Stary 27.02.2006, 12:15   #1
Michael00
Data rejestracji: 27.09.2004
Michael00 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Exclamation Nowy Alcohol 1.9.5.3823
Dla zaainteresowanych:
Wczoraj pojawił się nowy alcohol v1.9.5.3823
Zmiany:
UPDATE Virtual Drive engine.
UPDATE Alcohol Command Launcher and Shell Extension Context Menu to support image files with Unicode file names.
UPDATE Language translations
FIX a rare incompatible problem with some external racks (Firewire and USB) while burning media.
ADD Support for more devices, you can find more detailed information on our development page at http://www.alcohol-soft.com/devsupp/
FIX some minor bugs reported by users.
ADD Win64Bit compatibility.
FIX DEP (Data Execution Prevention) conflict problem.
UPDATE 9 Improved. DPM for DVD media.
ADD Upgrading system
ADD log timestamp as the format user has set in their system.
UPDATE Help Files
ADD Selected speed logging during dumping image
UPDATE Improved reading\writing engines
Michael00 jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 11:24.
