Stary 05.06.2007, 23:35   #1
Ͼ Ͽ
Log z nero bardzo wskazany.
Wklej z ***322;aski swojej.
Forum ZielonaIrlandia.
Stary 06.06.2007, 00:05   #2
Jelcz
Avatar użytkownika Jelcz
Data rejestracji: 09.10.2004
Jelcz w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Nie no nagra***322;a super!! wynik na 4 p***322;yty jedna nagrana (Emtec,TDK) wklejam loga bo oczywiscie bez problem***243;w nie moglo sie oby***263; standardowo na samym koncu przy100% nie dawa***322;a rady i sie m***281;czy***322;a z "zako***324;czeniem" p***322;yty
Kod:
1C82-0000-19E5-MAAX-4002-3642-****
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 1999-09-10 13:06:00
ahead WinASPI: File 'C:\Program Files\Nero\Nero Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 14:54:32
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
 (Nero Express)
Recorder:             <TSSTcorp CDW/DVD TS-H492A>Version: TB00 - HA 1 TA 0 - 7.5.7.0
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <TSSTcorp CDW/DVD TS-H492A>Version: TB00 - HA 1 TA 0 - 7.5.7.0
=== Scsi-Device-Map ===
DiskPeripheral       : SAMSUNG SP0812N                  atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : TSSTcorp CDW/DVD TS-H492A        atapi Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
TSSTcorp CDW/DVD TS-H492A  D:   CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
BUFE           : 0
Physical memory     : 255MB (261616kB)
Free physical memory: 67MB (68800kB)
Memory in use       : 73 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
5.6.2007
Audio CD
23:53:54    #1 Text 0 File SCSIPassThrough.cpp, Line 583
23:53:55    #2 CDADOC -1 File Cdadoc.cpp, Line 1635
    Audio item log info:
    Audio document burn settings:
    Burn mode: DAO,
    CD Text: On,
    Cache disk or network files: No,
    Cache small files: No,
    Cache files smaller than 65536 bytes.
    Audio Multisession: No
    List of audio tracks:
    Track 01: Length: 03:13.11, Pause frames: 150, Filters: 0, Name: 'Czerwone Gitary_Seweryn Krajewski - Najpiekniejsza.mp3'.
    Track 02: Length: 03:04.27, Pause frames: 150, Filters: 0, Name: 'Dwa Plus Jeden - Chod***378;, Pomaluj M***243;j ***346;wiat.mp3'.
    Track 03: Length: 03:49.18, Pause frames: 150, Filters: 0, Name: 'Dwa Plus Jeden - Jak Si***281; Masz, Kochanie.mp3'.
    Track 04: Length: 02:56.73, Pause frames: 150, Filters: 0, Name: 'Dwa plus Jeden - Wstawaj szkoda dnia.mp3'.
    Track 05: Length: 05:18.34, Pause frames: 150, Filters: 0, Name: 'Dwa plus jeden - Zegarmistrz ***347;wiat***322;a.mp3'.
    Track 06: Length: 04:21.01, Pause frames: 150, Filters: 0, Name: 'Dwa Plus Jeden-I***347;***263; W Stron***281; S***322;o***324;ca.mp3'.
    Track 07: Length: 03:19.17, Pause frames: 150, Filters: 0, Name: 'G***261;sowski Wojciech - Zielone wzg***243;rza nad Solin***261;.mp3'.
    Track 08: Length: 03:43.63, Pause frames: 150, Filters: 0, Name: 'Piotr Szczepanik - Dziewczyna, Ktora Kocham.mp3'.
    Track 09: Length: 03:10.46, Pause frames: 150, Filters: 0, Name: 'piotr szczepanik - goniac kormorany.mp3'.
    Track 10: Length: 03:41.48, Pause frames: 150, Filters: 0, Name: 'piotr szczepanik - kochac.mp3'.
    Track 11: Length: 03:23.17, Pause frames: 150, Filters: 0, Name: 'piotr szczepanik - nigdy wiecej.mp3'.
    Track 12: Length: 03:21.63, Pause frames: 150, Filters: 0, Name: 'Piotr Szczepanik - Zielone wzg***243;rza nad Solin***261;.mp3'.
    Track 13: Length: 04:27.31, Pause frames: 150, Filters: 0, Name: 'POLSKIE - Dwa Plus Jeden - Winda Do Nieba.mp3'.
    Track 14: Length: 03:50.20, Pause frames: 150, Filters: 0, Name: 'Seweryn Krajewski - Czerwone Gitary - Nie spoczniemy.mp3'.
