Data rejestracji: 07.06.2005
Problem z LG GCE-8524B
witam
nie moge nagrac CD oto log CODE tom ... Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 2005-03-09 18:14:30 ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06 Nero version: 6.3.0.2 Recorder: <HL-DT-ST CD-RW GCE-8524B>Version: 1.00 - HA 1 TA 0 - 6.3.0.2 Adapter driver: <atapi> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <HL-DT-ST CD-RW GCE-8524B >Version: 1.00 - HA 1 TA 0 - 6.3.0.2 Adapter driver: <atapi> HA 1 === Scsi-Device-Map === DiskPeripheral : FUJITSU MPF3102AT atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST CD-RW GCE-8524B atapi Port 1 ID 0 DMA: On CdRomPeripheral : AXV CD/DVD-ROM 2.1b axvscsi Port 2 ID 0 DMA: Off === CDRom-Device-Map === HL-DT-ST CD-RW GCE-8524B D: CDRom0 AXV CD/DVD-ROM E: CDRom1 ======================= AutoRun : 0 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 15728640 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 63MB (65008kB) Free physical memory: 5MB (5768kB) Memory in use : 91 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Enabled (1) 7.6.2005 CD-ROM (ISO) 15:18:28 #1 Text 0 File Isodoc.cpp, Line 6029 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660;1 file extensions : TRUE 15:18:28 #2 Phase 90 File dlgbrnst.cpp, Line 1800 Buffer Underrun Protection activated 15:18:28 #3 Text 0 File Reader.cpp, Line 118 Reader running 15:18:28 #4 Text 0 File Writer.cpp, Line 124 Writer HL-DT-ST CD-RW GCE-8524B running 15:18:28 #5 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) 15:18:30 #6 Text 0 File Burncd.cpp, Line 3101 Turn on Track-at-once, using CD-R/RW media 15:18:30 #7 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 352674 ( 78:24.24) 15:18:30 #8 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 15:18:30 #9 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: HL-DT-ST CD-RW GCE-8524B; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 15:18:30 #10 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:18:30 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 352675 (352675) = #352675/78:22.25 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 352673 blocks [HL-DT-ST CD-RW GCE-8524B ] -------------------------------------------------------------- 15:18:30 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [HL-DT-ST CD-RW GCE-8524B ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 722585600, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 352675 | lead-out | 1 | 0x00 | 0x41 15:18:30 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994 Removed 2 run-out blocks from end of track 1. Length: 352675 -> 352673. 15:18:34 #14 Phase 24 File dlgbrnst.cpp, Line 1800 Caching of files started 15:18:35 #15 Text 0 File Burncd.cpp, Line 4073 Cache writing successful. 15:18:35 #16 Phase 25 File dlgbrnst.cpp, Line 1800 Caching of files completed 15:18:35 #17 Phase 36 File dlgbrnst.cpp, Line 1800 Burn process started at 52x (7 800 KB/s) 15:18:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 15:18:35 #19 Text 0 File Mmc.cpp, Line 19451 Set BUFE: supported -> ON 15:19:09 #20 SCSI -1106 File Cdrdrv.cpp, Line 1431 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04560000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 15:19:09 #21 CDR -1106 File Writer.cpp, Line 301 Power calibration error 15:19:09 #22 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 15:19:10 #23 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 15:19:10 #24 CDR -201 File WriterStatus.cpp, Line 196 Invalid write state HL-DT-ST CD-RW GCE-8524B\H1 T0 15:19:10 #25 TRANSFER -18 File WriterStatus.cpp, Line 196 Could not perform EndTrack 15:19:10 #26 Text 0 File Mmc.cpp, Line 14287 <HL-DT-STCD-RW GCE-8524B > start Close Session 15:19:10 #27 SCSI -1176 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x04 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x04 15:19:10 #28 CDR -1176 File WriterStatus.cpp, Line 245 Session fixation error 15:19:10 #29 TRANSFER -19 File WriterStatus.cpp, Line 245 Could not perform Fixation 15:19:10 #30 Text 0 File WriterStatus.cpp, Line 254 falling back to disc fixation 15:19:10 #31 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 15:19:11 #32 Phase 38 File dlgbrnst.cpp, Line 1800 Burn process failed at 52x (7 800 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 2005-03-09 18:14:30 File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 21:51:54 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) dotychczas nagrywarka chodzila dobrze prosze o pomoc pozdrawiam Ostatnio zmieniany przez Y@nkee_PL : 12.06.2005 o godz. 21:18 |
1. Wyedytuj seriala ze swojego loga bo ci sie dostanie od moderatorow.
2. Zmien plyty bo zdaje sie probujesz nagrywac na jakims szajsie od plasmona. 3. Nagrywaj w trybie DAO lub DAO/96. 4. Wyczysc optyke nagrywarki. Nie rozbieraj jej jesli jest jeszcze na gwarancji, najwyzej plyta czyszczaca (czego nie polecam). Jesli nic z tych rzeczy nie pomoze, to raczej konczy sie nagrywara. Wiec serwis albo nowa. |
