Stary 02.06.2007, 14:39   #1
noe
Data rejestracji: 02.06.2007
noe w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z wypalaniem CD na Pioneer DVDR-112D
Witam,
Kupiłem niedawno nagrywarkę Pioneer DVDR-112D i mam duże problemy z nagrywaniem CD i CD-RW. DVD nagrywa bez problemu.
Probowałem wypalić w Nero TDK CD-R80 przy 32x i po dojściu do 8% wywaliło błąd.
Oto log z tej operacji:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
Recorder: <PIONEER DVD-RW DVR-112D>Version: 1.21 - HA 1 TA 0 - 7.7.5.1
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <QY1948C MWO107C >Version: 1.0 - HA 1 TA 2 - 7.7.5.1
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0822N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITEON DVD-ROM LTD163 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : QY1948C MWO107C 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITEON DVD-ROM LTD163 G: CDRom1
PIONEER DVD-RW DVR-112D H: CDRom0
QY1948C MWO107C J: CDRom2
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1022MB (1047280kB)
Free physical memory: 371MB (380580kB)
Memory in use : 63 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
2.6.2007
CD-ROM (ISO)
12:53:18 #1 Text 0 File SCSIPTICommands.cpp, Line 411
12:53:18 #2 Text 0 File Isodoc.cpp, Line 6527
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
12:53:18 #3 Text 0 File Burncd.cpp, Line 3163
Buffer underrun protection activated
12:53:18 #4 ISO9660GEN -11 File Geniso.cpp, Line 3334
12:53:18 #5 Text 0 File Burncd.cpp, Line 3465
Turn on Disc-At-Once, using CD-R/RW media
12:53:19 #6 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 272831 ( 60:39.56)
12:53:19 #7 Text 0 File DlgWaitCD.cpp, Line 318
12:53:19 #8 Text 0 File DlgWaitCD.cpp, Line 2912
Recorder: PIONEER DVD-RW DVR-112D;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
12:53:19 #9 Text 0 File DlgWaitCD.cpp, Line 490
12:53:19 #10 Text 0 File ThreadedTransferInterface.cpp, Line 823
0: TRM_DATA_MODE1 ()
original disc pos #0 + 272832 (272832) = #272832/60:37.57
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 272832 blocks [H: PIONEER DVD-RW DVR-112D]
12:53:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1026
Prepare [H: PIONEER DVD-RW DVR-112D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 559067136, ISRC ""
DAO layout:
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 272832 | -150 | 0x00
0 | 1 | 1 | 0x41 | 272832 | 0 | 0x00
272832 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
12:53:19 #12 Text 0 File SCSIPTICommands.cpp, Line 209
12:53:19 #13 Phase 24 File dlgbrnst.cpp, Line 1760
Caching of files started
12:53:19 #14 Text 0 File Burncd.cpp, Line 4298
Cache writing successful.
12:53:19 #15 Phase 25 File dlgbrnst.cpp, Line 1760
Caching of files completed
12:53:19 #16 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 32x (4800 KB/s)
12:53:19 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2764
12:53:19 #18 Text 0 File MMC.cpp, Line 17584
StartDAO : CD-Text - Off
12:53:19 #19 Text 0 File MMC.cpp, Line 22250
Set BUFE: Buffer underrun protection -> ON
12:53:20 #20 Text 0 File MMC.cpp, Line 17812
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 3c 27 39
12:53:23 #21 Text 0 File Cdrdrv.cpp, Line 1303
12:53:23.125 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #22 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.484 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #23 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.500 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #24 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.515 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #25 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.546 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #26 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.562 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #27 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.593 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #28 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.625 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #29 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.640 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #30 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.671 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #31 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.687 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #32 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.718 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #33 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.734 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #34 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.765 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #35 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.781 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #36 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.843 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #37 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.859 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #38 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.890 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #39 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.906 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #40 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.937 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #41 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.968 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:51 #42 Text 0 File Cdrdrv.cpp, Line 1303
12:53:51.984 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #43 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.015 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #44 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.031 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #45 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.062 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #46 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.078 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #47 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.109 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #48 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.187 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #49 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.203 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #50 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.234 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #51 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.250 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #52 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.281 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #53 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.296 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #54 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.328 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #55 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.343 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #56 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.375 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #57 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.390 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #58 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.421 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #59 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.500 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #60 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.515 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #61 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.546 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #62 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.562 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #63 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.593 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #64 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.609 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #65 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.640 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #66 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.656 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #67 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.687 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #68 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.703 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #69 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.734 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #70 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.812 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #71 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.828 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #72 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.859 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #73 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.875 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #74 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.906 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #75 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.921 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #76 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.953 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:52 #77 Text 0 File Cdrdrv.cpp, Line 1303