    Track 15: Length: 03:20.50, Pause frames: 150, Filters: 0, Name: 'Wojciech G***261;sowski - Gdzie si***281; podzia***322;y tamte prywatki - disco polo.mp3'.
    Track 16: Length: 02:59.65, Pause frames: 150, Filters: 0, Name: 'Czerwone Gitary - Dzika plaza (1).mp3'.
    Track 17: Length: 02:45.61, Pause frames: 150, Filters: 0, Name: 'Czerwone Gitary - Jest Taki Dzien.mp3'.
    Track 18: Length: 02:13.54, Pause frames: 150, Filters: 0, Name: 'czerwone gitary - kwiaty we wlosach.mp3'.
    Track 19: Length: 03:17.46, Pause frames: 150, Filters: 0, Name: 'czerwone gitary - Nie licze godzin i lat.mp3'.
    Track 20: Length: 02:25.53, Pause frames: 150, Filters: 0, Name: 'czerwone gitary - niebo z moich stron.mp3'.
    Track 21: Length: 03:40.47, Pause frames: 150, Filters: 0, Name: 'Czerwone gitary - Uciekaj Moje Serce.mp3'.
    Track 22: Length: 03:47.00, Pause frames: 150, Filters: 0, Name: 'Czerwone Gitary - Wrocmy nad jeziora.mp3'.
    Total size: 76:56.20
23:53:55    #3 Text 0 File Burncd.cpp, Line 3133
    W***322;***261;czono Super Link
23:53:55    #4 Text 0 File AudioCompilationImpl.cpp, Line 838
    DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
    DRM: Beginning burn process.
23:53:55    #5 Text 0 File Burncd.cpp, Line 3435
    Turn on Disc-At-Once, using CD-R/RW media
23:53:55    #6 Text 0 File DlgWaitCD.cpp, Line 301
    Last possible write address on media:   359848 ( 79:59.73)
    Last address to be written:             346069 ( 76:56.19)
23:53:55    #7 Text 0 File DlgWaitCD.cpp, Line 313
23:53:55    #8 Text 0 File DlgWaitCD.cpp, Line 2863
    Recorder: TSSTcorp CDW/DVD TS-H492A;
       CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
       ATIP Data:
         Special    Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
         Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
23:53:55    #9 Text 0 File DlgWaitCD.cpp, Line 485
23:53:55    #10 Text 0 File ThreadedTransferInterface.cpp, Line 820
     0: TRM_AUDIO_NOPRE (Czerwone Gitary_Seweryn Krajewski - Najpiekniejsza.mp3)
        original disc pos #0 + 14486 (14486) = #14486/3:13.11
        relocatable, disc pos for caching/writing not required/not required, no patch infos
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14486 blocks [Main]
     1: TRM_AUDIO_NOPRE (Dwa Plus Jeden - Chod***378;, Pomaluj M***243;j ***346;wiat.mp3)
        original disc pos #0 + 13827 (13827) = #13827/3:4.27
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13827 blocks [Main]
     2: TRM_AUDIO_NOPRE (Dwa Plus Jeden - Jak Si***281; Masz, Kochanie.mp3)
        original disc pos #0 + 17193 (17193) = #17193/3:49.18
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17193 blocks [Main]
     3: TRM_AUDIO_NOPRE (Dwa plus Jeden - Wstawaj szkoda dnia.mp3)
        original disc pos #0 + 13273 (13273) = #13273/2:56.73
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13273 blocks [Main]
     4: TRM_AUDIO_NOPRE (Dwa plus jeden - Zegarmistrz ***347;wiat***322;a.mp3)
        original disc pos #0 + 23884 (23884) = #23884/5:18.34
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23884 blocks [Main]
     5: TRM_AUDIO_NOPRE (Dwa Plus Jeden-I***347;***263; W Stron***281; S***322;o***324;ca.mp3)
        original disc pos #0 + 19576 (19576) = #19576/4:21.1
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19576 blocks [Main]
     6: TRM_AUDIO_NOPRE (G***261;sowski Wojciech - Zielone wzg***243;rza nad Solin***261;.mp3)
        original disc pos #0 + 14942 (14942) = #14942/3:19.17
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14942 blocks [Main]
     7: TRM_AUDIO_NOPRE (Piotr Szczepanik - Dziewczyna, Ktora Kocham.mp3)
        original disc pos #0 + 16788 (16788) = #16788/3:43.63
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16788 blocks [Main]
     8: TRM_AUDIO_NOPRE (piotr szczepanik - goniac kormorany.mp3)
        original disc pos #0 + 14296 (14296) = #14296/3:10.46
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14296 blocks [Main]
     9: TRM_AUDIO_NOPRE (piotr szczepanik - kochac.mp3)
        original disc pos #0 + 16623 (16623) = #16623/3:41.48
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16623 blocks [Main]
    10: TRM_AUDIO_NOPRE (piotr szczepanik - nigdy wiecej.mp3)
        original disc pos #0 + 15242 (15242) = #15242/3:23.17
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15242 blocks [Main]
