, Filters: 0, Name: '06 - Quiet Men.flac'.
	Track 07: Length: 02:55.63, Pause frames: 150, Filters: 0, Name: '07 - Dislocation.flac'.
	Track 08: Length: 03:53.03, Pause frames: 150, Filters: 0, Name: '08 - Maximum Acceleration.flac'.
	Track 09: Length: 04:15.45, Pause frames: 150, Filters: 0, Name: '09 - When You Walk Through Me.flac'.
	Track 10: Length: 03:11.70, Pause frames: 150, Filters: 0, Name: '10 - Just For A Moment.flac'.
	Track 11: Length: 03:28.18, Pause frames: 150, Filters: 0, Name: '01. Throw Down the Roses.flac'.
	Track 12: Length: 03:08.48, Pause frames: 150, Filters: 0, Name: '02. Mister Sister.flac'.
	Track 13: Length: 04:24.16, Pause frames: 150, Filters: 0, Name: '03. Guitars and Microphones.flac'.
	Track 14: Length: 03:19.67, Pause frames: 150, Filters: 0, Name: '04. Crush Me With Your Love.flac'.
	Track 15: Length: 02:38.09, Pause frames: 150, Filters: 0, Name: '05. Bottoms Up.flac'.
	Track 16: Length: 03:54.66, Pause frames: 150, Filters: 0, Name: '06. Bring Your Arms.flac'.
	Track 17: Length: 04:25.18, Pause frames: 150, Filters: 0, Name: '07. Wolves.flac'.
	Track 18: Length: 04:36.45, Pause frames: 150, Filters: 0, Name: '08. Matrix.flac'.
	Track 19: Length: 03:23.51, Pause frames: 150, Filters: 0, Name: '09. Time Wave Zero.flac'.
	Track 20: Length: 03:24.19, Pause frames: 150, Filters: 0, Name: '10. Pulls You Under.flac'.
	Total size: 73:40.68
10:22:05	#3 Text 0 File AudioCompilationImpl.cpp, Line 838
	DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
	DRM: Beginning burn process.
10:22:05	#4 PHASE 214 File dlgbrnst.cpp, Line 2066
	Generation of disc structures started
10:22:05	#5 PHASE 215 File dlgbrnst.cpp, Line 2066
	Generation of disc structures completed
10:22:05	#6 Text 0 File Burncd.cpp, Line 3634
	Turn on Disc-At-Once, using CD-R/RW media
10:22:09	#7 Text 0 File DlgWaitCD.cpp, Line 334
	[G: CRW4260         ] Last possible write address on media:   359842
	Last address to be written:             331417
10:22:09	#8 Text 0 File DlgWaitCD.cpp, Line 346
	[G: CRW4260         ] Write in overburning mode: NO (enabled: CD)
10:22:10	#9 Text 0 File DlgWaitCD.cpp, Line 3034
	Recorder: YAMAHA CRW4260;
	   CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
	   ATIP Data:
	     Special    Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70)
	     Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
10:22:10	#10 Text 0 File DlgWaitCD.cpp, Line 537
	[G: CRW4260         ] >>> Protocol of DlgWaitCD activities: <<<
10:22:10	#11 Text 0 File ThreadedTransferInterface.cpp, Line 879
	 0: TRM_AUDIO_NOPRE (01 - Slow Motion.flac)
	    original disc pos #0 + 15588 (15588) = #15588/3:27.63
	    relocatable, disc pos for caching/writing not required/not required
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15588 blocks [G: YAMAHA CRW4260]
	 1: TRM_AUDIO_NOPRE (02 - I Can't Stay Long.flac)
	    original disc pos #0 + 19263 (19263) = #19263/4:16.63
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19263 blocks [G: YAMAHA CRW4260]
	 2: TRM_AUDIO_NOPRE (03 - Someone Else's Clothes.flac)
	    original disc pos #0 + 20012 (20012) = #20012/4:26.62
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20012 blocks [G: YAMAHA CRW4260]
	 3: TRM_AUDIO_NOPRE (04 - Blue Light.flac)
	    original disc pos #0 + 14191 (14191) = #14191/3:9.16
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14191 blocks [G: YAMAHA CRW4260]
	 4: TRM_AUDIO_NOPRE (05 - Some Of Them.flac)
	    original disc pos #0 + 11157 (11157) = #11157/2:28.57
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11157 blocks [G: YAMAHA CRW4260]
	 5: TRM_AUDIO_NOPRE (06 - Quiet Men.flac)
	    original disc pos #0 + 18844 (18844) = #18844/4:11.19
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18844 blocks [G: YAMAHA CRW4260]
	 6: TRM_AUDIO_NOPRE (07 - Dislocation.flac)
	    original disc pos #0 + 13188 (13188) = #13188/2:55.63
