Problem TEAC CD-W516EB
Mam problem z wypalarka TEAC CD-W516EB, pasek stanu dochodzi do 6% i nagrywarka dostaje "czkawki" Mam win xp mc sp2 ,nero 7.0.1.4 poprzednio mialem 6.x.x.x i bylo to samo, bios 1,0b Prosze o pomoc, z gory thx i pozdro Logi z proby nagrania 1C80001080100000000248442262 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32 NT-SPTI used Nero Version: 7.0.1.4 Internal Version: 7, 0, 1, 4 Recorder: <TEAC CD-W516EB> Version: 1.0B - HA 1 TA 0 - 7.0.1.4 Adapter driver: <IDE> HA 1 Drive buffer : 1456kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 1 TA 3 - 7.0.1.4 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD800BB-00CAA1 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TEAC CD-W516EB atapi Port 1 ID 0 DMA: Off CdRomPeripheral : E-IDE CD-ROM 48X/AKU atapi Port 1 ID 1 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 st3shark Port 2 ID 0 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 st3shark Port 2 ID 1 DMA: Off === CDRom-Device-Map === Generic DVD-ROM F: CDRom3 Generic DVD-ROM H: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 89MB (91596kB) Memory in use : 82 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 3.2.2006 CD-ROM (ISO) 17:40:53 #1 Text 0 File Isodoc.cpp, Line 6411 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 17:40:53 #2 Text 0 File Burncd.cpp, Line 3048 TEAC CD-W516EB BURN-Proof activated 17:40:53 #3 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 72704KB of Memory 17:40:53 #4 Text 0 File Reader.cpp, Line 124 Reader running 17:40:53 #5 Text 0 File Writer.cpp, Line 113 Writer E: TEAC CD-W516EB running 17:40:53 #6 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 17:40:54 #7 Text 0 File Burncd.cpp, Line 3342 Turn on Track-At-Once, using CD-R/RW media 17:40:54 #8 Text 0 File DlgWaitCD.cpp, Line 279 Last possible write address on media: 359845 ( 79:59.70) Last address to be written: 298504 ( 66:22.04) 17:40:54 #9 Text 0 File DlgWaitCD.cpp, Line 291 Write in overburning mode: NO (enabled: CD) 17:40:54 #10 Text 0 File DlgWaitCD.cpp, Line 2578 Recorder: TEAC CD-W516EB; CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation ATIP Data: Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid) 17:40:54 #11 Text 0 File DlgWaitCD.cpp, Line 458 >>> Protocol of DlgWaitCD activities: <<< ========================================= 17:40:54 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 298505 (298505) = #298505/66:20.5 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 298503 blocks [E: TEAC CD-W516EB] -------------------------------------------------------------- 17:40:54 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: TEAC CD-W516EB] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 611645440, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 298505 | lead-out | 1 | 0x41 | 0x00 17:40:54 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127 Removed 2 run-out blocks from end of track 1. Length: 298505 -> 298503. 17:40:54 #15 Text 0 File SCSIPassThrough.cpp, Line 36 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 17:40:54 #16 Phase 24 File dlgbrnst.cpp, Line 1725 Caching of files started 17:40:54 #17 Text 0 File Burncd.cpp, Line 4176 Cache writing successful. 17:40:54 #18 Phase 25 File dlgbrnst.cpp, Line 1725 Caching of files completed 17:40:54 #19 Phase 36 File dlgbrnst.cpp, Line 1725 Burn process started at 16x (2*400 KB/s) 17:40:54 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 17:43:08 #21 SPTI -600 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x0a4a0000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17:43:08 #22 CDR -600 File Writer.cpp, Line 302 Device not available E: TEAC CD-W516EB 17:43:08 #23 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 17:43:08 #24 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 17:43:09 #25 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x35 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 17:43:09 #26 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049ac000: Len x20 17:43:09 #27 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 17:43:09 #28 CDR -500 File WriterStatus.cpp, Line 197 SCSI command aborted E: TEAC CD-W516EB 17:43:09 #29 TRANSFER -18 File WriterStatus.cpp, Line 197 Could not perform EndTrack 17:43:09 #30 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state E: TEAC CD-W516EB 17:43:09 #31 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 17:43:09 #32 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049acc00: Len x48 17:43:09 #33 CDR -500 File WriterStatus.cpp, Line 249 SCSI command aborted E: TEAC CD-W516EB 17:43:09 #34 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 17:43:09 #35 Text 0 File WriterStatus.cpp, Line 258 falling back to disc fixation 17:43:09 #36 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049acc00: Len x48 17:43:09 #37 CDR -500 File WriterStatus.cpp, Line 249 SCSI command aborted E: TEAC CD-W516EB 17:43:09 #38 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 17:43:09 #39 SPTI -500 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x00) WinError(22) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049acc00: Len x48 17:43:09 #40 SPTI -600 File SCSIPassThrough.cpp, Line 323 CdRom0: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049acc00: Len x48 17:43:10 #41 SPTI -600 File SCSIPassThrough.cpp, Line 323 CdRom0: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x049acc00: Len x48 17:43:11 #42 CDR -600 File WriterStatus.cpp, Line 172 Device not available E: TEAC CD-W516EB 17:43:11 #43 TRANSFER -39 File WriterStatus.cpp, Line 172 Could not perform EndSession 17:43:11 #44 Phase 38 File dlgbrnst.cpp, Line 1725 Burn process failed at 16x (2*400 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.03.26a, size=20576 bytes, created 2005-05-12 18:54:10 (Prassi/Veritas driver for win 2K) File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-10 07:00:00 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
Probowalej juz z dma i jest to samo
to wlacz DMA i zainstaluj ForceASPI
ForceAspi pomoże tyle co umarłemu kadzidło...
Dlaczego nagrywasz w TAO ? Masz jakieś powody ? Spróbuj w DAO. A tak w ogóle to spróbuj odpuścić sobie Nero 7.xx. Jest na tyle kontrowersyjny, że ja jeszcze nawet nie próbowałem go zakładać... Sprawdzam najpierw na szczurach - per saldo wychodzi taniej. |
w DAO jest to samo bo juz probowalem, wczesniej mialem nero 6,x,x,x i bylo to samo, u kumpla moja nagrywarka zachowuje sie tak samo ,wydaje mi sie ze juz padla
przeinstaluj sterowniki do płyty głównej.
dla pewności można sprawdzić nagrywarkę na innym kompie. |
Wszystkie czasy w strefie CET. Aktualna godzina: 01:33. |
