10.07.2016, 12:42 | #1 |
Yamaha CRW4260t SCSI 1998r.
Skleiłem jakiegoś kompa dla swoich napędów SCSI \Windows 7 32bit+ kontroler PC-ESCSI Adaptec AHA2910 + stery dla chipsetu AIC 78xx ver. AIC 78u2 -Win 7 ver. 605457.
Więc tym razem dodany napęd SCSI z testem działania .... Odczyt CD-ROM Odczyt CD-R |
10.07.2016, 12:45 | #2 |
Zapis x1
log z zapisu Kod:
9040-0198-Z5EU-U5M9-5422-WC24-****-**** Windows 7 6.1 IA32 Nero Version: 15.0.19.0 Internal Version: 15,0,19,0 Recorder : <YAMAHA CRW4260> FW version: 1.0g - HA 1 TA 3 - 15.0.19.0 Device bus : <> HA 1 Host system bus : <SCSI> Drive buffer : 2048kB Bus Type : via Inquiry data CD/DVD-ROM : <PLEXTOR DVDR PX-890SA > FW version: 1.00 - HA 1 TA 1 - 15.0.19.0 Device bus : <> HA 1 Host system bus : <IDE> === Scsi-Device-Map === CdRomPeripheral : YAMAHA CRW4260 1.0g aic78xx Port 4 ID 1 DMA: Off === CDRom-Device-Map === PLEXTOR DVDR PX-890SA H: CdRom1 YAMAHA CRW4260 G: CdRom3 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2047MB (2097151kB) Free physical memory: 1188MB (1216728kB) Memory in use : 59 % Uncached PFiles: 0x0 Global Bus Type: default (0) Check supported media : Disabled (0) 10.7.2016 Audio CD 10:22:04 #1 Text 0 File SCSIPTICommands.cpp, Line 617 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 10:22:04 #2 CDADOC -1 File Cdadoc.cpp, Line 1739 Audio item log info: Audio document burn settings: ============================= Burn mode: DAO, CD Text: On, Cache disk or network files: No, Cache small files: No, Cache files smaller than 65536 bytes. Audio Multisession: No List of audio tracks: ===================== Track 01: Length: 03:27.63, Pause frames: 150, Filters: 0, Name: '01 - Slow Motion.flac'. Track 02: Length: 04:16.63, Pause frames: 150, Filters: 0, Name: '02 - I Can't Stay Long.flac'. Track 03: Length: 04:26.62, Pause frames: 150, Filters: 0, Name: '03 - Someone Else's Clothes.flac'. Track 04: Length: 03:09.16, Pause frames: 150, Filters: 0, Name: '04 - Blue Light.flac'. Track 05: Length: 02:28.57, Pause frames: 150, Filters: 0, Name: '05 - Some Of Them.flac'. Track 06: Length: 04:11.19, Pause frames: 150, Filters: 0, Name: '06 - Quiet Men.flac'. Track 07: Length: 02:55.63, Pause frames: 150, Filters: 0, Name: '07 - Dislocation.flac'. Track 08: Length: 03:53.03, Pause frames: 150, Filters: 0, Name: '08 - Maximum Acceleration.flac'. Track 09: Length: 04:15.45, Pause frames: 150, Filters: 0, Name: '09 - When You Walk Through Me.flac'. Track 10: Length: 03:11.70, Pause frames: 150, Filters: 0, Name: '10 - Just For A Moment.flac'. Track 11: Length: 03:28.18, Pause frames: 150, Filters: 0, Name: '01. Throw Down the Roses.flac'. Track 12: Length: 03:08.48, Pause frames: 150, Filters: 0, Name: '02. Mister Sister.flac'. Track 13: Length: 04:24.16, Pause frames: 150, Filters: 0, Name: '03. Guitars and Microphones.flac'. Track 14: Length: 03:19.67, Pause frames: 150, Filters: 0, Name: '04. Crush Me With Your Love.flac'. Track 15: Length: 02:38.09, Pause frames: 150, Filters: 0, Name: '05. Bottoms Up.flac'. Track 16: Length: 03:54.66, Pause frames: 150, Filters: 0, Name: '06. Bring Your Arms.flac'. Track 17: Length: 04:25.18, Pause frames: 150, Filters: 0, Name: '07. Wolves.flac'. Track 18: Length: 04:36.45, Pause frames: 150, Filters: 0, Name: '08. Matrix.flac'. Track 19: Length: 03:23.51, Pause frames: 150, Filters: 0, Name: '09. Time Wave Zero.flac'. Track 20: Length: 03:24.19, Pause frames: 150, Filters: 0, Name: '10. Pulls You Under.flac'. Total size: 73:40.68 10:22:05 #3 Text 0 File AudioCompilationImpl.cpp, Line 838 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 10:22:05 #4 PHASE 214 File dlgbrnst.cpp, Line 2066 Generation of disc structures started 10:22:05 #5 PHASE 215 File dlgbrnst.cpp, Line 2066 Generation