Data rejestracji: 27.01.2006
Problem z nagrywaniem POMOCY
Witam,
przy próbie nagrania DVD wyskakuje mi komunikat - Błąd wejścia wyjścia i dalej: IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 2005-10-27 20:38:07 ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-06-17 14:25:04 Nero API version: 6.0.0.9 Using interface version: 6.3.1.4 Installed in: C:\Program Files\Ahead\Nero\ Application: ahead\Nero - Burning Rom Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BS0C - HA 1 TA 0 - 6.0.0.9 Adapter driver: <> HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder === Scsi-Device-Map === DiskPeripheral : WDC WD800BB-55JKA0 05.0 nvidesm Port 0 ID 0 DMA: Off DiskPeripheral : SAMSUNG SV1022D MK10 nvidesm Port 0 ID 1 DMA: Off CdRomPeripheral : SAMSUNG CD-ROM SC-148P PS01 nvidesm Port 0 ID 0 DMA: Off CdRomPeripheral : LITE-ON DVDRW SOHW-1633SBS0C nvidesm Port 0 ID 1 DMA: Off ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 271MB (278276kB) Memory in use : 46 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 8.12.2005 NeroAPI 19:03:15 #1 Phase 112 File APIProgress.cpp, Line 235 DVD-Video files reallocation started 19:03:15 #2 Phase 114 File APIProgress.cpp, Line 235 DVD-Video files reallocation completed (no file modified) 19:03:15 #3 Phase 111 File APIProgress.cpp, Line 235 DVD-Video files sorted 19:03:15 #4 Text 0 File Reader.cpp, Line 118 Reader running 19:03:15 #5 Text 0 File Writer.cpp, Line 127 Writer LITE-ON DVDRW SOHW-1633S running 19:03:15 #6 ISO9660GEN -11 File geniso.cpp, Line 3854 First writeable address = 0 (0x00000000) 19:03:15 #7 ISO9660GEN -11 File geniso.cpp, Line 3854 First writeable address = 0 (0x00000000) 19:03:15 #8 Text 0 File Burncd.cpp, Line 3173 Turn on Disc-At-Once, using DVD media 19:03:48 #9 Text 0 File DlgWaitCD.cpp, Line 228 Last possible write address on media: 2295103 (510:01.28) Last address to be written: 2009765 (446:36.65) 19:03:48 #10 Text 0 File DlgWaitCD.cpp, Line 233 Write in overburning mode: FALSE 19:03:48 #11 Text 0 File DlgWaitCD.cpp, Line 1722 Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD+R Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 19:03:48 #12 Text 0 File ThreadedTransferInterface.cpp, Line 768 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 2009766 (2009766) = #2009766/446:36.66 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2009766 blocks [LITE-ON DVDRW SOHW-1633S] -------------------------------------------------------------- 19:03:48 #13 Text 0 File ThreadedTransferInterface.cpp, Line 937 Prepare recorder [LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4116307968, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 2009766 | lead-out | 1 | 0x00 | 0x41 19:03:48 #14 Phase 24 File APIProgress.cpp, Line 235 Caching of files started 19:03:48 #15 Phase 25 File APIProgress.cpp, Line 235 Caching of files completed 19:03:48 #16 Phase 36 File APIProgress.cpp, Line 235 Burn process started at 8x (11*040 KB/s) 19:03:48 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2130 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 19:03:48 #18 Text 0 File Cdrdrv.cpp, Line 7906 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Media Specific: 00 03 59 55 44 45 4E 30 - 30 30 54 30 32 00 38 23 ..YUDEN000T02.8# 54 37 10 02 4E 72 02 8C - 63 16 16 0B 0B 0A 0A 01 T7..Nr..c....... 19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................ 19:03:48 #19 Text 0 File DVDPlusRW.cpp, Line 553 Start write address at LBA 0 DVD high compatibility mode: Yes 19:04:11 #20 SCSI -500 File Cdrdrv.cpp, Line 1415 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03930000 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 19:04:11 #21 Text 0 File Writer.cpp, Line 455 19:04:11.671 LITE-ON DVDRW SOHW-1633S : WriteBuffer reduced to 32768 Bytes 19:04:11 #22 Text 0 File Writer.cpp, Line 318 19:04:11.671 - LITE-ON DVDRW SOHW-1633S : Queue again later (Intervall : 5msec) 19:04:19 #23 SCSI -1076 File Cdrdrv.cpp, Line 1415 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03930000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x06 (KEY_UNIT_ATTENTION) Sense Code: 0x28 Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x28 0x00 19:04:19 #24 CDR -1076 File Writer.cpp, Line 335 Disc changed 19:04:19 #25 Text 0 File ThreadedTransfer.cpp, Line 227 all writers idle, stopping conversion 19:04:19 #26 Text 0 File ThreadedTransfer.cpp, Line 221 conversion idle, stopping reader 19:04:19 #27 Phase 127 File APIProgress.cpp, Line 235 Generating DVD high compatibility borders 19:04:19 #28 Phase 129 File APIProgress.cpp, Line 235 Generating DVD borders completed successfully 19:04:19 #29 Phase 38 File APIProgress.cpp, Line 235 Burn process failed at 8x (11*040 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 2005-10-27 20:38:07 File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-03-11 23:28:13 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Co z tym zrobić? Czy ktoś może mi pomóc? Pozdrawiam Wojtek |
DiskPeripheral : WDC WD800BB-55JKA0 05.0 nvidesm Port 0 ID 0 DMA: Off DiskPeripheral : SAMSUNG SV1022D MK10 nvidesm Port 0 ID 1 DMA: Off CdRomPeripheral : SAMSUNG CD-ROM SC-148P PS01 nvidesm Port 0 ID 0 DMA: Off CdRomPeripheral : LITE-ON DVDRW SOHW-1633SBS0C nvidesm Port 0 ID 1 DMA: Off ======================= o czym to swiadczy ?? podpowiedz kontrolery IDE trzeba cos wlaczyc :taktak odpowiedz WLACZ DMA |
zainstaluj sterowniki do płyty głównej...najważniejsze te do kontrolera IDE.
Jak mądrze zadawać pytania |