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13188 blocks [G: YAMAHA CRW4260]
	 7: TRM_AUDIO_NOPRE (08 - Maximum Acceleration.flac)
	    original disc pos #0 + 17478 (17478) = #17478/3:53.3
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17478 blocks [G: YAMAHA CRW4260]
	 8: TRM_AUDIO_NOPRE (09 - When You Walk Through Me.flac)
	    original disc pos #0 + 19170 (19170) = #19170/4:15.45
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19170 blocks [G: YAMAHA CRW4260]
	 9: TRM_AUDIO_NOPRE (10 - Just For A Moment.flac)
	    original disc pos #0 + 14395 (14395) = #14395/3:11.70
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14395 blocks [G: YAMAHA CRW4260]
	10: TRM_AUDIO_NOPRE (01. Throw Down the Roses.flac)
	    original disc pos #0 + 15618 (15618) = #15618/3:28.18
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15618 blocks [G: YAMAHA CRW4260]
	11: TRM_AUDIO_NOPRE (02. Mister Sister.flac)
	    original disc pos #0 + 14148 (14148) = #14148/3:8.48
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14148 blocks [G: YAMAHA CRW4260]
	12: TRM_AUDIO_NOPRE (03. Guitars and Microphones.flac)
	    original disc pos #0 + 19816 (19816) = #19816/4:24.16
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19816 blocks [G: YAMAHA CRW4260]
	13: TRM_AUDIO_NOPRE (04. Crush Me With Your Love.flac)
	    original disc pos #0 + 14992 (14992) = #14992/3:19.67
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14992 blocks [G: YAMAHA CRW4260]
	14: TRM_AUDIO_NOPRE (05. Bottoms Up.flac)
	    original disc pos #0 + 11859 (11859) = #11859/2:38.9
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11859 blocks [G: YAMAHA CRW4260]
	15: TRM_AUDIO_NOPRE (06. Bring Your Arms.flac)
	    original disc pos #0 + 17616 (17616) = #17616/3:54.66
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17616 blocks [G: YAMAHA CRW4260]
	16: TRM_AUDIO_NOPRE (07. Wolves.flac)
	    original disc pos #0 + 19893 (19893) = #19893/4:25.18
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19893 blocks [G: YAMAHA CRW4260]
	17: TRM_AUDIO_NOPRE (08. Matrix.flac)
	    original disc pos #0 + 20745 (20745) = #20745/4:36.45
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20745 blocks [G: YAMAHA CRW4260]
	18: TRM_AUDIO_NOPRE (09. Time Wave Zero.flac)
	    original disc pos #0 + 15276 (15276) = #15276/3:23.51
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15276 blocks [G: YAMAHA CRW4260]
	19: TRM_AUDIO_NOPRE (10. Pulls You Under.flac)
	    original disc pos #0 + 15319 (15319) = #15319/3:24.19
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15319 blocks [G: YAMAHA CRW4260]
10:22:10	#12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
	Prepare [G: YAMAHA CRW4260] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: "             "
	 Tracks 1 to 20:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800      37015776, ISRC ""
	   2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      37015776      37368576      82675152, ISRC ""
	   3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      82675152      83027952     130096176, ISRC ""
	   4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     130096176     130448976     163826208, ISRC ""
	   5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     163826208     164179008     190420272, ISRC ""
	   6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     190420272     190773072     235094160, ISRC ""
	   7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     235094160     235446960     266465136, ISRC ""
	   8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     266465136     266817936     307926192, ISRC ""
	   9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     307926192     308278992     353366832, ISRC ""
	  10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     353366832     353719632     387576672, ISRC ""
	  11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     387576672     387929472     424663008, ISRC ""
