Data rejestracji: 06.03.2004
Problem z nagrywaniem w nero v6.3
Windows 98 4.10
IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 02-07-17 16:03:58 ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 03-11-11 14:49:52 Wersja Nero: 6.3.0.0 (Nero Express) Nagrywarka: <LITE-ON LTR-48246S> Wersja: SS0E - HA 1 TA 1 - 6.3.0.0 Sterownik adaptera: <viadsk> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <CREATIVE DVD-ROM DVD1243E>Wersja: IC01 - HA 1 TA 0 - 6.3.0.0 Sterownik adaptera: <viadsk> HA 1 CREATIVE DVD-ROM DVD1243E (Target 0, E : Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?LITE-ON LTR-48246S (Target 1, F : Autoinsert On, DMA ?, Disconnect On, SyncDataXfer OffGeneric DVD-ROM (Target 0, G : Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 639MB (654764kB) Free physical memory: 107MB (109940kB) Memory in use : 49 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Enabled (1) 22.4.2004 CD-ROM (ISO) 14:20:34 #1 Text 0 File Isodoc.cpp, Line 6029 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : TRUE Write : FALSE Finalize CD : TRUE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 14:20:34 #2 Phase 90 File dlgbrnst.cpp, Line 1800 Włączono system ochrony zapisu 14:20:34 #3 Text 0 File Reader.cpp, Line 118 Reader running 14:20:34 #4 Text 0 File Writer.cpp, Line 124 Writer LITE-ON LTR-48246S running 14:20:34 #5 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) 14:20:34 #6 Text 0 File Burncd.cpp, Line 3094 Turn on Track-At-Once, using CD-R/RW media 14:20:35 #7 Text 0 File DlgWaitCD.cpp, Line 239 Last possible write address on media: 359844 (79:59.69) Last address to be written: 358485 (79:41.60) 14:20:35 #8 Text 0 File DlgWaitCD.cpp, Line 244 Write in overburning mode: FALSE 14:20:35 #9 Text 0 File DlgWaitCD.cpp, Line 2068 Recorder: LITE-ON LTR-48246S; CDR code: 00 97 15 17; OSJ entry from: Ritek Co. ATIP Data: Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 14:20:35 #10 Text 0 File DlgWaitCD.cpp, Line 405 >>> Protocol of DlgWaitCD activities: <<< ========================================= 14:20:35 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 358486 (358486) = #358486/79:39.61 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358484 blocks [LITE-ON LTR-48246S ] -------------------------------------------------------------- 14:20:35 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [LITE-ON LTR-48246S ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 734486528, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 358486 | lead-out | 1 | 0x00 | 0x41 14:20:35 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994 Removed 2 run-out blocks from end of track 1. Length: 358486 -> 358484. 14:20:35 #14 Phase 24 File dlgbrnst.cpp, Line 1800 Rozpoczęto buforowanie plików 14:20:35 #15 Text 0 File Burncd.cpp, Line 4061 Cache writing successful. 14:20:35 #16 Phase 25 File dlgbrnst.cpp, Line 1800 Zakończono buforowanie plików 14:20:35 #17 Phase 32 File dlgbrnst.cpp, Line 1800 Rozpoczęto symulację z prędkością 24x (3*600 KB/s) 14:20:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 14:20:35 #19 Text 0 File Mmc.cpp, Line 19397 Set BUFE: supported -> ON , SMART-BURN : ON 14:22:06 #20 Text 0 File Scsicmd.cpp, Line 1609 SCSI timeout (2), 90000ms, CDB Data[hex]: 2A 00 00 00 01 E0 00 00 20 00 00 00 14:22:06 #21 CDR -1175 File Cdrdrv.cpp, Line 1345 Śledzenie wewnętrzne Command timeout occured: timeout 90000ms, counter 1 CDB Data: 0x2A 0x00 0x00 0x00 0x01 0xE0 0x00 0x00 0x20 0x00 0x00 0x00 14:22:06 #22 SCSI -26 File Cdrdrv.cpp, Line 1375 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02250000 Status: 0x00 (0x02, SCSI_PENDING) HA-Status 0x00 (0x00, OK) TA-Status 0x00 (0x00, OK) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x01 0xE0 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 14:22:06 #23 SCSI -26 File Cdrdrv.cpp, Line 1430 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02250000 Status: 0x00 (0x02, SCSI_PENDING) HA-Status 0x00 (0x00, OK) TA-Status 0x00 (0x00, OK) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x01 0xE0 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 14:22:06 #24 CDR -26 File Writer.cpp, Line 301 Błąd upływu czasu polecenia SCSI/ATAPI! LITE-ON LTR-48246S\H1 T1 14:22:06 #25 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 14:22:06 #26 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 14:22:16 #27 Text 0 File Scsicmd.cpp, Line 1609 SCSI timeout (2), 10000ms, CDB Data[hex]: 35 00 00 00 00 00 00 00 00 00 00 00 14:22:16 #28 SCSI -1000 File Cdrdrv.cpp, Line 1170 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x00 (0x02, SCSI_PENDING) HA-Status 0x00 (0x00, OK) TA-Status 0x00 (0x00, OK) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 14:22:16 #29 CDR -1175 File Cdrdrv.cpp, Line 1186 Śledzenie wewnętrzne Command timeout occured: timeout 10000ms, counter 1 CDB Data[hex]: 35 00 00 00 00 00 00 00 00 00 00 00 14:22:16 #30 SCSI -26 File Cdrdrv.cpp, Line 1213 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x00 (0x02, SCSI_PENDING) HA-Status 0x00 (0x00, OK) TA-Status 0x00 (0x00, OK) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 14:22:25 #31 CDR -1000 File WriterStatus.cpp, Line 151 Błąd magistrali SCSI lub IDE! LITE-ON LTR-48246S\H1 T1 14:22:25 #32 TRANSFER -18 File WriterStatus.cpp, Line 151 Nie można wykonać polecenia ZakończŚcieżkę! 14:22:25 #33 CDR -201 File WriterStatus.cpp, Line 154 Niewłaściwy stan zapisu! LITE-ON LTR-48246S\H1 T1 14:22:25 #34 TRANSFER -18 File WriterStatus.cpp, Line 154 Nie można wykonać polecenia ZakończŚcieżkę! 14:22:25 #35 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 14:22:29 #36 Phase 34 File dlgbrnst.cpp, Line 1800 Symulacja z prędkością 24x (3*600 KB/s) nie powiodła się! Probowalem roznymi predkosciami nagrac plytke ale zadna nie nagrywa ![]() (aspi mam zainstalowane) Pomocy nie wiem co robic !!??
Until registration
Data rejestracji: 02.01.2003
O RANY ale tasiemiec ^_^ :zeby: ciekawe kto to będzie dokładnie analizował
zamiast tego napisz czy tylko w tym nero i na różnych płytach
#3 | |
Wyrejestrowany
Data rejestracji: 10.07.2002
