Data rejestracji: 02.06.2007
Problem z wypalaniem CD na Pioneer DVDR-112D
Witam,
Kupiłem niedawno nagrywarkę Pioneer DVDR-112D i mam duże problemy z nagrywaniem CD i CD-RW. DVD nagrywa bez problemu.Probowałem wypalić w Nero TDK CD-R80 przy 32x i po dojściu do 8% wywaliło błąd. Oto log z tej operacji: Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.7.5.1 Internal Version: 7, 7, 5, 1 Recorder: <PIONEER DVD-RW DVR-112D>Version: 1.21 - HA 1 TA 0 - 7.7.5.1 Adapter driver: <IDE> HA 1 Drive buffer : 2000kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <QY1948C MWO107C >Version: 1.0 - HA 1 TA 2 - 7.7.5.1 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SP0822N atapi Port 0 ID 0 DMA: On CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 1 ID 0 DMA: On CdRomPeripheral : LITEON DVD-ROM LTD163 atapi Port 1 ID 1 DMA: On CdRomPeripheral : QY1948C MWO107C 1.0 dtscsi Port 2 ID 0 DMA: Off === CDRom-Device-Map === LITEON DVD-ROM LTD163 G: CDRom1 PIONEER DVD-RW DVR-112D H: CDRom0 QY1948C MWO107C J: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1022MB (1047280kB) Free physical memory: 371MB (380580kB) Memory in use : 63 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 2.6.2007 CD-ROM (ISO) 12:53:18 #1 Text 0 File SCSIPTICommands.cpp, Line 411 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 12:53:18 #2 Text 0 File Isodoc.cpp, Line 6527 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 12:53:18 #3 Text 0 File Burncd.cpp, Line 3163 PIONEER DVD-RW DVR-112D Buffer underrun protection activated 12:53:18 #4 ISO9660GEN -11 File Geniso.cpp, Line 3334 First writeable address = 0 (0x00000000) 12:53:18 #5 Text 0 File Burncd.cpp, Line 3465 Turn on Disc-At-Once, using CD-R/RW media 12:53:19 #6 Text 0 File DlgWaitCD.cpp, Line 306 Last possible write address on media: 359845 ( 79:59.70) Last address to be written: 272831 ( 60:39.56) 12:53:19 #7 Text 0 File DlgWaitCD.cpp, Line 318 Write in overburning mode: NO (enabled: CD) 12:53:19 #8 Text 0 File DlgWaitCD.cpp, Line 2912 Recorder: PIONEER DVD-RW DVR-112D; CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation ATIP Data: Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid) 12:53:19 #9 Text 0 File DlgWaitCD.cpp, Line 490 >>> Protocol of DlgWaitCD activities: <<< ========================================= 12:53:19 #10 Text 0 File ThreadedTransferInterface.cpp, Line 823 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 272832 (272832) = #272832/60:37.57 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 272832 blocks [H: PIONEER DVD-RW DVR-112D] -------------------------------------------------------------- 12:53:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1026 Prepare [H: PIONEER DVD-RW DVR-112D] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 559067136, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x41 | 272832 | -150 | 0x00 0 | 1 | 1 | 0x41 | 272832 | 0 | 0x00 272832 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 12:53:19 #12 Text 0 File SCSIPTICommands.cpp, Line 209 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 12:53:19 #13 Phase 24 File dlgbrnst.cpp, Line 1760 Caching of files started 12:53:19 #14 Text 0 File Burncd.cpp, Line 4298 Cache writing successful. 12:53:19 #15 Phase 25 File dlgbrnst.cpp, Line 1760 Caching of files completed 12:53:19 #16 Phase 36 File dlgbrnst.cpp, Line 1760 Burn process started at 32x (4800 KB/s) 12:53:19 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2764 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 12:53:19 #18 Text 0 File MMC.cpp, Line 17584 StartDAO : CD-Text - Off 12:53:19 #19 Text 0 File MMC.cpp, Line 22250 Set BUFE: Buffer underrun protection -> ON 12:53:20 #20 Text 0 File MMC.cpp, Line 17812 CueData, Len=32 41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00 41 01 01 10 00 00 02 00 41 aa 01 14 00 3c 27 39 12:53:23 #21 Text 0 File Cdrdrv.cpp, Line 1303 12:53:23.125 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #22 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.484 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #23 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.500 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #24 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.515 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #25 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.546 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #26 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.562 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #27 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.593 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #28 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.625 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #29 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.640 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #30 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.671 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #31 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.687 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #32 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.718 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #33 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.734 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #34 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.765 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #35 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.781 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #36 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.843 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #37 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.859 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #38 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.890 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #39 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.906 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #40 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.937 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #41 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.968 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:51 #42 Text 0 File Cdrdrv.cpp, Line 1303 12:53:51.984 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #43 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.015 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #44 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.031 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #45 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.062 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #46 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.078 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #47 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.109 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #48 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.187 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #49 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.203 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #50 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.234 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #51 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.250 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #52 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.281 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #53 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.296 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #54 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.328 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #55 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.343 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #56 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.375 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #57 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.390 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #58 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.421 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #59 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.500 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #60 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.515 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #61 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.546 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #62 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.562 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #63 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.593 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #64 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.609 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #65 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.640 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #66 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.656 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #67 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.687 