of disc structures completed 10:22:05 #6 Text 0 File Burncd.cpp, Line 3634 Turn on Disc-At-Once, using CD-R/RW media 10:22:09 #7 Text 0 File DlgWaitCD.cpp, Line 334 [G: CRW4260 ] Last possible write address on media: 359842 Last address to be written: 331417 10:22:09 #8 Text 0 File DlgWaitCD.cpp, Line 346 [G: CRW4260 ] Write in overburning mode: NO (enabled: CD) 10:22:10 #9 Text 0 File DlgWaitCD.cpp, Line 3034 Recorder: YAMAHA CRW4260; CDR code: 00 97 15 17; OSJ entry from: Ritek Co. ATIP Data: Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 10:22:10 #10 Text 0 File DlgWaitCD.cpp, Line 537 [G: CRW4260 ] >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:22:10 #11 Text 0 File ThreadedTransferInterface.cpp, Line 879 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (01 - Slow Motion.flac) 2 indices, index0 (150) not provided original disc pos #0 + 15588 (15588) = #15588/3:27.63 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15588 blocks [G: YAMAHA CRW4260] 1: TRM_AUDIO_NOPRE (02 - I Can't Stay Long.flac) 2 indices, index0 (150) not provided original disc pos #0 + 19263 (19263) = #19263/4:16.63 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19263 blocks [G: YAMAHA CRW4260] 2: TRM_AUDIO_NOPRE (03 - Someone Else's Clothes.flac) 2 indices, index0 (150) not provided original disc pos #0 + 20012 (20012) = #20012/4:26.62 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20012 blocks [G: YAMAHA CRW4260] 3: TRM_AUDIO_NOPRE (04 - Blue Light.flac) 2 indices, index0 (150) not provided original disc pos #0 + 14191 (14191) = #14191/3:9.16 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14191 blocks [G: YAMAHA CRW4260] 4: TRM_AUDIO_NOPRE (05 - Some Of Them.flac) 2 indices, index0 (150) not provided original disc pos #0 + 11157 (11157) = #11157/2:28.57 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11157 blocks [G: YAMAHA CRW4260] 5: TRM_AUDIO_NOPRE (06 - Quiet Men.flac) 2 indices, index0 (150) not provided original disc pos #0 + 18844 (18844) = #18844/4:11.19 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18844 blocks [G: YAMAHA CRW4260] 6: TRM_AUDIO_NOPRE (07 - Dislocation.flac) 2 indices, index0 (150) not provided original disc pos #0 + 13188 (13188) = #13188/2:55.63 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13188 blocks [G: YAMAHA CRW4260] 7: TRM_AUDIO_NOPRE (08 - Maximum Acceleration.flac) 2 indices, index0 (150) not provided original disc pos #0 + 17478 (17478) = #17478/3:53.3 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17478 blocks [G: YAMAHA CRW4260] 8: TRM_AUDIO_NOPRE (09 - When You Walk Through Me.flac) 2 indices, index0 (150) not provided original disc pos #0 + 19170 (19170) = #19170/4:15.45 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19170 blocks [G: YAMAHA CRW4260] 9: TRM_AUDIO_NOPRE (10 - Just For A Moment.flac) 2 indices, index0 (150) not provided original disc pos #0 + 14395 (14395) = #14395/3:11.70 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14395 blocks [G: YAMAHA CRW4260] 10: TRM_AUDIO_NOPRE (01. Throw Down the Roses.flac) 2 indices, index0 (150) not provided original disc pos #0 + 15618 (15618) = #15618/3:28.18 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15618 blocks [G: YAMAHA CRW4260] 11: TRM_AUDIO_NOPRE (02. Mister Sister.flac) 2 indices, index0 (150) not provided original disc pos #0 + 14148 (14148) = #14148/3:8.48 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14148 blocks [G: YAMAHA CRW4260] 12: TRM_AUDIO_NOPRE (03. Guitars and Microphones.flac) 2 indices, index0 (150) not provided original disc pos #0 + 19816 (19816) = #19816/4:24.16 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19816 blocks [G: YAMAHA CRW4260] 13: TRM_AUDIO_NOPRE (04. Crush Me With Your Love.flac) 2 