    11: TRM_AUDIO_NOPRE (Piotr Szczepanik - Zielone wzg***243;rza nad Solin***261;.mp3)
        original disc pos #0 + 15138 (15138) = #15138/3:21.63
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15138 blocks [Main]
    12: TRM_AUDIO_NOPRE (POLSKIE - Dwa Plus Jeden - Winda Do Nieba.mp3)
        original disc pos #0 + 20056 (20056) = #20056/4:27.31
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20056 blocks [Main]
    13: TRM_AUDIO_NOPRE (Seweryn Krajewski - Czerwone Gitary - Nie spoczniemy.mp3)
        original disc pos #0 + 17270 (17270) = #17270/3:50.20
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17270 blocks [Main]
    14: TRM_AUDIO_NOPRE (Wojciech G***261;sowski - Gdzie si***281; podzia***322;y tamte prywatki - disco polo.mp3)
        original disc pos #0 + 15050 (15050) = #15050/3:20.50
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15050 blocks [Main]
    15: TRM_AUDIO_NOPRE (Czerwone Gitary - Dzika plaza (1).mp3)
        original disc pos #0 + 13490 (13490) = #13490/2:59.65
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13490 blocks [Main]
    16: TRM_AUDIO_NOPRE (Czerwone Gitary - Jest Taki Dzien.mp3)
        original disc pos #0 + 12436 (12436) = #12436/2:45.61
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12436 blocks [Main]
    17: TRM_AUDIO_NOPRE (czerwone gitary - kwiaty we wlosach.mp3)
        original disc pos #0 + 10029 (10029) = #10029/2:13.54
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10029 blocks [Main]
    18: TRM_AUDIO_NOPRE (czerwone gitary - Nie licze godzin i lat.mp3)
        original disc pos #0 + 14821 (14821) = #14821/3:17.46
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14821 blocks [Main]
    19: TRM_AUDIO_NOPRE (czerwone gitary - niebo z moich stron.mp3)
        original disc pos #0 + 10928 (10928) = #10928/2:25.53
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10928 blocks [Main]
    20: TRM_AUDIO_NOPRE (Czerwone gitary - Uciekaj Moje Serce.mp3)
        original disc pos #0 + 16547 (16547) = #16547/3:40.47
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16547 blocks [Main]
    21: TRM_AUDIO_NOPRE (Czerwone Gitary - Wrocmy nad jeziora.mp3)
        original disc pos #0 + 17025 (17025) = #17025/3:47.0
        -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17025 blocks [Main]
23:53:55    #11 Text 0 File ThreadedTransferInterface.cpp, Line 1033
    Prepare recorder [TSSTcorp CDW/DVD TS-H492A] for write in CUE-sheet-DAO
    DAO infos:
     MCN: ""
     Tracks 1 to 22:                                  Idx 0         Idx 1      Next Trk
       1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800      34423872, ISRC ""
       2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      34423872      34776672      67297776, ISRC ""
       3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      67297776      67650576     108088512, ISRC ""
       4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     108088512     108441312     139659408, ISRC ""
       5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     139659408     140012208     196187376, ISRC ""
       6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     196187376     196540176     242582928, ISRC ""
       7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     242582928     242935728     278079312, ISRC ""
       8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     278079312     278432112     317917488, ISRC ""
       9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     317917488     318270288     351894480, ISRC ""
      10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     351894480     352247280     391344576, ISRC ""
      11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     391344576     391697376     427546560, ISRC ""
      12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     427546560     427899360     463503936, ISRC ""
      13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     463503936     463856736     511028448, ISRC ""
      14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     511028448     511381248     552000288, ISRC ""
      15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     552000288     552353088     587750688, ISRC ""
      16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     587750688     588103488     619831968, ISRC ""
