Stary 13.05.2017, 07:08   #1
Yamaha CRW-F1 2002r.
Chipset OAK OTI-9797 +YAMAHA YDC-132V + YAMAHA YAD-524S + OPU Samsung SOH-RW40
Stary 22.06.2017, 17:23   #2
Odczyt CD-ROM\ zapis CD-R 650\700MB
Stary 22.06.2017, 17:27   #3
Maxell Music XL-II 80 AudioCD-R Ritek MID:97m15s17f Made in China
Yamaha CRW-F1 fw..1.0g
ImgBurn 2.5.8.0 x8
W przypadku błędów E12 sprzęt "wymiata "
log :
Kod:
I 13:53:58 ImgBurn Version 2.5.8.0 started!
I 13:53:58 Microsoft Windows 8 Professional x64 Edition (6.2, Build 9200)
I 13:53:58 Total Physical Memory: 4*189*108 KiB  -  Available: 1*873*160 KiB
I 13:53:58 Initialising ElbyCDIO...
I 13:53:58 ELBYCDIO.DLL - Elaborate Bytes CDRTools - ElbyCDIO DLL - Version 6.1.9.1
I 13:53:58 Searching for SCSI / ATAPI devices...
I 13:53:58 -> Drive 1 - Info: HL-DT-ST DVDRAM GT30N 1.01 (D:) (ATAPI)
I 13:54:00 -> Drive 2 - Info: YAMAHA CRW-F1E 1.0g (F:) (USB)
I 13:54:00 Found 1 CD-RW and 1 DVD***177;RW/RAM!
I 13:55:20 Operation Started!
I 13:55:20 Building Image Tree...
I 13:55:21 Checking Directory Depth...
I 13:55:21 Calculating Totals...
I 13:55:21 Preparing Image...
I 13:55:22 Checking Path Length...
I 13:55:22 Contents: 4 Files, 0 Folders
I 13:55:22 Content Type: Data
I 13:55:22 Data Type: MODE1/2048
I 13:55:22 File System(s): ISO9660, UDF (1.02)
I 13:55:22 Volume Label: Nero 9-10 iso Plex PREM Nero 5,5
I 13:55:22 Size: 590*061*144 bytes
I 13:55:22 Sectors: 288*118
I 13:55:22 Image Size: 590*643*200 bytes
I 13:55:22 Image Sectors: 288*400
I 13:55:23 Operation Successfully Completed! - Duration: 00:00:03
I 13:55:23 Operation Started!
I 13:55:23 Source File: -==/\/[BUILD IMAGE]\/\==-
I 13:55:24 Source File Sectors: 288*400 (MODE1/2048)
I 13:55:24 Source File Size: 590*643*200 bytes
I 13:55:24 Source File Volume Identifier: Nero 9-10 iso Plex PREM Nero 5,5
I 13:55:24 Source File Volume Set Identifier: 4AD66EEA00046682
I 13:55:24 Source File Application Identifier: IMGBURN V2.5.8.0 - THE ULTIMATE IMAGE BURNER!
I 13:55:24 Source File Implementation Identifier: ImgBurn
I 13:55:24 Source File File System(s): ISO9660; UDF (1.02)
I 13:55:24 Destination Device: [0:0:0] YAMAHA CRW-F1E 1.0g (F:) (USB)
I 13:55:24 Destination Media Type: CD-R (Disc ID: 97m15s17f, Ritek Co.)
I 13:55:24 Destination Media Sectors: 359*843
I 13:55:24 Write Mode: CD
I 13:55:24 Write Type: SAO
I 13:55:24 Write Speed: 8x
I 13:55:24 Lock Volume: Yes
I 13:55:24 Test Mode: No
I 13:55:24 OPC: Yes
I 13:55:24 BURN-Proof: Enabled
I 13:55:24 Write Speed Successfully Set! - Effective: 1*411 KB/s (8x)
I 13:55:34 Filling Buffer... (513 MiB)
I 13:55:40 Writing LeadIn...
I 13:56:03 Writing Session 1 of 1... (1 Track, LBA: 0 - 288399)
I 13:56:03 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 288399)
I 14:03:58 Synchronising Cache...
I 14:04:15 Exporting Graph Data...
I 14:04:15 Graph Data File: C:\Users\czary2mary\AppData\Roaming\ImgBurn\Graph Data Files\YAMAHA_CRW-F1E_1.0g_22-CZERWIEC-2017_13-55_97m15s17f_8x.ibg
I 14:04:15 Export Successfully Completed!
I 14:04:15 Operation Successfully Completed! - Duration: 00:08:51
I 14:04:16 Average Write Rate: 1*216 KiB/s (7.1x) - Maximum Write Rate: 1*232 KiB/s (7.2x)
Stary 25.06.2017, 04:50   #4
Maxell Music Printable CD-R Audio ATIP\MID 97m17s09f tłocznia Moser Baer
Feurio x Advanced Audio Master Quality Recording (x4)
Z testem discquality z tak nagraną płytą na wielu urządzeniach jest problem - wszystkie BenQDW1620\1625\1640\1650\1655 - zawieszają ten w losowych miejscach , nowsze modele na chipsetach MediaTek w programach testujących widzą "cuda" ale płyta w stacjonarnym sprzęcie działa idealnie .
Oczywiście przyczyną są wydłużone maksymalnie pity i landy przez co na wiele napędów źle to interpretuje .
Stary 26.06.2017, 10:10   #5
Update \
Udało się zrobić test discquality na BenQ DW1640 z firmware BSLB w Nero Speed Disc . W Opti Drive Control dalej losowo błąd testu.
Stary 21.08.2017, 16:48   #6
PlexDisc MEDICAL DISC CD-R Printable CMC Magnetic Tajwan ATIP:97m26s66f
ImgBurn 2.5.8.0 x8
Stary 30.04.2018, 07:32   #7
Memorex Music CD-R AUDIO 700MB CMC Magnetic 97m26s66f
Nero 5.5 Edycja specjalna Yamaha- Advanced Audio Master Quality Recording x8
Stary 11.05.2018, 06:13   #8
JVC CD-R Music CD-R Audio Taiyo Yuden Made in Japan ATIP\MID: 97m24s01f
Nero 5.5 Edycja specjalna Yamaha- Advanced Audio Master Quality Recording x4
Stary 18.05.2018, 11:08   #9
Leman39
Avatar użytkownika Leman39
Data rejestracji: 21.02.2014
Jak ona pali!
Stary 22.05.2018, 06:13   #10
Kolejna "sztuka " w kolekcji - tym razem przybyła z fabrycznym firmware 1.0c
Stary 25.11.2022, 06:54   #11
RITEK CD-R Inkjet White Medical 52x MID/ATIP : 97m15s17f
ImgBurn 2.5.8.0 x44
CRW F1 do użytkowników i nie tylko walu Napędy optyczne CD 1 30.08.2003 22:03
Yamaha F1 i super niska cena... ?? Martin_TP Napędy optyczne CD 23 11.01.2003 09:46
YAMAHA CRW F1 NOWY Firmware zorg Napędy optyczne CD 0 05.10.2002 03:20
yamaha crw f1 gips Napędy optyczne CD 0 13.09.2002 17:18
yamaha crw f1 gips Napędy optyczne CD 4 06.09.2002 09:41
Wszystkie czasy w strefie CET. Aktualna godzina: 21:34.