12:53:52.968 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #78 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.000 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #79 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.015 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #80 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.046 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #81 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.125 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #82 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.140 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #83 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.171 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #84 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.187 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #85 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.218 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #86 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.234 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #87 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.265 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #88 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.281 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #89 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.312 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #90 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.343 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #91 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.359 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #92 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.437 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #93 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.453 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #94 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.484 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #95 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.500 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #96 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.531 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #97 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.546 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #98 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.578 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #99 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.593 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #100 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.625 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #101 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.640 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #102 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.671 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #103 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.750 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #104 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.765 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #105 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.796 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #106 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.812 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #107 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.843 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #108 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.859 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #109 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.890 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #110 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.906 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #111 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.937 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #112 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.953 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:53 #113 Text 0 File Cdrdrv.cpp, Line 1303
12:53:53.984 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #114 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.046 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #115 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.078 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #116 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.109 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #117 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.125 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #118 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.156 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #119 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.171 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:53:54 #120 Text 0 File Cdrdrv.cpp, Line 1303
12:53:54.203 - H: PIONEER DVD-RW DVR-112D : Queue again later
12:54:00 #121 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 2C A0 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 02 32 65 0E 00 00 00 00 0C
Buffer x0a1e5980: Len x10000
0xCD FF FF F2 06 76 16 60 68 14 17 22 2A 4A 23 38
0xDF FF FF 4F 4A 60 01 02 65 48 7B A6 96 47 CC 07
0x60 F5 6A 48 BD 2B 26 31 FF FB 80 64 09 80 13 74
12:54:00 #122 CDR -1135 File Writer.cpp, Line 301
Write error
12:54:00 #123 SPTI -1046 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x00
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0E 00 00 00 00 30
12:54:00 #124 CDR -1046 File WriterStatus.cpp, Line 162
Illegal disc
12:54:00 #125 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
12:54:00 #126 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 32x (4800 KB/s)
12:54:01 #127 Text 0 File SCSIPTICommands.cpp, Line 254
12:54:04 #128 Text 0 File Cdrdrv.cpp, Line 10529
12:54:04 #129 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
Registry Keys:
Próbowałem też wypalać na Platinum CD-R700 przy 4x i to samo przy 8% pojawia się błąd. Verbatimów CD-RW700 nagrywarka wogóle nie widzi i nie da się ich ani zmazać ani zapisać. Firmware mam najnowszy 1.21.
Proszę o pomoc Nie wiem czy oddać nagryware do reklamacji czy coś można na to poradzić?
Pozdro,
noe jest offline
Stary 02.06.2007, 14:44   #2
Bródka
Technik Informatyk
Avatar użytkownika Bródka
Data rejestracji: 22.01.2005
Powiedz po co nagrywasz plyty cd tak wolno ?
Masz moze zainstalowanego alcohola jak tak wylacz ukrywanie ATIP
Kup lepsze plytki np Sony, Verbatim mam tu na mysli CD-R
Optiarc AD-7703S v1.03
Mój Mondek - PolskaJazda.pl
Bródka jest offline
Stary 02.06.2007, 14:52   #3
Prezesik
Człekokształtny
Avatar użytkownika Prezesik
Data rejestracji: 27.12.2004
Tak jak pisa***322; kolega, pokombinuj z no***347;nikami
cho***263; TDK nie s***261; takie z***322;e
ale r***243;***380;nie bywa i mo***380;na trafi***263; na parti***281;, kt***243;ra b***281;dzie ca***322;a do wyrzucenia
CD-RW -> poszukaj ATIP
-edit-
aha jeszcze jedno..
w logu pojawia si***281; 'KEY_MEDIUM_ERROR' czyli b***322;***261;d no***347;nika. mo***380;liwe, ***380;e nagrywasz za wolno co przy nowych p***322;ytach nie jest dobrym pomys***322;em
Seny, pit i collons!
Ostatnio zmieniany przez Prezesik : 02.06.2007 o godz. 15:04
Prezesik jest offline
Stary 02.06.2007, 16:02   #4
noe
No wi***281;c tak:
- mam zainstalowanego alcohola i opcja "ignore media type" (odpowiedzialna za wy***322;***261;czenie ATIP) jest odznaczona,
- normalnie cd nagrywam z pr***281;dko***347;ci***261; max ale w przypadku tego pioneera zacz***261;***322;em pr***243;bowa***263; z mniejszymi pr***281;dko***347;ciami, bo na max wywala***322; b***322;***281;dy, niestety nie mam log***243;w z tych pierwszych wypa***322;***243;w,
- co do tdk-***243;w to ju***380; resztka cake-a wi***281;kszo***347;***263; wypali***322;em na Sony CD-RW CRX216E i nie by***322;o ***380;adnych problem***243;w,
noe jest offline
Stary 02.06.2007, 17:38   #5
Grześiu748
Spamerzyna
Avatar użytkownika Grześiu748
Data rejestracji: 24.09.2006
No c***243;z... Czyli wina no***347;nika. Nawet w dobrych p***322;ytach znajdzie si***281; partia, kt***243;ra jest (przepraszam za wyra***380;enie) do d..y
Grześiu748 jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 14:34.
