Stary 08.12.2003, 16:00   #1
haste
Data rejestracji: 08.12.2003
haste w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z LiteON
Witam...zobaczcie tan log z Nera i jak wiecie o co chodzi to bede wdzieczny.
Niszczy mi tylko plyty bo po probie wypalenia plyta jest do d***...Tak samo jest pod linuxem...
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 1999-05-05 22:22:00
Nero Version: 5.5.9.24
Recorder: <LITE-ON LTR-48246S> Version: SS0E - HA 0 TA 1 - 5.5.9.24
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <LITE-ON LTR-48246S> Version: SS0E - HA 0 TA 1 - 5.5.9.24
LITE-ON LTR-48246S (Target 1, G: Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 20971520 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130500kB)
Free physical memory: 2MB (2660kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
8.12.2003
CD-ROM (ISO)
12:42:59 #1 Text 0 File Isodoc.cpp, Line 7328
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
12:42:59 #2 Phase 90 File dlgbrnst.cpp, Line 1574
Buffer Underrun Protection activated
12:42:59 #3 Text 0 File Reader.cpp, Line 115
Reader running
12:42:59 #4 Text 0 File Writer.cpp, Line 123
Writer LITE-ON LTR-48246S running
12:42:59 #5 ISO9660GEN -11 File geniso.cpp, Line 4519
12:42:59 #6 Text 0 File Burncd.cpp, Line 3604
Turn on Track-At-Once, using CD-R/RW media
12:42:59 #7 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
original CD pos #0 + 339438 (339438) = #339438/75:25.63
relocatable, CD pos for caching/writing not required/required, no patch infos
12:43:24 #8 Text 0 File DlgWaitCD.cpp, Line 202
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 339437 (75:27.62)
12:43:24 #9 Text 0 File DlgWaitCD.cpp, Line 207
Write in overburning mode: FALSE
12:43:24 #10 Text 0 File DlgWaitCD.cpp, Line 1419
Recorder: LITE-ON LTR-48246S;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
12:43:25 #11 Text 0 File ThreadedTransferInterface.cpp, Line 811
Prepare recorder LITE-ON LTR-48246S for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 695476224
12:43:25 #12 Text 0 File ThreadedTransferInterface.cpp, Line 839
Removed 2 run-out blocks from end of track 1.
12:43:25 #13 Text 0 File ThreadedTransferInterface.cpp, Line 659
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 339436 blocks [LITE-ON LTR-48246S ]
12:43:25 #14 Phase 24 File dlgbrnst.cpp, Line 1574
Caching of files started
12:43:25 #15 Phase 25 File dlgbrnst.cpp, Line 1574
Caching of files completed
12:43:25 #16 Phase 36 File dlgbrnst.cpp, Line 1574
Burn process started at 48x (7*200 KB/s)
12:43:25 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1952
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
12:43:25 #18 Text 0 File Mmc.cpp, Line 17129
Set BUFE: supported -> ON , SMART-BURN : ON
12:43:55 #19 SCSI -1135 File Cdrdrv.cpp, Line 1393
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02490000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x01 0xF0 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
12:43:55 #20 MMC -1135 File Writer.cpp, Line 331
Write error
12:43:55 #21 Text 0 File ThreadedTransfer.cpp, Line 219
12:43:55 #22 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
12:43:55 #23 CDR -201 File WriterStatus.cpp, Line 194
Invalid write state
12:43:55 #24 TRANSFER -18 File WriterStatus.cpp, Line 194
Could not perform EndTrack
12:43:55 #25 Text 0 File Mmc.cpp, Line 12011
<LITE-ON LTR-48246S > start Close Session
12:44:30 #26 Phase 39 File dlgbrnst.cpp, Line 1574
Burn process aborted
12:44:30 #27 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
haste jest offline
Stary 08.12.2003, 16:08   #2
SEBAW
Stary użytkownik
Avatar użytkownika SEBAW
Data rejestracji: 09.06.2002
Weż uaktualnij nero do wersji 5.5.10.54 i odinstaluj stare (ajk instalowałeś) ASPI i wgraj ponownie ASPI Adapteca + fixaspi lub ForceASPI.
SEBAW jest offline
Stary 08.12.2003, 18:39   #3
nimal
Author
Avatar użytkownika nimal
Data rejestracji: 29.03.2003
opisz jak to sie zaczelo i kiedy
nimal jest offline
Stary 08.12.2003, 18:44   #4
haste
Napisany przez SEBAw
Nie dziala dalej...nawet plyt RW nie chce kawoac tylko wawala erase field
..Jedna nagral do 270MB i wawalil Write Field
haste jest offline
Stary 08.12.2003, 18:51   #5
haste
Napisany przez nimal
Chm....Juz dawno plyt nie wypalalem i dokladnie niepamietam ale problemy zaczely sie pod linuxem...niedomykal plyt pod windowsem bylo podobnie (MMORE)...Od tamtego czasu nie wypalalem plyt az do dzis...Jak pod linuxem wypalalem to niby to wypalilo ale plyta byla nieruszona poza 1MB...Pod windowsem podobnie...Raz wypalilo na RW 270MB ale plyty juz sie nie dalo wyczyscic...A CD-R to juz nawet nie zaczynaly sie wypalac poza fatalnym 1MB i nie mozna juz nic z ta plyta zrobic...Jakies 3-mce temu naped rozwalil mi plyte - jednak sobie go wyczyscilem i bylo wszystko oki. i dlatego watpie zeby to byla wina tego zdarzenia...CHyba bedzie trzeba kupic nowy naped...ten zostawie jako CD-ROM....
haste jest offline
Stary 08.12.2003, 19:32   #6
nimal
Author
hmm - sprawdz jeszcze na innym kompie
wyeliminujesz w ten sposob szkodzenie kabelka/kontrolera
i chyba nowa spawarka Cie czeka - nie ma tego zlego co by na dobre nie wyszlo
nimal jest offline
Stary 08.12.2003, 19:33   #7
Bartez
Team Member
Avatar użytkownika Bartez
Data rejestracji: 18.10.2002
usun kontroler na ktorym masz nagrywarke,
wywal aspi, wgraj na nowo,
zaktualizuj nero
poczytaj forum...
Bartez
Ranking dysków twardych
Bartez jest offline
Stary 15.12.2003, 05:57   #8
haste
PO wielu probach i testach u dalo mi sie odpalic wypalanie na predkosci 8x...Niby wypalanie przebega OK ale na samym koncu przy zamykaniu sesji wyskauje mi cos takiego:
22:38:36 #26 MMC -1135 File ThreadedTransferInterface.cpp, Line 1561
Write error
22:38:36 #27 TRANSFER -18 File ThreadedTransferInterface.cpp, Line 1561
22:38:36 #28 Text 0 File Mmc.cpp, Line 12011
22:39:11 #29 Phase 38 File dlgbrnst.cpp, Line 1574
Burn process failed at 8x (1*200 KB/s)
22:39:11 #30 Text 0 File Scsicmd.cpp, Line 406
.....Moze na to jest jakis problem bo to wczesniejsze to chyba rzeczywisce jest laser nadajacy sie do kalibracji ale blad przy zamykaniu sesji to tez wina rozregulowanego laser-u
haste jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 08:58.
