Stary 03.02.2006, 19:39   #1
oJej
Data rejestracji: 03.02.2006
oJej w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Question Problem TEAC CD-W516EB
Mam problem z wypalarka TEAC CD-W516EB, pasek stanu dochodzi do 6% i nagrywarka dostaje "czkawki"
Mam win xp mc sp2 ,nero 7.0.1.4 poprzednio mialem 6.x.x.x i bylo to samo, bios 1,0b
Prosze o pomoc, z gory thx i pozdro
Logi z proby nagrania
1C80001080100000000248442262
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
Recorder: <TEAC CD-W516EB> Version: 1.0B - HA 1 TA 0 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 1456kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 1 TA 3 - 7.0.1.4
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-00CAA1 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W516EB atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : E-IDE CD-ROM 48X/AKU atapi Port 1 ID 1 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 st3shark Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 st3shark Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
Generic DVD-ROM F: CDRom3
Generic DVD-ROM H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 89MB (91596kB)
Memory in use : 82 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
3.2.2006
CD-ROM (ISO)
17:40:53 #1 Text 0 File Isodoc.cpp, Line 6411
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
17:40:53 #2 Text 0 File Burncd.cpp, Line 3048
TEAC CD-W516EB
BURN-Proof activated
17:40:53 #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 72704KB of Memory
17:40:53 #4 Text 0 File Reader.cpp, Line 124
Reader running
17:40:53 #5 Text 0 File Writer.cpp, Line 113
Writer E: TEAC CD-W516EB running
17:40:53 #6 ISO9660GEN -11 File Geniso.cpp, Line 3312
17:40:54 #7 Text 0 File Burncd.cpp, Line 3342
Turn on Track-At-Once, using CD-R/RW media
17:40:54 #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 298504 ( 66:22.04)
17:40:54 #9 Text 0 File DlgWaitCD.cpp, Line 291
17:40:54 #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: TEAC CD-W516EB;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid)
17:40:54 #11 Text 0 File DlgWaitCD.cpp, Line 458
17:40:54 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 ()
original disc pos #0 + 298505 (298505) = #298505/66:20.5
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 298503 blocks [E: TEAC CD-W516EB]
17:40:54 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: TEAC CD-W516EB] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 611645440, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
298505 | lead-out | 1 | 0x41 | 0x00
17:40:54 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127
Removed 2 run-out blocks from end of track 1. Length: 298505 -> 298503.
17:40:54 #15 Text 0 File SCSIPassThrough.cpp, Line 36
17:40:54 #16 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
17:40:54 #17 Text 0 File Burncd.cpp, Line 4176
Cache writing successful.
17:40:54 #18 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
17:40:54 #19 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 16x (2*400 KB/s)
17:40:54 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
17:43:08 #21 SPTI -600 File SCSIPassThrough.cpp, Line 323
E: CdRom0: SCSIStatus(x00) WinError(55) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0a4a0000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
17:43:08 #22 CDR -600 File Writer.cpp, Line 302
Device not available
E: TEAC CD-W516EB
17:43:08 #23 Text 0 File ThreadedTransfer.cpp, Line 228
17:43:08 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
17:43:09 #25 SPTI -500 File SCSIPassThrough.cpp, Line 323
E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x35 00 00 00 00 00 00 00 00 00 00 00
17:43:09 #26 SPTI -500 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Buffer x049ac000: Len x20
17:43:09 #27 SPTI -500 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
17:43:09 #28 CDR -500 File WriterStatus.cpp, Line 197
SCSI command aborted
E: TEAC CD-W516EB
17:43:09 #29 TRANSFER -18 File WriterStatus.cpp, Line 197
Could not perform EndTrack
17:43:09 #30 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
E: TEAC CD-W516EB
17:43:09 #31 TRANSFER -18 File WriterStatus.cpp, Line 200
17:43:09 #32 SPTI -500 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5A 00 05 00 00 00 00 00 48 00
Buffer x049acc00: Len x48
17:43:09 #33 CDR -500 File WriterStatus.cpp, Line 249
E: TEAC CD-W516EB
17:43:09 #34 TRANSFER -19 File WriterStatus.cpp, Line 249
Could not perform Fixation
17:43:09 #35 Text 0 File WriterStatus.cpp, Line 258
falling back to disc fixation
17:43:09 #36 SPTI -500 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
17:43:09 #37 CDR -500 File WriterStatus.cpp, Line 249
E: TEAC CD-W516EB
17:43:09 #38 TRANSFER -19 File WriterStatus.cpp, Line 249
17:43:09 #39 SPTI -500 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
17:43:09 #40 SPTI -600 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
17:43:10 #41 SPTI -600 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
17:43:11 #42 CDR -600 File WriterStatus.cpp, Line 172
E: TEAC CD-W516EB
17:43:11 #43 TRANSFER -39 File WriterStatus.cpp, Line 172
Could not perform EndSession
17:43:11 #44 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 16x (2*400 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.26a, size=20576 bytes, created 2005-05-12 18:54:10 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-10 07:00:00 (Adapter driver for src)
Registry Keys:
oJej jest offline
Stary 03.02.2006, 20:05   #2
Maciej
Avatar użytkownika Maciej
włącz DMA, może zniknie "czkawka"
Jak mądrze zadawać pytania
Maciej jest offline
Stary 03.02.2006, 20:24   #3
oJej
Probowalej juz z dma i jest to samo
oJej jest offline
Stary 03.02.2006, 21:03   #4
to wlacz DMA i zainstaluj ForceASPI
icemac jest offline
Stary 04.02.2006, 20:17   #5
esem
OldBoy
Avatar użytkownika esem
Data rejestracji: 18.05.2002
ForceAspi pomoże tyle co umarłemu kadzidło...
Dlaczego nagrywasz w TAO ? Masz jakieś powody ? Spróbuj w DAO.
A tak w ogóle to spróbuj odpuścić sobie Nero 7.xx. Jest na tyle kontrowersyjny, że ja jeszcze nawet nie próbowałem go zakładać...
Sprawdzam najpierw na szczurach - per saldo wychodzi taniej.
ASUS DRW-24B3LT
esem jest offline
Stary 05.02.2006, 02:51   #6
oJej
w DAO jest to samo bo juz probowalem, wczesniej mialem nero 6,x,x,x i bylo to samo, u kumpla moja nagrywarka zachowuje sie tak samo ,wydaje mi sie ze juz padla
oJej jest offline
Stary 05.02.2006, 09:55   #7
Maciej
przeinstaluj sterowniki do płyty głównej.
dla pewności można sprawdzić nagrywarkę na innym kompie.
Maciej jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 22:53.
