Stary 03.11.2004, 00:37   #1
Konet
Data rejestracji: 03.11.2004
Konet w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z Plextorem
Witam.
Mam taki maly problem z nagrywarka. Jest to Plextor PX-W4012A. Podczas nagrywania cos pada. Wgralem juz nowy bios i dalej to samo. Moze jak wkleje log file z nero to cos to wam powie.
xxxxxxx xxxxxxx
xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 08:20:56
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 2004-07-22 16:33:44
Nero version: 6.3.1.20
Recorder: <PLEXTOR CD-R PX-W4012A>Version: 1.06 - HA 1 TA 0 - 6.3.1.20
Adapter driver: <atapi> HA 1
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-ROM DVD-106 >Version: 1.22 - HA 0 TA 1 - 6.3.1.20
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP1614N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-ROM DVD-106 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PLEXTOR CD-R PX-W4012A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-ROM DVD-106 F: CDRom0
PLEXTOR CD-R PX-W4012A G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261620kB)
Free physical memory: 39MB (40292kB)
Memory in use : 84 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
2.11.2004
Audio CD
23:17:47 #1 CDADOC -1 File Cdadoc.cpp, Line 1508
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:55.19, Pause frames: 150, Filters: 0, Name: '01. Farba - A Je_li To Nieprawda.mp3'.
Track 02: Length: 04:26.10, Pause frames: 150, Filters: 0, Name: '02. Farba - Daleko....mp3'.
Track 03: Length: 04:02.52, Pause frames: 150, Filters: 0, Name: '03. Farba - Chce Tu Zostaa.mp3'.
Track 04: Length: 03:42.18, Pause frames: 150, Filters: 0, Name: '04. Farba - Czy Nigdy Wiecej (Nigdy Wiecej).mp3'.
Track 05: Length: 02:46.24, Pause frames: 150, Filters: 0, Name: '05. Farba - Odejde Od Ciebie.mp3'.
Track 06: Length: 03:04.35, Pause frames: 150, Filters: 0, Name: '06. Farba - Taka Ny Nu 3one Czaczen.mp3'.
Track 07: Length: 04:28.44, Pause frames: 150, Filters: 0, Name: '07. Farba - Zagubiony Ksi1_e.mp3'.
Track 08: Length: 04:11.59, Pause frames: 150, Filters: 0, Name: '08. Farba - Hej Ma3y.mp3'.
Track 09: Length: 04:24.42, Pause frames: 150, Filters: 0, Name: '09. Farba - Gra Zwana _wiat.mp3'.
Track 10: Length: 03:15.15, Pause frames: 150, Filters: 0, Name: '10. Farba - Musze Krzyczea!.mp3'.
Track 11: Length: 04:07.12, Pause frames: 150, Filters: 0, Name: '11. Farba - Nie Warte Nic.mp3'.
Track 12: Length: 06:27.19, Pause frames: 150, Filters: 0, Name: '12. Farba - I'm Leaving You.mp3'.
Total size: 50:15.49
23:17:47 #2 Phase 72 File dlgbrnst.cpp, Line 1855
BURN-Proof activated
23:17:47 #3 Text 0 File Reader.cpp, Line 126
Reader running
23:17:47 #4 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
23:17:47 #5 Text 0 File Writer.cpp, Line 124
Writer PLEXTOR CD-R PX-W4012A running
23:17:47 #6 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-at-once, using CD-R/RW media
23:17:47 #7 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 359846 ( 79:59.71)
Last address to be written: 226023 ( 50:15.48)
23:17:47 #8 Text 0 File DlgWaitCD.cpp, Line 259
23:17:47 #9 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: PLEXTOR CD-R PX-W4012A;
CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
ATIP Data:
Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 48 (LO 79:59.72)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
23:17:47 #10 Text 0 File DlgWaitCD.cpp, Line 420
23:17:47 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
0: TRM_AUDIO_NOPRE (01. Farba - A Je_li To Nieprawda.mp3)
original disc pos #0 + 22144 (22144) = #22144/4:55.19
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22144 blocks [PLEXTOR CD-R PX-W4012A]
1: TRM_AUDIO_NOPRE (02. Farba - Daleko....mp3)
original disc pos #0 + 19960 (19960) = #19960/4:26.10
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19960 blocks [PLEXTOR CD-R PX-W4012A]
2: TRM_AUDIO_NOPRE (03. Farba - Chce Tu Zostaa.mp3)
original disc pos #0 + 18202 (18202) = #18202/4:2.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18202 blocks [PLEXTOR CD-R PX-W4012A]
3: TRM_AUDIO_NOPRE (04. Farba - Czy Nigdy Wiecej (Nigdy Wiecej).mp3)
original disc pos #0 + 16668 (16668) = #16668/3:42.18
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16668 blocks [PLEXTOR CD-R PX-W4012A]
4: TRM_AUDIO_NOPRE (05. Farba - Odejde Od Ciebie.mp3)
original disc pos #0 + 12474 (12474) = #12474/2:46.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12474 blocks [PLEXTOR CD-R PX-W4012A]
5: TRM_AUDIO_NOPRE (06. Farba - Taka Ny Nu 3one Czaczen.mp3)
original disc pos #0 + 13835 (13835) = #13835/3:4.35
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13835 blocks [PLEXTOR CD-R PX-W4012A]
6: TRM_AUDIO_NOPRE (07. Farba - Zagubiony Ksi1_e.mp3)
original disc pos #0 + 20144 (20144) = #20144/4:28.44
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20144 blocks [PLEXTOR CD-R PX-W4012A]
7: TRM_AUDIO_NOPRE (08. Farba - Hej Ma3y.mp3)
original disc pos #0 + 18884 (18884) = #18884/4:11.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18884 blocks [PLEXTOR CD-R PX-W4012A]
8: TRM_AUDIO_NOPRE (09. Farba - Gra Zwana _wiat.mp3)
original disc pos #0 + 19842 (19842) = #19842/4:24.42
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19842 blocks [PLEXTOR CD-R PX-W4012A]
9: TRM_AUDIO_NOPRE (10. Farba - Musze Krzyczea!.mp3)
original disc pos #0 + 14640 (14640) = #14640/3:15.15
