Stary 08.09.2003, 14:57   #1
piterrr
Data rejestracji: 08.09.2003
piterrr w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Angry problem z LG - 8160B
Od pewnego czasu mam problem z LG - 8160B.A mianowiceie podczas nagrywania proces ten dochodzi do ok 98% i wyskakuje WRITE ERROR !!.
Bardzo prosze o pomoc. Dodam ze wszesniej nagrywalem ok. 1,5 roku i wszystko bylo OK. Ponizej zamieszczam Log. zapisany po nagraniu plyty.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-01-29 22:37:36
Nero Version: 5.5.10.28
Recorder: <HL-DT-ST CD-RW GCE-8160B>Version: 1.02 - HA 1 TA 0 - 5.5.10.28
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <LG CD-ROM CRD-8521B>Version: 1.04 - HA 0 TA 1 - 5.5.10.28
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
DiskPeripheral : ST380021A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LG CD-ROM CRD-8521B atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : HL-DT-ST CD-RW GCE-8160B atapi Port 1 ID 0 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 159MB (163660kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
8.9.2003
CD-ROM (ISO)
13:46:21 #1 Text 0 File Isodoc.cpp, Line 7579
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
13:46:21 #2 Phase 90 File dlgbrnst.cpp, Line 1655
Buffer Underrun Protection activated
13:46:21 #3 Text 0 File Reader.cpp, Line 115
Reader running
13:46:21 #4 Text 0 File Writer.cpp, Line 125
Writer HL-DT-ST CD-RW GCE-8160B running
13:46:21 #5 ISO9660GEN -11 File geniso.cpp, Line 4571
13:46:21 #6 Text 0 File Burncd.cpp, Line 3735
Turn on Disc-At-Once, using CD-R/RW media
13:46:21 #7 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
original CD pos #0 + 358960 (358960) = #358960/79:46.10
relocatable, CD pos for caching/writing not required/required, no patch infos
13:46:21 #8 Text 0 File DlgWaitCD.cpp, Line 221
Last possible write address on media: 359847 (79:59.72)
Last address to be written: 358959 (79:48.09)
13:46:21 #9 Text 0 File DlgWaitCD.cpp, Line 226
Write in overburning mode: FALSE
13:46:21 #10 Text 0 File DlgWaitCD.cpp, Line 1678
Recorder: HL-DT-ST CD-RW GCE-8160B;
CDR code: 00 97 27 06; OSJ entry from: DIGITAL STORAGE TECHNOLOGY CO.,LTD
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 06 (LI 97:27.06), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
13:46:21 #11 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder HL-DT-ST CD-RW GCE-8160B for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 735457280
13:46:21 #12 Text 0 File ThreadedTransferInterface.cpp, Line 672
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358960 blocks [HL-DT-ST CD-RW GCE-8160B ]
13:46:21 #13 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
13:46:22 #14 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
13:46:22 #15 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 12x (1_800 KB/s)
13:46:22 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
13:46:22 #17 Text 0 File Mmc.cpp, Line 13410
StartDAO : CD-Text - Off
13:46:22 #18 Text 0 File Mmc.cpp, Line 17895
Set BUFE: supported -> ON
13:46:22 #19 Text 0 File Mmc.cpp, Line 13668
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 4f 30 0a
13:52:49 #20 SCSI -1135 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02410000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x05 0x07 0x97 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
13:52:49 #21 MMC -1135 File Writer.cpp, Line 333
Write error
13:52:49 #22 Text 0 File ThreadedTransfer.cpp, Line 222
13:52:54 #23 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
13:52:55 #24 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 12x (1_800 KB/s)
13:52:55 #25 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 21:51:54 (Adapter driver for rec)
Registry Keys:
piterrr jest offline
Stary 08.09.2003, 15:45   #2
SEBAW
Stary użytkownik
Avatar użytkownika SEBAW
Data rejestracji: 09.06.2002
Może masz coś nie tak z ASPI, bądź też zabrudzoną optykę patrząc, że ta nagrywarka ma 1,5 roku.
Może wystarczy wgrać stery VIA, jeśli twoja płyta główna jest na tym czipsecie wykonana.
SEBAW jest offline
Stary 08.09.2003, 21:44   #3
SEBAwl napisa***322;(a)
a sie przyznam, ze na nowym systemie jeszcze nie instalowalem ani via ani aspi i nagrywarka pali.
Mi tez czasem ten error wyskakuje ale to ok co 80 plytka
Patrix jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 18:33.