indices, index0 (150) not provided original disc pos #0 + 14992 (14992) = #14992/3:19.67 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14992 blocks [G: YAMAHA CRW4260] 14: TRM_AUDIO_NOPRE (05. Bottoms Up.flac) 2 indices, index0 (150) not provided original disc pos #0 + 11859 (11859) = #11859/2:38.9 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11859 blocks [G: YAMAHA CRW4260] 15: TRM_AUDIO_NOPRE (06. Bring Your Arms.flac) 2 indices, index0 (150) not provided original disc pos #0 + 17616 (17616) = #17616/3:54.66 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17616 blocks [G: YAMAHA CRW4260] 16: TRM_AUDIO_NOPRE (07. Wolves.flac) 2 indices, index0 (150) not provided original disc pos #0 + 19893 (19893) = #19893/4:25.18 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19893 blocks [G: YAMAHA CRW4260] 17: TRM_AUDIO_NOPRE (08. Matrix.flac) 2 indices, index0 (150) not provided original disc pos #0 + 20745 (20745) = #20745/4:36.45 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20745 blocks [G: YAMAHA CRW4260] 18: TRM_AUDIO_NOPRE (09. Time Wave Zero.flac) 2 indices, index0 (150) not provided original disc pos #0 + 15276 (15276) = #15276/3:23.51 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15276 blocks [G: YAMAHA CRW4260] 19: TRM_AUDIO_NOPRE (10. Pulls You Under.flac) 2 indices, index0 (150) not provided original disc pos #0 + 15319 (15319) = #15319/3:24.19 relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15319 blocks [G: YAMAHA CRW4260] -------------------------------------------------------------- 10:22:10 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1095 Prepare [G: YAMAHA CRW4260] for write in CUE-sheet-DAO DAO infos: ========== MCN: " " TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 20: Idx 0 Idx 1 Next Trk 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 37015776, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 37015776 37368576 82675152, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 82675152 83027952 130096176, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 130096176 130448976 163826208, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 163826208 164179008 190420272, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 190420272 190773072 235094160, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 235094160 235446960 266465136, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 266465136 266817936 307926192, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 307926192 308278992 353366832, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 353366832 353719632 387576672, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 387576672 387929472 424663008, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 424663008 425015808 458291904, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 458291904 458644704 505251936, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 505251936 505604736 540865920, ISRC "" 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 540865920 541218720 569111088, ISRC "" 16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 569111088 569463888 610896720, ISRC "" 17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 610896720 611249520 658037856, ISRC "" 18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 658037856 658390656 707182896, ISRC "" 19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 707182896 707535696 743464848, ISRC "" 20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 743464848 743817648 779847936, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ -150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x21 | 0 | 0 | 0x00 0 | 1 | 1 | 0x21 | 15588 | 0 | 0x00 15588 | 2 | 0 | 0x21 | 0 | 0 | 0x00 15738 | 2 | 1 | 0x21 | 19263 | 15738 | 