Data rejestracji: 22.03.2006
Problem z nagrywaniem Dvd+r (pioneer 110-d)
Witam !
Mam pewien problem z nagrywaniem plyt DVD+R (Basf, TDK) DVD-R nagrywaja sie bez problemu. Po zakonczeniu procesu nagrywania pojawia sie kominikat: Nie można wykonać polecenia Zakończ w trybie DAO :mur: Wgrane sterowniki ASPI, najnowszy bios do nagrywarki 1.39, Nero 6.0.0.15 Log z operacji: 1A23-0065-4031-7633-1222-9258 Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56 ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-06-17 15:25:04 Wersja Nero: 6.0.0.15 (Nero Express) Nagrywarka: <PIONEER DVD-RW DVR-110D>Wersja: 1.39 - HA 1 TA 0 - 6.0.0.15 Sterownik adaptera: <atapi> HA 1 Drive buffer : 2000kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: <KH5825F WLF382I >Wersja: 1.0 - HA 2 TA 0 - 6.0.0.15 Sterownik adaptera: <dtscsi> HA 2 === Scsi-Device-Map === DiskPeripheral : HDS722516VLAT80 atapi Port 0 ID 0 DMA: On CdRomPeripheral : PIONEER DVD-RW DVR-110D atapi Port 1 ID 0 DMA: On CdRomPeripheral : KH5825F WLF382I 1.0 dtscsi Port 2 ID 0 DMA: Off === CDRom-Device-Map === PIONEER DVD-RW DVR-110D H: CDRom0 KH5825F WLF382I I: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 614MB (629244kB) Memory in use : 39 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 22.3.2006 Kompilacja ISO 10:28:57 #1 Text 0 File Isodoc.cpp, Line 5878 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 10:28:57 #2 Text 0 File Reader.cpp, Line 118 Reader running 10:28:57 #3 Text 0 File Writer.cpp, Line 127 Writer PIONEER DVD-RW DVR-110D running 10:28:57 #4 ISO9660GEN -11 File geniso.cpp, Line 3861 First writeable address = 0 (0x00000000) 10:28:57 #5 Text 0 File Burncd.cpp, Line 3168 Turn on Disc-At-Once, using DVD media 10:29:04 #6 Text 0 File DlgWaitCD.cpp, Line 230 Last possible write address on media: 2295103 (510:01.28) Last address to be written: 1446751 (321:30.01) 10:29:04 #7 Text 0 File DlgWaitCD.cpp, Line 235 Write in overburning mode: FALSE 10:29:04 #8 Text 0 File DlgWaitCD.cpp, Line 1885 Recorder: PIONEER DVD-RW DVR-110D, Media type: DVD+R Disc Manufacturer ID: CMC MAG, Media Type ID: M01, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 10:29:04 #9 Text 0 File DlgWaitCD.cpp, Line 393 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:29:04 #10 Text 0 File ThreadedTransferInterface.cpp, Line 769 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 3280 (3280) = #3280/0:43.55 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3280 blocks [PIONEER DVD-RW DVR-110D] -------------------------------------------------------------- 10:29:04 #11 Text 0 File ThreadedTransferInterface.cpp, Line 938 Prepare recorder [PIONEER DVD-RW DVR-110D] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 2 to 2: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 7024640, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 1443322 | lead-in | 0 | 0x00 | 0x41 1443322 | 2 | 0 | 0x00 | 0x41 1443472 | 2 | 1 | 0x00 | 0x41 1446752 | lead-out | 1 | 0x00 | 0x41 10:29:04 #12 Phase 24 File dlgbrnst.cpp, Line 1843 Rozpoczęto buforowanie plików 10:29:04 #13 Phase 25 File dlgbrnst.cpp, Line 1843 Zakończono buforowanie plików 10:29:04 #14 Phase 36 File dlgbrnst.cpp, Line 1843 Rozpoczęto zapis z prędkością 6x (8 280 KB/s) 10:29:04 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2136 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #1443472 10:29:04 #16 Text 0 File Cdrdrv.cpp, Line 7909 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Media Specific: 00 07 43 4D 43 20 4D 41 - 47 00 4D 30 31 00 38 23 ..CMC.MAG.M01.8# 54 37 18 00 3E 6E 00 70 - 62 15 15 0B 0B 08 08 01 T7..>n.pb....... 19 1B 0B 0B 0E 0F 01 00 - 00 00 00 00 00 00 00 01 ................ 