Stary 05.03.2004, 08:59   #1
@r2r
Data rejestracji: 04.12.2001
@r2r w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
jest nowy DVD Mate 2.6.3.1
http://www.copystar.com.tw/software_update/enu/DVDMate/
Training (21.1 MB):
http://www.copystar.com.tw/software_...te/How2Use.htm
Update (7.62 MB):
http://www.copystar.com.tw/software_...MateUpdate.htm
historia wersji:
http://www.copystar.com.tw/software_update/enu/DVDMate/VersionHistory(ENU).txt
DVD Mate
Version history (English)
DVD Mate is a program with various functions.
All sorts of drives and writers are available everywhere so that
you may find some compatible problems when running with different devices.
Please follow up the instructions and contact us once you face
dificult problems. Our R&D team will find best solutions to the problems.
2004/03/1
*: Fix spanish language display problem.
*: Fix main menu link and display problem.
*: Append ot fix recorder list:
Lite-On : SOHW-812S
2004/02/26
*: Fix failed to load CD Video Author.
*: Fix skin language and picture lose.
*: Fix Premaster ISO file sort speed.
*: Append spanish language support.
SONY : CRX215E5
Lite-On : LDW-451S
Samsung : SM-252S
Toshiba : SD-R1512
FreeCom : SDCDRW52K
2004/02/18
*: Fix language error.
*: Fix multi-Session/Volume display.
*: Fix onlie update downlaod failed problem.
AOPEN : DRW8800
ASUS : DRW-0804P
2004/02/11 Fix
*: fix PC no or only one CD-ROM problem.
*: Premaster save as .iso, burn failed problem.
*: Support online update download patch file.
*: Fix Achernar for MS HCT 11.2 test kit And windows driver verifier manager.
TEAC : DV-W24E
LiteOn : SDW-431SX
2004/01/19 Fix
1: fix Premaster for unix file name
2: fix dvd-rom display read and burn speed.
3: fix save c/dvd imagefile memory leak
TEAC : CD-W552D
NEC : ND-2500A
PHILIPS : JR4DVDRW
TRAXDATA: RW-2500
@r2r jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 13:07.