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14640 blocks [PLEXTOR CD-R PX-W4012A]
10: TRM_AUDIO_NOPRE (11. Farba - Nie Warte Nic.mp3)
original disc pos #0 + 18537 (18537) = #18537/4:7.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18537 blocks [PLEXTOR CD-R PX-W4012A]
11: TRM_AUDIO_NOPRE (12. Farba - I'm Leaving You.mp3)
original disc pos #0 + 29044 (29044) = #29044/6:27.19
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 29044 blocks [PLEXTOR CD-R PX-W4012A]
23:17:48 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [PLEXTOR CD-R PX-W4012A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 12:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 52435488, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 52435488 52788288 99734208, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 99734208 100087008 142898112, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 142898112 143250912 182454048, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 182454048 182806848 212145696, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 212145696 212498496 245038416, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 245038416 245391216 292769904, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 292769904 293122704 337537872, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 337537872 337890672 384559056, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 384559056 384911856 419345136, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 419345136 419697936 463296960, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 463296960 463649760 531961248, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x01
-150 | 1 | 0 | 0x00 | 0x21
0 | 1 | 1 | 0x00 | 0x21
22144 | 2 | 0 | 0x00 | 0x21
22294 | 2 | 1 | 0x00 | 0x21
42254 | 3 | 0 | 0x00 | 0x21
42404 | 3 | 1 | 0x00 | 0x21
60606 | 4 | 0 | 0x00 | 0x21
60756 | 4 | 1 | 0x00 | 0x21
77424 | 5 | 0 | 0x00 | 0x21
77574 | 5 | 1 | 0x00 | 0x21
90048 | 6 | 0 | 0x00 | 0x21
90198 | 6 | 1 | 0x00 | 0x21
104033 | 7 | 0 | 0x00 | 0x21
104183 | 7 | 1 | 0x00 | 0x21
124327 | 8 | 0 | 0x00 | 0x21
124477 | 8 | 1 | 0x00 | 0x21
143361 | 9 | 0 | 0x00 | 0x21
143511 | 9 | 1 | 0x00 | 0x21
163353 | 10 | 0 | 0x00 | 0x21
163503 | 10 | 1 | 0x00 | 0x21
178143 | 11 | 0 | 0x00 | 0x21
178293 | 11 | 1 | 0x00 | 0x21
196830 | 12 | 0 | 0x00 | 0x21
196980 | 12 | 1 | 0x00 | 0x21
226024 | lead-out | 1 | 0x00 | 0x01
23:17:48 #13 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 40x (6*000 KB/s)
23:17:48 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
23:17:48 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #22294
23:17:48 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #42404
23:17:48 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #60756
23:17:48 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #77574
23:17:48 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #90198
23:17:48 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #104183
23:17:48 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #124477
23:17:48 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #143511
23:17:48 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #163503
23:17:48 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #178293
23:17:48 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #196980
23:17:48 #26 Text 0 File Mmc.cpp, Line 15914
StartDAO : CD-Text - On
23:17:48 #27 Text 0 File Mmc.cpp, Line 20531
Set BUFE: BURN-Proof -> ON
23:17:48 #28 Text 0 File Mmc.cpp, Line 16203
CueData, Len=208
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 39 13
21 02 01 00 00 04 3b 13
21 03 00 00 00 09 19 1d
21 03 01 00 00 09 1b 1d
21 04 00 00 00 0d 1e 06
21 04 01 00 00 0d 20 06
21 05 00 00 00 11 0e 18
21 05 01 00 00 11 10 18
21 06 00 00 00 14 02 30
21 06 01 00 00 14 04 30
21 07 00 00 00 17 09 08
21 07 01 00 00 17 0b 08
21 08 00 00 00 1b 27 34
21 08 01 00 00 1b 29 34
21 09 00 00 00 1f 35 24
21 09 01 00 00 1f 37 24
21 0a 00 00 00 24 14 03
21 0a 01 00 00 24 16 03
21 0b 00 00 00 27 25 12
21 0b 01 00 00 27 27 12
21 0c 00 00 00 2b 2e 1e
21 0c 01 00 00 2b 30 1e
01 aa 01 01 00 32 0f 31
23:20:28 #29 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x037C0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x0C
Sense Qual: 0x07
CDB Data: 0x2A 0x00 0x00 0x02 0x50 0xC2 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x02 0x51 0x58 0x0A
0x00 0x00 0x00 0x00 0x0C 0x07
23:20:28 #30 CDR -1135 File Writer.cpp, Line 304
Write error
23:20:28 #31 Text 0 File ThreadedTransfer.cpp, Line 229
23:20:31 #32 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
23:20:34 #33 Text 0 File ThreadedTransfer.cpp, Line 223
23:20:34 #34 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
23:20:34 #35 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 40x (6*000 KB/s)
23:20:34 #36 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
23:20:34 #37 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 07:53:02
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 11:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 2002-08-29 00:27:50 (Adapter driver for rec)
Registry Keys:
Z gory dzieki za pomoc.
Konet jest offline
Stary 03.11.2004, 20:05   #2
Gerard
Podpalacz
Avatar użytkownika Gerard
Data rejestracji: 01.10.2004
Gerard w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
a czy w tle masz włączony program od Plextora (Plextools)?
Gerard
Gerard jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 03:10.