	  12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     424663008     425015808     458291904, ISRC ""
	  13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     458291904     458644704     505251936, ISRC ""
	  14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     505251936     505604736     540865920, ISRC ""
	  15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     540865920     541218720     569111088, ISRC ""
	  16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     569111088     569463888     610896720, ISRC ""
	  17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     610896720     611249520     658037856, ISRC ""
	  18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     658037856     658390656     707182896, ISRC ""
	  19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     707182896     707535696     743464848, ISRC ""
	  20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     743464848     743817648     779847936, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	     -150 |  lead-in |   0 |    0x01 |        0 |        0 | 0x00
	     -150 |        1 |   0 |    0x21 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x21 |    15588 |        0 | 0x00
	    15588 |        2 |   0 |    0x21 |        0 |        0 | 0x00
	    15738 |        2 |   1 |    0x21 |    19263 |    15738 | 0x00
	    35001 |        3 |   0 |    0x21 |        0 |        0 | 0x00
	    35151 |        3 |   1 |    0x21 |    20012 |    35151 | 0x00
	    55163 |        4 |   0 |    0x21 |        0 |        0 | 0x00
	    55313 |        4 |   1 |    0x21 |    14191 |    55313 | 0x00
	    69504 |        5 |   0 |    0x21 |        0 |        0 | 0x00
	    69654 |        5 |   1 |    0x21 |    11157 |    69654 | 0x00
	    80811 |        6 |   0 |    0x21 |        0 |        0 | 0x00
	    80961 |        6 |   1 |    0x21 |    18844 |    80961 | 0x00
	    99805 |        7 |   0 |    0x21 |        0 |        0 | 0x00
	    99955 |        7 |   1 |    0x21 |    13188 |    99955 | 0x00
	   113143 |        8 |   0 |    0x21 |        0 |        0 | 0x00
	   113293 |        8 |   1 |    0x21 |    17478 |   113293 | 0x00
	   130771 |        9 |   0 |    0x21 |        0 |        0 | 0x00
	   130921 |        9 |   1 |    0x21 |    19170 |   130921 | 0x00
	   150091 |       10 |   0 |    0x21 |        0 |        0 | 0x00
	   150241 |       10 |   1 |    0x21 |    14395 |   150241 | 0x00
	   164636 |       11 |   0 |    0x21 |        0 |        0 | 0x00
	   164786 |       11 |   1 |    0x21 |    15618 |   164786 | 0x00
	   180404 |       12 |   0 |    0x21 |        0 |        0 | 0x00
	   180554 |       12 |   1 |    0x21 |    14148 |   180554 | 0x00
	   194702 |       13 |   0 |    0x21 |        0 |        0 | 0x00
	   194852 |       13 |   1 |    0x21 |    19816 |   194852 | 0x00
	   214668 |       14 |   0 |    0x21 |        0 |        0 | 0x00
	   214818 |       14 |   1 |    0x21 |    14992 |   214818 | 0x00
	   229810 |       15 |   0 |    0x21 |        0 |        0 | 0x00
	   229960 |       15 |   1 |    0x21 |    11859 |   229960 | 0x00
	   241819 |       16 |   0 |    0x21 |        0 |        0 | 0x00
	   241969 |       16 |   1 |    0x21 |    17616 |   241969 | 0x00
	   259585 |       17 |   0 |    0x21 |        0 |        0 | 0x00
	   259735 |       17 |   1 |    0x21 |    19893 |   259735 | 0x00
	   279628 |       18 |   0 |    0x21 |        0 |        0 | 0x00
	   279778 |       18 |   1 |    0x21 |    20745 |   279778 | 0x00
	   300523 |       19 |   0 |    0x21 |        0 |        0 | 0x00
	   300673 |       19 |   1 |    0x21 |    15276 |   300673 | 0x00
	   315949 |       20 |   0 |    0x21 |        0 |        0 | 0x00
	   316099 |       20 |   1 |    0x21 |    15319 |   316099 | 0x00
	   331418 | lead-out |   1 |    0x01 |        0 |        0 | 0x00
	MediaType: CD-R