      17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     619831968     620184768     649434240, ISRC ""
      18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     649434240     649787040     673375248, ISRC ""
      19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     673375248     673728048     708587040, ISRC ""
      20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     708587040     708939840     734642496, ISRC ""
      21: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     734642496     734995296     773913840, ISRC ""
      22: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     773913840     774266640     814309440, ISRC ""
    DAO layout:
     ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
         -150 |  lead-in |   0 |    0x01 |        0 |        0 | 0x00
         -150 |        1 |   0 |    0x21 |    14486 |     -150 | 0x00
            0 |        1 |   1 |    0x21 |    14486 |        0 | 0x00
        14486 |        2 |   0 |    0x21 |    13827 |    14486 | 0x00
        14636 |        2 |   1 |    0x21 |    13827 |    14636 | 0x00
        28463 |        3 |   0 |    0x21 |    17193 |    28463 | 0x00
        28613 |        3 |   1 |    0x21 |    17193 |    28613 | 0x00
        45806 |        4 |   0 |    0x21 |    13273 |    45806 | 0x00
        45956 |        4 |   1 |    0x21 |    13273 |    45956 | 0x00
        59229 |        5 |   0 |    0x21 |    23884 |    59229 | 0x00
        59379 |        5 |   1 |    0x21 |    23884 |    59379 | 0x00
        83263 |        6 |   0 |    0x21 |    19576 |    83263 | 0x00
        83413 |        6 |   1 |    0x21 |    19576 |    83413 | 0x00
       102989 |        7 |   0 |    0x21 |    14942 |   102989 | 0x00
       103139 |        7 |   1 |    0x21 |    14942 |   103139 | 0x00
       118081 |        8 |   0 |    0x21 |    16788 |   118081 | 0x00
       118231 |        8 |   1 |    0x21 |    16788 |   118231 | 0x00
       135019 |        9 |   0 |    0x21 |    14296 |   135019 | 0x00
       135169 |        9 |   1 |    0x21 |    14296 |   135169 | 0x00
       149465 |       10 |   0 |    0x21 |    16623 |   149465 | 0x00
       149615 |       10 |   1 |    0x21 |    16623 |   149615 | 0x00
       166238 |       11 |   0 |    0x21 |    15242 |   166238 | 0x00
       166388 |       11 |   1 |    0x21 |    15242 |   166388 | 0x00
       181630 |       12 |   0 |    0x21 |    15138 |   181630 | 0x00
       181780 |       12 |   1 |    0x21 |    15138 |   181780 | 0x00
       196918 |       13 |   0 |    0x21 |    20056 |   196918 | 0x00
       197068 |       13 |   1 |    0x21 |    20056 |   197068 | 0x00
       217124 |       14 |   0 |    0x21 |    17270 |   217124 | 0x00
       217274 |       14 |   1 |    0x21 |    17270 |   217274 | 0x00
       234544 |       15 |   0 |    0x21 |    15050 |   234544 | 0x00
       234694 |       15 |   1 |    0x21 |    15050 |   234694 | 0x00
       249744 |       16 |   0 |    0x21 |    13490 |   249744 | 0x00
       249894 |       16 |   1 |    0x21 |    13490 |   249894 | 0x00
       263384 |       17 |   0 |    0x21 |    12436 |   263384 | 0x00
       263534 |       17 |   1 |    0x21 |    12436 |   263534 | 0x00
       275970 |       18 |   0 |    0x21 |    10029 |   275970 | 0x00
       276120 |       18 |   1 |    0x21 |    10029 |   276120 | 0x00
       286149 |       19 |   0 |    0x21 |    14821 |   286149 | 0x00
       286299 |       19 |   1 |    0x21 |    14821 |   286299 | 0x00
       301120 |       20 |   0 |    0x21 |    10928 |   301120 | 0x00
       301270 |       20 |   1 |    0x21 |    10928 |   301270 | 0x00
       312198 |       21 |   0 |    0x21 |    16547 |   312198 | 0x00
       312348 |       21 |   1 |    0x21 |    16547 |   312348 | 0x00
       328895 |       22 |   0 |    0x21 |    17025 |   328895 | 0x00
       329045 |       22 |   1 |    0x21 |    17025 |   329045 | 0x00
       346070 | lead-out |   1 |    0x01 |        0 |        0 | 0x00
23:53:55    #12 Text 0 File SCSIPassThrough.cpp, Line 41
23:53:55    #13 Phase 36 File dlgbrnst.cpp, Line 1746
    Burn process started at 52x (7 800 KB/s)
23:53:55    #14 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
23:53:55    #15 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #14636
23:53:55    #16 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #28613
