Data rejestracji: 20.12.2003
Yo
Mam problem z Nero (albo nagrywarka, boje sie, ze z tym drugim ![]() ![]() ![]() Oto obiecany log: Kod:
Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'd:\program files\ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-06-17 15:25:04 Nero version: 6.0.0.19 Recorder: <QSI CDRW/DVD SBW-241> Version: VX09 - HA 1 TA 0 - 6.0.0.19 Adapter driver: <atapi> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <QSI CDRW/DVD SBW-241>Version: VX09 - HA 1 TA 0 - 6.0.0.19 Adapter driver: <atapi> HA 1 === Scsi-Device-Map === DiskPeripheral : IC25N030ATMR04-0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : QSI CDRW/DVD SBW-241 atapi Port 1 ID 0 DMA: On DiskPeripheral : TOSHIBA THNCF064MMA atapi Port 2 ID 0 DMA: Off === CDRom-Device-Map === QSI CDRW/DVD SBW-241 K: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 40894464 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 255MB (261616kB) Free physical memory: 92MB (95116kB) Memory in use : 63 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 24.2.2004 CD-ROM (ISO) 10:18:03 #1 Text 0 File Isodoc.cpp, Line 5950 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 10:18:03 #2 Phase 88 File dlgbrnst.cpp, Line 1843 ExacLink activated 10:18:03 #3 Text 0 File Reader.cpp, Line 118 Reader running 10:18:03 #4 Text 0 File Writer.cpp, Line 127 Writer QSI CDRW/DVD SBW-241 running 10:18:03 #5 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) 10:18:03 #6 Text 0 File Burncd.cpp, Line 3198 Turn on Track-at-once, using CD-R/RW media 10:18:06 #7 Text 0 File DlgWaitCD.cpp, Line 230 Last possible write address on media: 359848 (79:59.73) Last address to be written: 230526 (51:15.51) 10:18:06 #8 Text 0 File DlgWaitCD.cpp, Line 235 Write in overburning mode: FALSE 10:18:06 #9 Text 0 File DlgWaitCD.cpp, Line 1949 Recorder: QSI CDRW/DVD SBW-241; CDRW code: 00 97 26 00; OSJ entry from: FORNET INTERNATIONAL PTE LTD. ATIP Data: Special Info [hex] 1: B3 00 CE, 2: 61 1A 00 (LI 97:26.00), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 24 1A D8, 2: 26 B2 4A, 3: 00 80 80 (invalid) 10:18:06 #10 Text 0 File DlgWaitCD.cpp, Line 394 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:18:06 #11 Text 0 File ThreadedTransferInterface.cpp, Line 769 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 230527 (230527) = #230527/51:13.52 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 230525 blocks [QSI CDRW/DVD SBW-241] -------------------------------------------------------------- 10:18:06 #12 Text 0 File ThreadedTransferInterface.cpp, Line 938 Prepare recorder [QSI CDRW/DVD SBW-241] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 472426496, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 230527 | lead-out | 1 | 0x00 | 0x41 10:18:06 #13 Text 0 File ThreadedTransferInterface.cpp, Line 965 Removed 2 run-out blocks from end of track 1. 10:18:06 #14 Phase 24 File dlgbrnst.cpp, Line 1843 Caching of files started 10:18:07 #15 Phase 25 File dlgbrnst.cpp, Line 1843 Caching of files completed 10:18:07 #16 Phase 36 File dlgbrnst.cpp, Line 1843 Burn process started at 4x (600 KB/s) 10:18:07 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2136 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 10:18:08 #18 Text 0 File Mmc.cpp, Line 19195 Set BUFE: ExacLink -> ON 10:20:41 #19 SCSI -1135 File Cdrdrv.cpp, Line 1413 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04330000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0xB1 0x80 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x0C 0x00 10:20:41 #20 CDR -1135 File Writer.cpp, Line 335 Write error 10:20:41 #21 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:20:41 #22 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 10:20:41 #23 CDR -201 File WriterStatus.cpp, Line 193 Invalid write state QSI CDRW/DVD SBW-241\H1 T0 10:20:41 #24 TRANSFER -18 File WriterStatus.cpp, Line 193 Could not perform EndTrack 10:20:41 #25 Text 0 File Mmc.cpp, Line 14149 <QSI CDRW/DVD SBW-241> start Close Session 10:20:41 #26 Text 0 File dlgbrnst.cpp, Line 1703 Set remaining time: 0:00,000 (0ms) -> OK 10:20:41 #27 Phase 38 File dlgbrnst.cpp, Line 1843 Burn process failed at 4x (600 KB/s) Existing drivers: File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 21:51:54 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) maciejkiner |
Data rejestracji: 24.02.2004
Mam dokladnie taki sam problem. Combo Samsunga na ktorym pracuje posypalo mi sie niestety
Ok.... cos nowego.... nagralem przed chwila plytke (230mb) - poszlo bez problemu... wiekszej nie chce ruszyc.... Oso chosiii
Yo
U mnie dramatyzm poteguj to, ze jest to integra w notebooku. Komp na gwarancji, ale z tego co wiem, jak bede oddawac naped to z reszta maszyny a jest mi ona bardziej niz koniecznie potrzebna... Powiedzcie mi, ze to jakis vir or smth, bo sie zastrzele :/ A plytki wywala tak miedzy 10 a 20%. Pewnie jakbym nagrywal mniejsze (np 200mb) to moglo by przejsc... pzdr maciejkiner |
Powiedz tylko ze masz Maxdate 1000T.... to juz bede wiedzial ze do kazdego laduja takie cholerstwo... U mnie tez to combo siedzi w laptopie.
Data rejestracji: 25.11.2003
Masz gwarancje? Jak masz to oddaj, na 99% ci wymienia na nowe.
Two beers or not two beers? |
Yo
Nie mam Maxdaty. Mam Actine... Gwarancje mam, ale musze tak zamotac, zeby oddac sam naped bo bez kompa ani rusz niestety :/ pzdr maciejkiner Ostatnio zmieniany przez maciejkiner : 26.02.2004 o godz. 16:34 |
Data rejestracji: 24.10.2003
Sprubójcie zainstalować aspi
Yo
Zainstalwoalem ASPI dostapene tu na stronie glownej w dziale pliki i nadal to samo :/ Zreszta juz kiedys kombinowalem z ASPI, roznymi programami do nagrywania i ciagle bylo to samo ![]() pzdr maciejkiner |
Yo
Zrobilem tak: zainstalowalem ASPI wywalilem XPkowska usluge nagrywania i nagralo mi plytke :/ Teraz musze porobic testy czy to fux czy juz tak bedzie... pzdr maciejkiner |
