Stary 22.04.2004, 14:48   #1
Dzi@dzi@
Data rejestracji: 06.03.2004
Dzi@dzi@ w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z nagrywaniem w nero v6.3
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 02-07-17 16:03:58
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 03-11-11 14:49:52
Wersja Nero: 6.3.0.0 (Nero Express)
Nagrywarka: <LITE-ON LTR-48246S> Wersja: SS0E - HA 1 TA 1 - 6.3.0.0
Sterownik adaptera: <viadsk> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <CREATIVE DVD-ROM DVD1243E>Wersja: IC01 - HA 1 TA 0 - 6.3.0.0
CREATIVE DVD-ROM DVD1243E (Target 0, E: Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
LITE-ON LTR-48246S (Target 1, F: Autoinsert On, DMA ?, Disconnect On, SyncDataXfer Off
Generic DVD-ROM (Target 0, G: Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 639MB (654764kB)
Free physical memory: 107MB (109940kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
22.4.2004
CD-ROM (ISO)
14:20:34 #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Simulate : TRUE
Write : FALSE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
14:20:34 #2 Phase 90 File dlgbrnst.cpp, Line 1800
Włączono system ochrony zapisu
14:20:34 #3 Text 0 File Reader.cpp, Line 118
Reader running
14:20:34 #4 Text 0 File Writer.cpp, Line 124
Writer LITE-ON LTR-48246S running
14:20:34 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
14:20:34 #6 Text 0 File Burncd.cpp, Line 3094
Turn on Track-At-Once, using CD-R/RW media
14:20:35 #7 Text 0 File DlgWaitCD.cpp, Line 239
Last possible write address on media: 359844 (79:59.69)
Last address to be written: 358485 (79:41.60)
14:20:35 #8 Text 0 File DlgWaitCD.cpp, Line 244
Write in overburning mode: FALSE
14:20:35 #9 Text 0 File DlgWaitCD.cpp, Line 2068
Recorder: LITE-ON LTR-48246S;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:20:35 #10 Text 0 File DlgWaitCD.cpp, Line 405
14:20:35 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 358486 (358486) = #358486/79:39.61
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358484 blocks [LITE-ON LTR-48246S ]
14:20:35 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON LTR-48246S ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 734486528, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
358486 | lead-out | 1 | 0x00 | 0x41
14:20:35 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994
Removed 2 run-out blocks from end of track 1. Length: 358486 -> 358484.
14:20:35 #14 Phase 24 File dlgbrnst.cpp, Line 1800
Rozpoczęto buforowanie plików
14:20:35 #15 Text 0 File Burncd.cpp, Line 4061
Cache writing successful.
14:20:35 #16 Phase 25 File dlgbrnst.cpp, Line 1800
Zakończono buforowanie plików
14:20:35 #17 Phase 32 File dlgbrnst.cpp, Line 1800
Rozpoczęto symulację z prędkością 24x (3*600 KB/s)
14:20:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
14:20:35 #19 Text 0 File Mmc.cpp, Line 19397
Set BUFE: supported -> ON , SMART-BURN : ON
14:22:06 #20 Text 0 File Scsicmd.cpp, Line 1609
SCSI timeout (2), 90000ms, CDB Data[hex]: 2A 00 00 00 01 E0 00 00 20 00 00 00
14:22:06 #21 CDR -1175 File Cdrdrv.cpp, Line 1345
Śledzenie wewnętrzne
Command timeout occured: timeout 90000ms, counter 1
CDB Data: 0x2A 0x00 0x00 0x00 0x01 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
14:22:06 #22 SCSI -26 File Cdrdrv.cpp, Line 1375
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02250000
Status: 0x00 (0x02, SCSI_PENDING)
HA-Status 0x00 (0x00, OK)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
14:22:06 #23 SCSI -26 File Cdrdrv.cpp, Line 1430
Sense Code: 0x00
Sense Qual: 0x00
14:22:06 #24 CDR -26 File Writer.cpp, Line 301
Błąd upływu czasu polecenia SCSI/ATAPI!
LITE-ON LTR-48246S\H1 T1
14:22:06 #25 Text 0 File ThreadedTransfer.cpp, Line 229
14:22:06 #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
14:22:16 #27 Text 0 File Scsicmd.cpp, Line 1609
SCSI timeout (2), 10000ms, CDB Data[hex]: 35 00 00 00 00 00 00 00 00 00 00 00
14:22:16 #28 SCSI -1000 File Cdrdrv.cpp, Line 1170
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
14:22:16 #29 CDR -1175 File Cdrdrv.cpp, Line 1186
Command timeout occured: timeout 10000ms, counter 1
14:22:16 #30 SCSI -26 File Cdrdrv.cpp, Line 1213
Sense Code: 0x00
Sense Qual: 0x00
14:22:25 #31 CDR -1000 File WriterStatus.cpp, Line 151
Błąd magistrali SCSI lub IDE!
14:22:25 #32 TRANSFER -18 File WriterStatus.cpp, Line 151
Nie można wykonać polecenia ZakończŚcieżkę!
14:22:25 #33 CDR -201 File WriterStatus.cpp, Line 154
Niewłaściwy stan zapisu!
14:22:25 #34 TRANSFER -18 File WriterStatus.cpp, Line 154
14:22:25 #35 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
14:22:29 #36 Phase 34 File dlgbrnst.cpp, Line 1800
Symulacja z prędkością 24x (3*600 KB/s) nie powiodła się!
Probowalem roznymi predkosciami nagrac plytke ale zadna nie nagrywa
(aspi mam zainstalowane) Pomocy nie wiem co robic !!??
Dzi@dzi@ jest offline
Stary 22.04.2004, 16:17   #2
adixo
Until registration
Avatar użytkownika adixo
Data rejestracji: 02.01.2003
adixo jak się przyłoży ma szansę zostać specem <150 - 249 pkt>adixo jak się przyłoży ma szansę zostać specem <150 - 249 pkt>
O RANY ale tasiemiec ^_^ :zeby: ciekawe kto to będzie dokładnie analizował
zamiast tego napisz czy tylko w tym nero i na różnych płytach
adixo jest offline
Stary 22.04.2004, 16:38   #3
kizio
Wyrejestrowany
Avatar użytkownika kizio
Data rejestracji: 10.07.2002
Napisany przez Dzi@dzi@
Nagrywałeś w Nero Express? Jeżeli tak to spórbuj zwykłym Nero. Czasami Expressma takie wybryki chociarz to mało prawdopodobne...
kiziopl na gmail
JID: kizio na jabster.pl
kizio jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 00:18.