23:53:55    #17 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #45956
23:53:55    #18 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #59379
23:53:55    #19 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #83413
23:53:55    #20 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #103139
23:53:55    #21 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #118231
23:53:55    #22 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #135169
23:53:55    #23 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #149615
23:53:55    #24 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #166388
23:53:55    #25 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #181780
23:53:55    #26 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #197068
23:53:55    #27 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #217274
23:53:55    #28 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #234694
23:53:55    #29 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #249894
23:53:55    #30 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #263534
23:53:55    #31 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #276120
23:53:55    #32 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #286299
23:53:55    #33 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 19 (relocatable, no disc pos, no patch infos, orig at #0): write at #301270
23:53:55    #34 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 20 (relocatable, no disc pos, no patch infos, orig at #0): write at #312348
23:53:55    #35 Text 0 File ThreadedTransferInterface.cpp, Line 2730
    Verifying disc position of item 21 (relocatable, no disc pos, no patch infos, orig at #0): write at #329045
23:53:55    #36 Text 0 File MMC.cpp, Line 17509
    StartDAO : CD-Text - On
23:53:55    #37 Text 0 File MMC.cpp, Line 22124
    Set BUFE: Super Link -> ON
23:53:55    #38 Text 0 File MMC.cpp, Line 17739
    CueData, Len=368
    21 00 00 41 00 00 00 00
    21 01 00 00 00 00 00 00
    21 01 01 00 00 00 02 00
    21 02 00 00 00 03 0f 0b
    21 02 01 00 00 03 11 0b
    21 03 00 00 00 06 15 26
    21 03 01 00 00 06 17 26
    21 04 00 00 00 0a 0c 38
    21 04 01 00 00 0a 0e 38
    21 05 00 00 00 0d 0b 36
    21 05 01 00 00 0d 0d 36
    21 06 00 00 00 12 20 0d
    21 06 01 00 00 12 22 0d
    21 07 00 00 00 16 37 0e
    21 07 01 00 00 16 39 0e
    21 08 00 00 00 1a 10 1f
    21 08 01 00 00 1a 12 1f
    21 09 00 00 00 1e 02 13
    21 09 01 00 00 1e 04 13
    21 0a 00 00 00 21 0e 41
    21 0a 01 00 00 21 10 41
    21 0b 00 00 00 24 3a 26
    21 0b 01 00 00 25 00 26
    21 0c 00 00 00 28 17 37
    21 0c 01 00 00 28 19 37
    21 0d 00 00 00 2b 2f 2b
    21 0d 01 00 00 2b 31 2b
    21 0e 00 00 00 30 10 4a
    21 0e 01 00 00 30 12 4a
    21 0f 00 00 00 34 09 13
    21 0f 01 00 00 34 0b 13
    21 10 00 00 00 37 1f 45
    21 10 01 00 00 37 21 45
    21 11 00 00 00 3a 21 3b
    21 11 01 00 00 3a 23 3b
    21 12 00 00 00 3d 15 2d
    21 12 01 00 00 3d 17 2d
    21 13 00 00 00 3f 25 18
    21 13 01 00 00 3f 27 18
    21 14 00 00 00 42 38 46
    21 14 01 00 00 42 3a 46
    21 15 00 00 00 45 18 30
    21 15 01 00 00 45 1a 30
    21 16 00 00 00 49 07 14
    21 16 01 00 00 49 09 14
    01 aa 01 01 00 4c 38 14
23:56:21    #39 Text 0 File WriterStatus.cpp, Line 112
    <TSSTcorp CDW/DVD TS-H492A> start writing Lead-Out at LBA 346070 (547D6h), length 0 blocks
23:57:22    #40 Phase 37 File dlgbrnst.cpp, Line 1746
    Burn process completed successfully at 52x (7 800 KB/s)
23:57:22    #41 Text 0 File Burncd.cpp, Line 4764
    B***322;***261;d niedope***322;nienia bufora unikni***281;ty 1 raz(y)!
23:57:29    #42 Text 0 File AudioCompilationImpl.cpp, Line 863
    DRM: DRM burn session terminated.
23:57:29    #43 Text 0 File AudioCompilationImpl.cpp, Line 892
    DRM: Closing entire DRM handling. Bye.
23:57:37    #44 Text 0 File Cdrdrv.cpp, Line 10459
23:57:37    #45 Text 0 File SCSIPassThrough.cpp, Line 583
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.48 , size=24698 bytes, created 2004-02-24 09:55:20
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 1999-09-10 13:06:00
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-03-12 00:28:13 (Prassi/Veritas driver for win 2K)
Registry Keys:
Visca el Barca
Ostatnio zmieniany przez andy : 07.06.2007 o godz. 14:35
Jelcz jest offline   Odpowiedz cytując ten post
Wszystkie czasy w strefie CET. Aktualna godzina: 21:21.
