Stary 29.11.2004, 20:27   #1
kwi4tu
Data rejestracji: 21.09.2003
kwi4tu w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
problem z nagrywarka
nie wiem czemu nie moge wypalic plytki. wyskakuje mi:
20:05:30 Burn process started at 16x
20:07:33 No seek complete
20:07:34 Could no perform EndTrack
20:07:34 Command sequence error
20:07:34 Cold not perform Fixation
20:07:30 Burn process failed
ponizej zamieszczam calego loga:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 2004-07-28 16:51:12
Nero version: 6.6.0.1
Recorder: <CyberDrv CW038D CD-R/RW> Version: 120C - HA 1 TA 0 - 6.6.0.1
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <CyberDrv CW038D CD-R/RW >Version: 120C - HA 1 TA 0 - 6.6.0.1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV4002H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : CyberDrv CW038D CD-R/RW atapi Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
CyberDrv CW038D CD-R/RW D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 70MB (72004kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
29.11.2004
CD Image
19:08:09 #1 Text 0 File Burncd.cpp, Line 2832
ExacLink activated
19:08:10 #2 Text 0 File Reader.cpp, Line 127
Reader running
19:08:10 #3 Text 0 File Writer.cpp, Line 122
Writer CyberDrv CW038D CD-R/RW running
19:08:10 #4 Text 0 File Burncd.cpp, Line 3117
Turn on Track-at-once, using CD-R/RW media
19:08:10 #5 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 315670 ( 70:10.70)
19:08:10 #6 Text 0 File DlgWaitCD.cpp, Line 268
19:08:10 #7 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: CyberDrv CW038D CD-R/RW;
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 20, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 45 44 03 (invalid), 3: 00 00 00 (invalid)
19:08:10 #8 Text 0 File DlgWaitCD.cpp, Line 430
19:08:10 #9 Text 0 File ThreadedTransferInterface.cpp, Line 844
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
original disc pos #0 + 315671 (315671) = #315671/70:8.71
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 315669 blocks [CyberDrv CW038D CD-R/RW]
19:08:10 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1047
Prepare recorder [CyberDrv CW038D CD-R/RW] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 646801408, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
315671 | lead-out | 1 | 0x00 | 0x41
19:08:10 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1096
Removed 2 run-out blocks from end of track 1. Length: 315671 -> 315669.
19:08:10 #12 Phase 24 File dlgbrnst.cpp, Line 1853
Caching of files started
19:08:10 #13 Text 0 File Burncd.cpp, Line 4003
Cache writing successful.
19:08:10 #14 Phase 25 File dlgbrnst.cpp, Line 1853
Caching of files completed
19:08:10 #15 Phase 36 File dlgbrnst.cpp, Line 1853
Burn process started at 16x (2*400 KB/s)
19:08:10 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2497
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:08:10 #17 Text 0 File Mmc.cpp, Line 20673
Set BUFE: ExacLink -> ON
19:15:33 #18 SCSI -1093 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x06670000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x02
Sense Qual: 0x30
CDB Data: 0x2A 0x00 0x00 0x01 0xB1 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0x30
19:15:33 #19 CDR -1093 File Writer.cpp, Line 311
No seek complete
19:15:33 #20 Text 0 File ThreadedTransfer.cpp, Line 229
19:15:34 #21 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
19:15:34 #22 SCSI -1033 File Cdrdrv.cpp, Line 1178
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x04 0x01
19:15:44 #23 CDR -1033 File WriterStatus.cpp, Line 197
Drive not ready
19:15:44 #24 TRANSFER -18 File WriterStatus.cpp, Line 197
Could not perform EndTrack
19:15:44 #25 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
CyberDrv CW038D CD-R/RW\H1 T0
19:15:44 #26 TRANSFER -18 File WriterStatus.cpp, Line 200
19:15:44 #27 Text 0 File Mmc.cpp, Line 15477
<CyberDrvCW038D CD-R/RW > start Close Session
19:15:44 #28 SCSI -1023 File Cdrdrv.cpp, Line 1178
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x00
19:15:44 #29 CDR -1023 File WriterStatus.cpp, Line 249
19:15:44 #30 TRANSFER -19 File WriterStatus.cpp, Line 249
Could not perform Fixation
19:15:44 #31 Text 0 File WriterStatus.cpp, Line 258
falling back to disc fixation
19:15:44 #32 Text 0 File dlgbrnst.cpp, Line 1711
Set remaining time: 0:00,000 (0ms) -> OK
19:15:44 #33 Phase 38 File dlgbrnst.cpp, Line 1853
Burn process failed at 16x (2*400 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 11:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 2002-08-29 09:27:50 (Adapter driver for rec)
Registry Keys:
Ostatnio zmieniany przez kwi4tu : 30.11.2004 o godz. 16:38
kwi4tu jest offline
Stary 30.11.2004, 11:43   #2
nimal
Author
Avatar użytkownika nimal
Data rejestracji: 29.03.2003
usun poczatek loga - to nie warez wiec nie odawaj seriali
sprobuj na innych plytach i podaj wiecej szczegolow - od kiedy, czy zawsze na tych samych plytach, czy masz najnowszy bios, czy reinstalowales system, czy masz nagrywnaie wbudowane wylaczone...
nimal jest offline
Stary 30.11.2004, 22:44   #3
kwi4tu
przed chwila udalo mi sie nagrac plyte cd-rw. ale gdy ten sam plik chcialem nagrac na cd-r to po okolo 50% znowy wyskoczyl mi blad:
No seek complete
Burn process failed
kwi4tu jest offline
Stary 01.12.2004, 09:21   #4
nimal
Author
laser - albo brudny (wyczysc) albo sie skonczyl (wymiana sprzetu), albo sprzet nie zna twoich plyt cdr -sprobuj an innych i/lub aktualizuj firmware
zanim zrobisz krok radykalny - sprawdz na innym kompie
problemy lasera uwidaczniaja sie na cdr a nie na rw bo do ich palenia sa uzywane zupelnie inne moce lasera
nimal jest offline
Stary 01.12.2004, 16:21   #5
kwi4tu
na tych plytkach wczesniej normalnie nagrywalem. fimware tez jest zaktualizowane do najnowszej wersji. zdaje mi sie ze laser jest brudny. jesli nie to czeka mnie wymiana sprzetu
wielkie dzieki za pomoc pozdro dla ciebie
kwi4tu jest offline
Stary 01.12.2004, 17:10   #6
Maciej
Avatar użytkownika Maciej
sprawdż nagrywarkę na innym kompie...przed podejmowaniem desperackich decyzji.
Jak mądrze zadawać pytania
Maciej jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 13:55.
