Stary 27.01.2006, 11:07   #1
wjotke
Data rejestracji: 27.01.2006
wjotke w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z nagrywaniem POMOCY
Witam,
przy próbie nagrania DVD wyskakuje mi komunikat - Błąd wejścia wyjścia i dalej:
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 2005-10-27 20:38:07
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-06-17 14:25:04
Nero API version: 6.0.0.9
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BS0C - HA 1 TA 0 - 6.0.0.9
Adapter driver: <> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-55JKA0 05.0 nvidesm Port 0 ID 0 DMA: Off
DiskPeripheral : SAMSUNG SV1022D MK10 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : SAMSUNG CD-ROM SC-148P PS01 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : LITE-ON DVDRW SOHW-1633SBS0C nvidesm Port 0 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 271MB (278276kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
8.12.2005
NeroAPI
19:03:15 #1 Phase 112 File APIProgress.cpp, Line 235
DVD-Video files reallocation started
19:03:15 #2 Phase 114 File APIProgress.cpp, Line 235
DVD-Video files reallocation completed (no file modified)
19:03:15 #3 Phase 111 File APIProgress.cpp, Line 235
DVD-Video files sorted
19:03:15 #4 Text 0 File Reader.cpp, Line 118
Reader running
19:03:15 #5 Text 0 File Writer.cpp, Line 127
Writer LITE-ON DVDRW SOHW-1633S running
19:03:15 #6 ISO9660GEN -11 File geniso.cpp, Line 3854
19:03:15 #7 ISO9660GEN -11 File geniso.cpp, Line 3854
19:03:15 #8 Text 0 File Burncd.cpp, Line 3173
19:03:48 #9 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2009765 (446:36.65)
19:03:48 #10 Text 0 File DlgWaitCD.cpp, Line 233
Write in overburning mode: FALSE
19:03:48 #11 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD+R
Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
19:03:48 #12 Text 0 File ThreadedTransferInterface.cpp, Line 768
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 2009766 (2009766) = #2009766/446:36.66
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2009766 blocks [LITE-ON DVDRW SOHW-1633S]
19:03:48 #13 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4116307968, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2009766 | lead-out | 1 | 0x00 | 0x41
19:03:48 #14 Phase 24 File APIProgress.cpp, Line 235
Caching of files started
19:03:48 #15 Phase 25 File APIProgress.cpp, Line 235
Caching of files completed
19:03:48 #16 Phase 36 File APIProgress.cpp, Line 235
Burn process started at 8x (11*040 KB/s)
19:03:48 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2130
19:03:48 #18 Text 0 File Cdrdrv.cpp, Line 7906
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Media Specific:
00 03 59 55 44 45 4E 30 - 30 30 54 30 32 00 38 23 ..YUDEN000T02.8#
54 37 10 02 4E 72 02 8C - 63 16 16 0B 0B 0A 0A 01 T7..Nr..c.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
19:03:48 #19 Text 0 File DVDPlusRW.cpp, Line 553
Start write address at LBA 0
19:04:11 #20 SCSI -500 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03930000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
19:04:11 #21 Text 0 File Writer.cpp, Line 455
19:04:11.671 LITE-ON DVDRW SOHW-1633S : WriteBuffer reduced to 32768 Bytes
19:04:11 #22 Text 0 File Writer.cpp, Line 318
19:04:11.671 - LITE-ON DVDRW SOHW-1633S : Queue again later (Intervall : 5msec)
19:04:19 #23 SCSI -1076 File Cdrdrv.cpp, Line 1415
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x28
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x28 0x00
19:04:19 #24 CDR -1076 File Writer.cpp, Line 335
Disc changed
19:04:19 #25 Text 0 File ThreadedTransfer.cpp, Line 227
19:04:19 #26 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
19:04:19 #27 Phase 127 File APIProgress.cpp, Line 235
Generating DVD high compatibility borders
19:04:19 #28 Phase 129 File APIProgress.cpp, Line 235
Generating DVD borders completed successfully
19:04:19 #29 Phase 38 File APIProgress.cpp, Line 235
Burn process failed at 8x (11*040 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 2005-10-27 20:38:07
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-03-11 23:28:13 (Prassi/Veritas driver for win 2K)
Registry Keys:
Co z tym zrobić? Czy ktoś może mi pomóc?
Wojtek
wjotke jest offline
Stary 27.01.2006, 12:12   #2
o czym to swiadczy ??
podpowiedz kontrolery IDE trzeba cos wlaczyc :taktak
odpowiedz WLACZ DMA
icemac jest offline
Stary 27.01.2006, 15:10   #3
Maciej
Avatar użytkownika Maciej
zainstaluj sterowniki do płyty głównej...najważniejsze te do kontrolera IDE.
Jak mądrze zadawać pytania
Maciej jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 07:21.