10:29:04 #17 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:24,131 (24131ms) -> OK 10:29:04 #18 Text 0 File DVDPlusRW.cpp, Line 555 Start write address at LBA 1443472 DVD high compatibility mode: No 10:29:05 #19 Text 0 File Writer.cpp, Line 318 10:29:05.140 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #20 Text 0 File Writer.cpp, Line 318 10:29:28.203 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #21 Text 0 File Writer.cpp, Line 318 10:29:28.468 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #22 Text 0 File Writer.cpp, Line 318 10:29:28.625 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #23 Text 0 File Writer.cpp, Line 318 10:29:28.640 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #24 Text 0 File Writer.cpp, Line 318 10:29:28.656 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #25 Text 0 File Writer.cpp, Line 318 10:29:28.656 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #26 Text 0 File Writer.cpp, Line 318 10:29:28.671 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #27 Text 0 File Writer.cpp, Line 318 10:29:28.687 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #28 Text 0 File Writer.cpp, Line 318 10:29:28.687 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #29 Text 0 File Writer.cpp, Line 318 10:29:28.703 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #30 Text 0 File WriterStatus.cpp, Line 113 <PIONEER DVD-RW DVR-110D> start writing Lead-Out at LBA 1446752 (161360h), lenght 0 blocks 10:29:28 #31 Text 0 File Writer.cpp, Line 318 10:29:28.718 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #32 Text 0 File Writer.cpp, Line 318 10:29:28.718 - PIONEER DVD-RW DVR-110D : Queue again later (Intervall : 7msec) 10:29:28 #33 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:29:30 #34 SCSI -1066 File Cdrdrv.cpp, Line 1203 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0x5B 0x01 0x01 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00 0x24 0x00 10:29:30 #35 SCSI -1176 File Cdrdrv.cpp, Line 1203 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x03 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00 0x72 0x03 10:29:30 #36 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:00,000 (0ms) -> OK 10:29:30 #37 CDR -1066 File ThreadedTransferInterface.cpp, Line 1626 Błędne pole polecenia! PIONEER DVD-RW DVR-110D\H1 T0 10:29:30 #38 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1626 Nie można wykonać polecenia Zakończ w trybie DAO! 10:29:30 #39 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:00,000 (0ms) -> OK 10:29:30 #40 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:00,000 (0ms) -> OK 10:29:30 #41 Phase 38 File dlgbrnst.cpp, Line 1843 Zapis z prędkością 6x (8 280 KB/s) nie powiódł się! Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02 File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 2002-08-29 01:27:50 (Adapter driver for rec) File 'Drivers\dtscsi.sys': Ver=?.?.?.?, size=223128 bytes, created 2006-03-18 12:43:56 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Dzieki za pomoc. |
| #ads | |
Głupi Yasio
Data rejestracji: 27.05.2003
Jako ze uzywalem Pioneerow, mam tylko tyle do powiedzenia:
-nie lubia plyt +R, nagrywalem na Verbatimach 8x +R i jakos mi szlo. -nie sa to najlepsze nagrywarki na swiecie, z 10 szt, 3 byly niesprawne na starcie. -w Macach to nie chodzila zadna. (LG kazda) Tyle. Nie potrafie ci pomoc. |
Stary użytkownik
Data rejestracji: 09.06.2002
Dzi***281;ki za numer seryjny.
#4 | |
Ojciec dyktator
Data rejestracji: 16.02.2006
Jakis czas temu (z 1 miech) mialem jeszcze Pionka 109 i pomimo najnowszego biosu niechcial mi nagrywac dvd+r tdk x8 i ogolnie + nie lykal w 90% przyp. chyba musisz czekac na bios o ile maja zamiar to wogole poprawic w przyszlosci ...
BENQ LS DW1655 / LITE-ON SHW-1635S |
#7 | |
Stary użytkownik