10:22:10	#13 Text 0 File SCSIPTICommands.cpp, Line 404
10:22:10	#14 Text 0 File Burncd.cpp, Line 4504
	Caching options: cache CDRom or Network-No, small files-No (<64KB)
10:22:10	#15 PHASE 36 File dlgbrnst.cpp, Line 2066
	Burn process started at 1x (150 KB/s)
10:22:10	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:22:10	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #15738
10:22:10	#18 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #35151
10:22:10	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #55313
10:22:10	#20 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #69654
10:22:10	#21 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #80961
10:22:10	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #99955
10:22:10	#23 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #113293
10:22:10	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #130921
10:22:10	#25 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #150241
10:22:10	#26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #164786
10:22:10	#27 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #180554
10:22:10	#28 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #194852
10:22:10	#29 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #214818
10:22:10	#30 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #229960
10:22:10	#31 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #241969
10:22:10	#32 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #259735
10:22:10	#33 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #279778
10:22:10	#34 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #300673
10:22:10	#35 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 19 (relocatable, no disc pos, no patch infos, orig at #0): write at #316099
10:22:10	#36 Text 0 File Mmc.cpp, Line 17654
	StartDAO : CD-Text - Off
10:22:10	#37 Text 0 File Mmc.cpp, Line 17882
	CueData, Len=336
	21 00 00 01 00 00 00 00
	21 01 00 00 00 00 00 00
	21 01 01 00 00 00 02 00
	21 02 00 00 00 03 1d 3f
	21 02 01 00 00 03 1f 3f
	21 03 00 00 00 07 30 33
	21 03 01 00 00 07 32 33
	21 04 00 00 00 0c 11 26
	21 04 01 00 00 0c 13 26
	21 05 00 00 00 0f 1c 36
	21 05 01 00 00 0f 1e 36
	21 06 00 00 00 11 3b 24
	21 06 01 00 00 12 01 24
	21 07 00 00 00 16 0c 37
	21 07 01 00 00 16 0e 37
	21 08 00 00 00 19 0a 2b
	21 08 01 00 00 19 0c 2b
	21 09 00 00 00 1d 05 2e
	21 09 01 00 00 1d 07 2e
	21 0a 00 00 00 21 17 10
	21 0a 01 00 00 21 19 10
	21 0b 00 00 00 24 25 0b
	21 0b 01 00 00 24 27 0b
	21 0c 00 00 00 28 07 1d
	21 0c 01 00 00 28 09 1d
	21 0d 00 00 00 2b 12 02
	21 0d 01 00 00 2b 14 02
	21 0e 00 00 00 2f 2c 12
	21 0e 01 00 00 2f 2e 12
	21 0f 00 00 00 33 06 0a
	21 0f 01 00 00 33 08 0a
	21 10 00 00 00 35 2e 13
	21 10 01 00 00 35 30 13
	21 11 00 00 00 39 2b 0a
	21 11 01 00 00 39 2d 0a
	21 12 00 00 00 3e 0a 1c
	21 12 01 00 00 3e 0c 1c
	21 13 00 00 00 42 30 49
	21 13 01 00 00 42 32 49
	21 14 00 00 00 46 0e 31
	21 14 01 00 00 46 10 31
	01 aa 01 01 00 49 28 44
10:22:10	#38 Text 0 File ThreadedTransfer.cpp, Line 275
	Pipe memory size 83836800
11:38:47	#39 Text 0 File WriterStatus.cpp, Line 245
	<G: YAMAHA CRW4260> start writing Lead-Out at LBA 331418 (50E9Ah), length 0 blocks
11:40:24	#40 PHASE 37 File dlgbrnst.cpp, Line 2066
	Burn process completed successfully at 1x (150 KB/s)
11:40:24	#41 Text 0 File AudioCompilationImpl.cpp, Line 863
	DRM: DRM burn session terminated.
11:40:24	#42 Text 0 File AudioCompilationImpl.cpp, Line 892
	DRM: Closing entire DRM handling. Bye.
11:40:24	#43 Text 0 File SCSIPTICommands.cpp, Line 454
11:40:24	#44 Text 0 File Cdrdrv.cpp, Line 12266
11:40:24	#45 Text 0 File SCSIPTICommands.cpp, Line 617
Stary 10.07.2016, 13:50   #3
Yamaha CRW4260t SCSI 1998r. fw.1.0g
Maxell Music XL-II 80 AudioCD-R Ritek MID:97m15s17f Made in China
NERO 2014 x1
Jak widać dla niektórych nowszych napędów problemem jest taki wolny zapis i mają problem z odczytem tak zapisanej płyty...