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #68 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.703 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #69 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.734 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #70 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.812 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #71 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.828 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #72 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.859 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #73 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.875 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #74 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.906 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #75 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.921 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #76 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.953 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:52 #77 Text 0 File Cdrdrv.cpp, Line 1303 12:53:52.968 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #78 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.000 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #79 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.015 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #80 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.046 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #81 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.125 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #82 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.140 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #83 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.171 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #84 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.187 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #85 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.218 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #86 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.234 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #87 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.265 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #88 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.281 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #89 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.312 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #90 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.343 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #91 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.359 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #92 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.437 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #93 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.453 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #94 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.484 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #95 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.500 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #96 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.531 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #97 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.546 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #98 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.578 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #99 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.593 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #100 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.625 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #101 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.640 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #102 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.671 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #103 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.750 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #104 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.765 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #105 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.796 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #106 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.812 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #107 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.843 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #108 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.859 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #109 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.890 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #110 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.906 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #111 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.937 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #112 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.953 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:53 #113 Text 0 File Cdrdrv.cpp, Line 1303 12:53:53.984 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #114 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.046 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #115 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.078 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #116 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.109 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #117 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.125 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #118 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.156 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #119 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.171 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:53:54 #120 Text 0 File Cdrdrv.cpp, Line 1303 12:53:54.203 - H: PIONEER DVD-RW DVR-112D : Queue again later 12:54:00 #121 SPTI -1135 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 2C A0 00 00 20 00 00 00 Sense Area: 0x71 00 03 00 02 32 65 0E 00 00 00 00 0C Buffer x0a1e5980: Len x10000 0xCD FF FF F2 06 76 16 60 68 14 17 22 2A 4A 23 38 0xDF FF FF 4F 4A 60 01 02 65 48 7B A6 96 47 CC 07 0x60 F5 6A 48 BD 2B 26 31 FF FB 80 64 09 80 13 74 12:54:00 #122 CDR -1135 File Writer.cpp, Line 301 Write error H: PIONEER DVD-RW DVR-112D 12:54:00 #123 SPTI -1046 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x30 Sense Qual: 0x00 CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 02 00 00 00 00 0E 00 00 00 00 30 12:54:00 #124 CDR -1046 File WriterStatus.cpp, Line 162 Illegal disc H: PIONEER DVD-RW DVR-112D 12:54:00 #125 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 12:54:00 #126 Phase 38 File dlgbrnst.cpp, Line 1760 Burn process failed at 32x (4800 KB/s) 12:54:01 #127 Text 0 File SCSIPTICommands.cpp, Line 254 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 12:54:04 #128 Text 0 File Cdrdrv.cpp, Line 10529 DriveLocker: UnLockVolume completed 12:54:04 #129 Text 0 File SCSIPTICommands.cpp, Line 411 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Próbowałem też wypalać na Platinum CD-R700 przy 4x i to samo przy 8% pojawia się błąd. Verbatimów CD-RW700 nagrywarka wogóle nie widzi i nie da się ich ani zmazać ani zapisać. Firmware mam najnowszy 1.21. Proszę o pomoc Nie wiem czy oddać nagryware do reklamacji czy coś można na to poradzić ?Pozdro, |
Technik Informatyk
Data rejestracji: 22.01.2005
Powiedz po co nagrywasz plyty cd tak wolno ?
Masz moze zainstalowanego alcohola jak tak wylacz ukrywanie ATIP Kup lepsze plytki np Sony, Verbatim mam tu na mysli CD-R |
Człekokształtny
Data rejestracji: 27.12.2004
Tak jak pisa***322; kolega, pokombinuj z no***347;nikami
![]() cho***263; TDK nie s***261; takie z***322;e ![]() ale r***243;***380;nie bywa i mo***380;na trafi***263; na parti***281;, kt***243;ra b***281;dzie ca***322;a do wyrzucenia CD-RW -> poszukaj ATIP ![]() -edit- aha jeszcze jedno.. w logu pojawia si***281; 'KEY_MEDIUM_ERROR' czyli b***322;***261;d no***347;nika. mo***380;liwe, ***380;e nagrywasz za wolno co przy nowych p***322;ytach nie jest dobrym pomys***322;em
Seny, pit i collons! Ostatnio zmieniany przez Prezesik : 02.06.2007 o godz. 15:04 |
No wi***281;c tak:
- mam zainstalowanego alcohola i opcja "ignore media type" (odpowiedzialna za wy***322;***261;czenie ATIP) jest odznaczona, - normalnie cd nagrywam z pr***281;dko***347;ci***261; max ale w przypadku tego pioneera zacz***261;***322;em pr***243;bowa***263; z mniejszymi pr***281;dko***347;ciami, bo na max wywala***322; b***322;***281;dy, niestety nie mam log***243;w z tych pierwszych wypa***322;***243;w, - co do tdk-***243;w to ju***380; resztka cake-a wi***281;kszo***347;***263; wypali***322;em na Sony CD-RW CRX216E i nie by***322;o ***380;adnych problem***243;w, |
Spamerzyna
Data rejestracji: 24.09.2006
No c***243;z... Czyli wina no***347;nika. Nawet w dobrych p***322;ytach znajdzie si***281; partia, kt***243;ra jest (przepraszam za wyra***380;enie) do d..y
