Młody żonkoś
Data rejestracji: 02.02.2003
f7a093af34b8cbe1abc165213fea9deb Mandrake90-cd1-inst.i586.iso
05a3ccafaacc37d6d1e2f260fc274549 Mandrake90-cd2-ext.i586.iso 1a2fd731fb6e30d39b0b99f504b231b3 Mandrake90-cd3-i18n.i586.iso to jest z pliku md5sums po co to jest? Wiec pytanko brzmi mam te 3 iso a oni w readme p[iszą tak mozę ktoś wyjaśnić mi to? rozumiem 50 % tekstu Howto burn an ISO image ? All the CD-Writing software can use ISO image to burn directly a CD-Rom. Important note: take care to download the ISO in binary mode (FTP). By default Netscape download the file in ASCII mode which corrupt the image. You can check the integrity of the ISO file with the md5 key (md5sum mandrake.iso under Linux), go to http://www.etree.org/md5com.html to get the md5sum.exe version if you are using Windows) Please avoid downloading the ISO with a 56K modem line. If the download fails you can use "Resume" which allows you to continue the download. It works with ftp (reget), ncftp, CuteFTP, Getright, ... With Easy CD Creator: -------------------- Open Easy CD Creator Go to "File" then to "Create CD from disc image" make sure to change the bottom drop down menu ("Files of type:") to say "ISO image files" It will do the rest after you browse to the *.iso file (Thanks for zacheyer) With WinOnCD: ------------ you can select a "track-image" project when you click the New button. So long as you are in track mode, not file-system mode (how that looks depends on whether you have 3.0 or 3.5) then dragging a track image file onto the CD window should accept it as a raw track. WinOnCD uses .RAW as its own extension (Thanks Rick Jones) With Nero Burning Rom: ---------------------- Open Nero. Close the wizard if it is started automatically. Go to "File" then to "Burn Image...". In the next dialog, click on "Image Files (*.nrg)" and select "All files (*.*)". Choose the .iso file and accept. In the following dialog make sure: - Type of Image is: Data Mode 1 - Block size: 2048 - Image header: 0 - Image trailer: 0 - All the checkboxes are unactive. Click "OK". In the next dialog check that the "write" and "finalize" option are active. Click on "Write". (Thanks Antonio Asensi) With CD-Record: --------------- CD-Writing HowTo: http://howto.linuxberg.com/ptHOWTO/CD-Writing-HOWTO For example: cdrecord -v speed=4 dev=4,0 mandrake.iso You get the number on the SCSI bus number with "cdrecord --scanbus"
Dotyk idący daleko poza definicję słowa instynkt...Julio Cortazar |
Gość
Posty: n/a
Toc przecie masz wszystko opisane jak nagrac to w Nero, nagraj polk obrazu, mode 1 itd.
Ja tego Mandraka nagralem dla znajomego podpinajac go do Daemona, sprawdzilem odpalanie-ruszyl - i wypalilem go Clonem, dziala. |
Data rejestracji: 17.10.2000
ten pierwszy plik zawiera sumy kontrolne plikow z obrazami
sumy te są pomocne przy sprawdzaniu czy te 3 pliki sie pociagnely bez bledow. Pozdrawiam
"myślisz że kim jestem ?? CZŁOWIEKIEM ??" - "Matrix Rewolucje" "Moja jest tylko racja i to święta racja, bo nawet jak jest twoja to moja jest mojsza niż twojsza, że wlaśnie moja racja jest racja najmojsza." - "Dzień świra" PIJ MLEKO!!! BEDZIESZ WIELKI!!! Powered by LTR-52246S |
Data rejestracji: 28.02.2003
Nie wiem jak jest w Mandrake, ale w Red Hat jak nagrasz płyty to system przed instalacją sam je sprawdza czy są prawidłowe.