Ostatnio zmieniany przez czary2mary : 10.07.2016 o godz. 13:58
Stary 10.07.2016, 14:14   #4
Leman39
Avatar użytkownika Leman39
Data rejestracji: 21.02.2014
Jak oceniasz wypał, bo moim zdaniem kurcze, słabo
Stary 10.07.2016, 14:58   #5
Dobrze jest... spójrz na test PX-760A \beta\jitter............beta prawie zero odchyłów \ jitter momentami w okolicy ~~5%....
Gdyby BenQ testował x1 było by dobrze...
Stary 10.07.2016, 22:57   #6
seku
Avatar użytkownika seku
ogólnie podziwiam :-)
Stary 11.07.2016, 11:54   #7
Leman39
No ja mam niemały problem z interpretacją tych wyników, przyznaję
Narobiłeś mi ochoty na yamahę, ciekawe jak poradzi sobie z AZO. Audio CD Verbatima chyba też mają podłoże AZO (coś, jak kiedyś seria Color CD-R).
Oby więcej takich sprzętów
Stary 11.07.2016, 14:00   #8
Trudno powiedzieć jak sobie poradzi z nowymi innymi nośnikami..... Z Ritek CD-R poradziła sobie dobrze ...jedyne dostepne przekładnie zapisu to x1 , x2 , x4 ....
Maksymalny odczyt x6 .....
Trzeba pamiętać że sprzęt soft ma z 1998r , czyli strategie dla nośników CD-R x1-4 , jest trochę nowszy firmware 1.0q ale żeby zaktualizować sprzęt to trzeba kilka dyskietek napisać i pod DOS-em walczyć ....też trzeba zapomnieć o aktualizacji sprzętu na kontrolerze PC-E SCSI .....
To cud że rozpoznaje nowe nośniki i nagrywa....
Stary 11.07.2016, 20:04   #9
Leman39
Model F1E można za 100 PLN z hakiem w PL wyciągnąć, ale wyłącznie z sentymentu
Mi się strasznie podobają wizualnie te Yamahy - surowe takie, japońskie
Stary 11.07.2016, 21:06   #10
CRW F1 to inna bajka \ interfejs IDE\USB + soft z 2003r + wsparcie dla wszystkich nośników x48\52..... to jeden z najbardziej zaawansowanych technologicznie i techniczne napędów CD-RW............
Stary 26.07.2016, 22:32   #11
Tym razem trochę późniejszy egzemplarz z sierpnia 1998r.. na przeglądzie ...zwraca uwagę jeszcze bardzo duża soczewka lasera oraz trzy chipy sterujące Yamaha .....
Stary 26.07.2016, 23:46   #12
seku
jak zawsze wilki szacunek :-)
nagrywarki CD sobie odpuszczam w zbiorach
ale za to w tym tyg. zdobyłem ASUSA 24B3ST od pierwszego właściciela :-) przebieg znikomy zobaczymy ile płyt wypalił ;-) za 60zł z wysyłką
Stary 27.07.2016, 16:47   #13
Leman39
Skąd Wy to Panowie bierzecie? :-)
U mnie póki co na stanie przeważnie szrot..
Stary 28.07.2016, 05:55   #14
Z kufra ze skarbami...
Stary 28.07.2016, 14:01   #15
Ͼ Ͽ
Forum ZielonaIrlandia.
Problem z nagrywaniem CD-R 48x na Yamaha 6416 SCSI a2fm Napędy optyczne CD 0 16.07.2003 08:40
YAMAHA F1 - SCSI vs IDE ?? fido2001 Napędy optyczne CD 25 30.01.2003 01:16
Yamaha 8/4/24 SCSI i problem z nagrywaniem x8 qba Napędy optyczne CD 1 07.04.2002 23:51
YAMAHA 2100 E i SCSI tomek23 Napędy optyczne CD 0 25.03.2002 16:09
Jak wlaczyc dma w yamaha 2100s scsi ? (pilne) Goro Napędy optyczne CD 0 21.10.2001 14:14
Wszystkie czasy w strefie CET. Aktualna godzina: 15:31.
