Stary 25.10.2004, 14:31   #1
kisol
Data rejestracji: 08.08.2003
kisol w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Unhappy problem z nero i Win98
witam
wsyzstko gralo tylko zalozylem drugi dysk i teraz juz nie che nagrywac
dyski sa na jednej tasmie RW na drugiej podczas nagrywania wyskakuje komuniatinvalid write state. Gdy nagrywalem po linuxem dzialalo i plytka tez dziala
a pod windom nic :/
oto fragment logu jak to komus pomoze
CD-ROM (ISO)
13:14:13 #1 Text 0 File Isodoc.cpp, Line 5950
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
13:14:13 #2 Phase 90 File dlgbrnst.cpp, Line 1843
Buffer Underrun Protection activated
13:14:15 #3 Text 0 File Reader.cpp, Line 118
Reader running
13:14:15 #4 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-48125S running
13:14:15 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
13:14:15 #6 Text 0 File Burncd.cpp, Line 3198
Turn on Track-at-once, using CD-R/RW media
13:14:18 #7 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 359845 (79:59.70)
Last address to be written: 358812 (79:46.12)
13:14:18 #8 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
13:14:18 #9 Text 0 File DlgWaitCD.cpp, Line 1949
Recorder: LITE-ON LTR-48125S;
CDR code: 00 97 26 07; OSJ entry from: FORNET INTERNATIONAL PTE LTD.
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13:14:18 #10 Text 0 File DlgWaitCD.cpp, Line 394
Insert the disc to write to.
(Medium in drive: CD-R. Medium required by compilation: CD-R/RW.)
13:14:18 #11 Text 0 File ThreadedTransferInterface.cpp, Line 769
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 358813 (358813) = #358813/79:44.13
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358811 blocks [LITE-ON LTR-48125S ]
13:14:18 #12 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [LITE-ON LTR-48125S ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 735156224, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
358813 | lead-out | 1 | 0x00 | 0x41
13:14:19 #13 Text 0 File ThreadedTransferInterface.cpp, Line 965
Removed 2 run-out blocks from end of track 1.
13:14:19 #14 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
13:14:19 #15 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
13:14:19 #16 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 24x (3*600 KB/s)
13:14:19 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2136
13:14:19 #18 Text 0 File Mmc.cpp, Line 19195
Set BUFE: supported -> ON , SMART-BURN : ON
13:14:59 #19 TRANSFER -25 File Reader.cpp, Line 371
Error reading Data
13:15:10 #20 Text 0 File ThreadedTransfer.cpp, Line 228
13:15:11 #21 CDR -201 File WriterStatus.cpp, Line 193
Invalid write state
LITE-ON LTR-48125S\H0 T0
13:15:11 #22 TRANSFER -18 File WriterStatus.cpp, Line 193
Could not perform EndTrack
13:15:11 #23 Text 0 File Mmc.cpp, Line 14149
<LITE-ON LTR-48125S > start Close Session
13:15:29 #24 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
13:15:29 #25 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 24x (3*600 KB/s)
kisol jest offline
Stary 25.10.2004, 15:11   #2
tengu
Hitokiri Battousai
Avatar użytkownika tengu
Data rejestracji: 14.09.2004
Najpierw przeinstaluj nero - czasem wykrywanie nagrywarek szwankuje ;-
a jeśli nie pomoże:
Sprawdź zworki w dyskach i napędzie czy są na pewno MASTER / SLAVE
Przy jednym dysku na primary IDE Cable select nie ma problemu, ale już na przykład dwa dyski CABLE Select potrafią ostro narozrabiać,
No i oczywiście DMA jeśli możliwe (jak miałem LG 32x chodził jako PIO4 [inaczej nie mógł]i czasem gubił bufor i płytka do kosza), ASPI itp.
vectra-unlimited
Ostatnio zmieniany przez tengu : 25.10.2004 o godz. 15:15
tengu jest offline
Stary 25.10.2004, 19:44   #3
kisol
zinstlaeowlaem nowe sterowniki, sprubowalem nagrac w innym porgramie nibyt nagralo ale na plycie sa bledy pod jej koniec, :/ w nero nie prubowlaem jeszceraz nagrywac!
kisol jest offline
Stary 26.10.2004, 10:10   #4
tengu
Hitokiri Battousai
Hmm wychodzi z tego loga, że on ma problemy z czytaniem więc albo bufor nagrywarki spada poniżej pewnego poziomu, albo coś z dyskami (właśnie pod koniec się coś takiego pojawiło) [ale jestem trochę cienki w czytaniu logów (za dużo dobrych płytek), więc może przyczyna jest inna], spróbuj wyłączyć antyvira/firewalla/p2p i wygaszacz ekranu na czas nagrywania.....
vectra-unlimited
tengu jest offline
Stary 30.10.2004, 09:47   #5
kisol
sprubuje moze cos pomoze! bo narazie problem sie powtarza
kisol jest offline
Stary 01.11.2004, 23:29   #6
kisol
problem nadal aktualny :/
kisol jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 01:27.
