02.06.2017, 14:39 | #1 |
Yamaha CRW-6416S SCSI 1999r. Refurbished
Bardzo poważna i pracochłonna i skomplikowana naprawa.Uszkodzone OPU, silnik główny , wyłamane trzpienie sanek lasera , zatarty niesamowicie hałasujący wentylator ....
Wymiana na używane części z egzemplarza gdzie uszkodzony został chip główny\płyta główna . |
02.06.2017, 14:45 | #2 |
Philips CD-R x52 CMC 97m26s66f Made in Tajwan
Yamaha CRW-6416S SCSI Refurbished fw.1.0c ImgBurn 2.5.8.0 x6 log: Kod:
I 11:24:44 ImgBurn Version 2.5.8.0 started! I 11:24:44 Microsoft Windows 7 Ultimate Edition (6.1, Build 7601 : Service Pack 1) I 11:24:44 Total Physical Memory: 3*012*404 KiB - Available: 1*561*332 KiB W 11:24:44 Duplex Secure's SPTD driver can have a detrimental effect on drive performance. I 11:24:44 Initialising SPTI... I 11:24:44 Searching for SCSI / ATAPI devices... I 11:24:46 -> Drive 1 - Info: Optiarc DVD RW AD-7280S 1.01 (M:) (ATA) I 11:24:47 -> Drive 2 - Info: PLEXTOR DVDR PX-890SA 1.00 (H:) (ATA) I 11:24:47 -> Drive 3 - Info: YAMAHA CRW6416S 1.0c (G:) (SCSI) I 11:24:47 Found 1 CD-RW and 2 DVDÂąRW/RAMs! I 11:25:01 Operation Started! I 11:25:01 Source File: -==/\/[DISCOVERY IMAGE]\/\==- I 11:25:01 Source File Sectors: 359*844 (MODE1/2048) I 11:25:01 Source File Size: 736*960*512 bytes I 11:25:01 Source File Volume Identifier: IMGBURN_DISCOVERY_IMAGE I 11:25:01 Source File Volume Set Identifier: 359844_SECTORS I 11:25:01 Source File Application Identifier: IMGBURN V2.5.8.0 - THE ULTIMATE IMAGE BURNER! I 11:25:01 Source File Implementation Identifier: ImgBurn v2.5.8.0 I 11:25:01 Source File File System(s): ISO9660 I 11:25:01 Destination Device: [4:3:0] YAMAHA CRW6416S 1.0c (G:) (SCSI) I 11:25:01 Destination Media Type: CD-R* I 11:25:01 Destination Media Sectors: 359*844 I 11:25:01 Write Mode: CD I 11:25:01 Write Type: SAO I 11:25:01 Write Speed: 6x I 11:25:01 Lock Volume: Yes I 11:25:01 Test Mode: No I 11:25:01 OPC: No I 11:25:01 BURN-Proof: Enabled W 11:25:02 Write Speed Miscompare! - Wanted: 1*058 KB/s (6x), Got: 1*024 KB/s (5,8x) I 11:25:04 Filling Buffer... (40 MiB) I 11:25:04 Writing LeadIn... I 11:25:53 Writing Session 1 of 1... (1 Track, LBA: 0 - 359843) I 11:25:53 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 359843) I 11:38:21 Synchronising Cache... I 11:38:37 Exporting Graph Data... I 11:38:37 Graph Data File: I:\Users\czary2mary\AppData\Roaming\ImgBurn\Graph Data Files\YAMAHA_CRW6416S_1.0c_2-CZERWIEC-2017_11-25_N-A_6x.ibg I 11:38:37 Export Successfully Completed! I 11:38:37 Operation Successfully Completed! - Duration: 00:13:35 I 11:38:37 Average Write Rate: 963 KiB/s (5.6x) - Maximum Write Rate: 992 KiB/s (5.8x) |
02.06.2017, 20:26 | #3 |
Data rejestracji: 21.02.2014
Bardzo ładnie, plus gratuluję reanimacji
03.06.2017, 05:11 | #4 |
Napęd niesamowicie skomplikowany jak większość Yamaha Made in Japan z tamtych czasów -ale w tamtych czasach absolutnie nic nie mogło z nimi konkurować pod żadnym względem . Przed naprawą i rozbiórką trenowałem na "trupie" demontaż \montaż ....
Podobne dyskusje | ||||
[Muzeum] Yamaha CRW-6416S NB SCSI 1999r. | czary2mary | Napędy optyczne CD | 1 | 13.05.2017 07:11 |
[Muzeum] Yamaha CRW4416S SCSI 1999r. | czary2mary | Napędy optyczne CD | 11 | 21.07.2016 09:33 |
Problem z nagrywaniem CD-R 48x na Yamaha 6416 SCSI | a2fm | Napędy optyczne CD | 0 | 16.07.2003 07:40 |
YAMAHA F1 - SCSI vs IDE ?? | fido2001 | Napędy optyczne CD | 25 | 30.01.2003 00:16 |
Yamaha 8/4/24 SCSI i problem z nagrywaniem x8 | qba | Napędy optyczne CD | 1 | 07.04.2002 22:51 |
