Data rejestracji: 29.08.2003
problem z nagrywaniem płyt Esperanza
mam trzyletnią nagrywarke TEAC CD-W512EB o parametrach 12/10/32. do tej pory dzialala dobrze, nagrywala wszystko, nic nie palila. jednak ostatnio próbowalem nagrac cos na płyte esperanza (700 MB, silver, 52x) i zapis się nie powiódł. myślalem ze płyta jest uszkodzona, wiec wziolem nastepna taka sama plyte. za kazdym razem log nagrywania jest taki sam:
Kod:
21:23:55 #2 Phase 72 File dlgbrnst.cpp, Line 1841 Włączono system BURN-Proof 21:23:55 #3 Text 0 File Reader.cpp, Line 118 Reader running 21:23:55 #4 Text 0 File Writer.cpp, Line 124 Writer TEAC CD-W512EB running 21:23:56 #5 ISO9660GEN -11 File geniso.cpp, Line 3898 First writeable address = 0 (0x00000000) 21:23:56 #6 Text 0 File Burncd.cpp, Line 3198 Turn on Track-At-Once, using CD-R/RW media 21:23:57 #7 Text 0 File DlgWaitCD.cpp, Line 244 Last possible write address on media: 359845 ( 79:59.70) Last address to be written: 358696 ( 79:44.46) 21:23:57 #8 Text 0 File DlgWaitCD.cpp, Line 249 Write in overburning mode: FALSE 21:23:57 #9 Text 0 File DlgWaitCD.cpp, Line 2107 Recorder: TEAC CD-W512EB; CDR code: 00 97 26 07; OSJ entry from: FORNET INTERNATIONAL PTE LTD. ATIP Data: Special Info [hex] 1: D0 00 90, 2: 61 1A 07 (LI 97:26.07), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid) 21:23:57 #10 Text 0 File DlgWaitCD.cpp, Line 410 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert the disc to write to. (Medium in drive: CD-R. Medium required by compilation: CD-R/RW.) 21:23:57 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 358697 (358697) = #358697/79:42.47 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358695 blocks [TEAC CD-W512EB ] -------------------------------------------------------------- 21:23:57 #12 Text 0 File ThreadedTransferInterface.cpp, Line 982 Prepare recorder [TEAC CD-W512EB ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 734918656, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 358697 | lead-out | 1 | 0x00 | 0x41 21:23:57 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1028 Removed 2 run-out blocks from end of track 1. Length: 358697 -> 358695. 21:23:57 #14 Phase 24 File dlgbrnst.cpp, Line 1841 Rozpoczęto buforowanie plików 21:23:57 #15 Text 0 File Burncd.cpp, Line 4214 Cache writing successful. 21:23:57 #16 Phase 25 File dlgbrnst.cpp, Line 1841 Zakończono buforowanie plików 21:23:57 #17 Phase 36 File dlgbrnst.cpp, Line 1841 Rozpoczęto zapis z prędkością 12x (1*800 KB/s) 21:23:57 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2342 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 21:23:57 #19 Text 0 File Mmc.cpp, Line 19864 Set BUFE: BURN-Proof -> ON 21:24:33 #20 SCSI -1106 File Cdrdrv.cpp, Line 1437 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x09770000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 21:24:33 #21 CDR -1106 File Writer.cpp, Line 304 Błąd kalibracji mocy! 21:24:33 #22 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 21:24:33 #23 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 21:24:33 #24 SCSI -1046 File Cdrdrv.cpp, Line 1183 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x30 0x05 21:24:33 #25 CDR -1046 File WriterStatus.cpp, Line 193 Nieprawidłowy dysk! 21:24:33 #26 TRANSFER -18 File WriterStatus.cpp, Line 193 Nie można wykonać polecenia ZakończŚcieżkę! 21:24:33 #27 CDR -201 File WriterStatus.cpp, Line 196 Niewłaściwy stan zapisu! TEAC CD-W512EB\H1 T1 21:24:33 #28 TRANSFER -18 File WriterStatus.cpp, Line 196 Nie można wykonać polecenia ZakończŚcieżkę! 21:24:33 #29 Text 0 File Mmc.cpp, Line 14708 <TEAC CD-W512EB > start Close Session 21:24:33 #30 SCSI -1046 File Cdrdrv.cpp, Line 1183 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x30 0x05 21:24:33 #31 CDR -1046 File WriterStatus.cpp, Line 245 Nieprawidłowy dysk! 21:24:33 #32 TRANSFER -19 File WriterStatus.cpp, Line 245 Wykonanie polecenia Fiksacja nie jest możliwe! 21:24:33 #33 Text 0 File WriterStatus.cpp, Line 254 falling back to disc fixation 21:24:33 #34 Text 0 File dlgbrnst.cpp, Line 1699 Set remaining time: 0:00,000 (0ms) -> OK 21:24:33 #35 Phase 38 File dlgbrnst.cpp, Line 1841 Zapis z prędkością 12x (1*800 KB/s) nie powiódł się! |
Cichy mod
Data rejestracji: 16.03.2003
Uaktulanij BIOS
![]() Pytanko : Czy to się dzieje na każdej płycie Esperanza ?
![]() Ciekawy blog LiTEa <-- Click ![]() ![]() Jak używac google ? | Lite-on 52327S | BenQ DW1640@EW164B Zanim zadasz pytanie - przeczytaj! [v1.0] | Jak odwiesic CD w Nero? Typ folderow w XP, rejestr | Konto w XP do gier TIMEOUT w autostart | O-T-W-I-E-R-A-M-Y |
Maciek: Reaktywacja
Data rejestracji: 18.11.2002
jak juz wspomniano, jesli jest taka mozliwosc to wgraj nowsza wersje biosa
a jesli wgranie nic nie pomoze to przydaloby sie przeczyscic optyke
wgralem nowego biosa, lecz problem sie powtarza
#6 | |
http://forum.cdrinfo.pl/showthread.p...zczenie+optyki ...tam znajdziesz linki i artykuł ![]()
Jak mądrze zadawać pytania |
po wymianie BIOSA, dokladnym wyczyszczeniu, zaktualizowaniu sterowników ASPI nagrywarka dalej nie chce nagrywac płyt Espreanza (700 MB, silver, 52x), jednak nagrywa płyty CD-RW i płyty Platinum (700MB, 52x)
podejrzewam ze po prostu moja nagrywarka nie bedzie nigdy trawiła płyt Espreanza ![]() |
Data rejestracji: 31.07.2003
Trafiają się skrajnie różne partie tych płytek.
Kupiłem kiedyś 10 i nagrało się super i trzymają się do dzisiaj. Następnym razem kupiłem 25 i z tego chyba 10 poleciało do kosza.
Ciężko jest żyć lekko ![]() |
Napisalem ci wyzej ze nic nie wywalczysz, nie wiem czy espery warte sa tego zeby sie przy nich upierac. Starsze nagrywarki niewaja klopoty z rozpoznaniem i skalibrowaniem lasera na nowych szybkich plytach. Na szczescie plytek jest wiele i wystarczy uzywac tych co ci dzialaja dobrze, wyjscia proste sa najlepsze.