0x00 35001 | 3 | 0 | 0x21 | 0 | 0 | 0x00 35151 | 3 | 1 | 0x21 | 20012 | 35151 | 0x00 55163 | 4 | 0 | 0x21 | 0 | 0 | 0x00 55313 | 4 | 1 | 0x21 | 14191 | 55313 | 0x00 69504 | 5 | 0 | 0x21 | 0 | 0 | 0x00 69654 | 5 | 1 | 0x21 | 11157 | 69654 | 0x00 80811 | 6 | 0 | 0x21 | 0 | 0 | 0x00 80961 | 6 | 1 | 0x21 | 18844 | 80961 | 0x00 99805 | 7 | 0 | 0x21 | 0 | 0 | 0x00 99955 | 7 | 1 | 0x21 | 13188 | 99955 | 0x00 113143 | 8 | 0 | 0x21 | 0 | 0 | 0x00 113293 | 8 | 1 | 0x21 | 17478 | 113293 | 0x00 130771 | 9 | 0 | 0x21 | 0 | 0 | 0x00 130921 | 9 | 1 | 0x21 | 19170 | 130921 | 0x00 150091 | 10 | 0 | 0x21 | 0 | 0 | 0x00 150241 | 10 | 1 | 0x21 | 14395 | 150241 | 0x00 164636 | 11 | 0 | 0x21 | 0 | 0 | 0x00 164786 | 11 | 1 | 0x21 | 15618 | 164786 | 0x00 180404 | 12 | 0 | 0x21 | 0 | 0 | 0x00 180554 | 12 | 1 | 0x21 | 14148 | 180554 | 0x00 194702 | 13 | 0 | 0x21 | 0 | 0 | 0x00 194852 | 13 | 1 | 0x21 | 19816 | 194852 | 0x00 214668 | 14 | 0 | 0x21 | 0 | 0 | 0x00 214818 | 14 | 1 | 0x21 | 14992 | 214818 | 0x00 229810 | 15 | 0 | 0x21 | 0 | 0 | 0x00 229960 | 15 | 1 | 0x21 | 11859 | 229960 | 0x00 241819 | 16 | 0 | 0x21 | 0 | 0 | 0x00 241969 | 16 | 1 | 0x21 | 17616 | 241969 | 0x00 259585 | 17 | 0 | 0x21 | 0 | 0 | 0x00 259735 | 17 | 1 | 0x21 | 19893 | 259735 | 0x00 279628 | 18 | 0 | 0x21 | 0 | 0 | 0x00 279778 | 18 | 1 | 0x21 | 20745 | 279778 | 0x00 300523 | 19 | 0 | 0x21 | 0 | 0 | 0x00 300673 | 19 | 1 | 0x21 | 15276 | 300673 | 0x00 315949 | 20 | 0 | 0x21 | 0 | 0 | 0x00 316099 | 20 | 1 | 0x21 | 15319 | 316099 | 0x00 331418 | lead-out | 1 | 0x01 | 0 | 0 | 0x00 MediaType: CD-R 10:22:10 #13 Text 0 File SCSIPTICommands.cpp, Line 404 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 10:22:10 #14 Text 0 File Burncd.cpp, Line 4504 Caching options: cache CDRom or Network-No, small files-No (<64KB) 10:22:10 #15 PHASE 36 File dlgbrnst.cpp, Line 2066 Burn process started at 1x (150 KB/s) 10:22:10 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 10:22:10 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #15738 10:22:10 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #35151 10:22:10 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #55313 10:22:10 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #69654 10:22:10 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #80961 10:22:10 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #99955 10:22:10 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #113293 10:22:10 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #130921 10:22:10 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #150241 10:22:10 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #164786 10:22:10 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #180554 10:22:10 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #194852 10:22:10 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #214818 10:22:10 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #229960 10:22:10 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #241969 10:22:10 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #259735 10:22:10 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #279778 10:22:10 #34 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #300673 10:22:10 #35 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 19 (relocatable, no disc pos, no patch infos, orig at #0): write at #316099 10:22:10 #36 Text 0 File Mmc.cpp, Line 17654 StartDAO : CD-Text - Off 10:22:10 #37 Text 0 File Mmc.cpp, Line 17882 CueData, Len=336 21 00 00 01 00 00 00 00 21 01 00 00 00 00 00 00 21 01 01 00 00 00 02 00 21 02 00 00 00 03 1d 3f 21 02 01 00 00 03 1f 3f 21 03 00 00 00 07 30 33 21 03 01 00 00 07 32 33 21 04 00 00 00 0c 11 26 21 04 01 00 00 0c 13 26 21 05 00 00 00 0f 1c 36 21 05 01 00 00 0f 1e 36 21 06 00 00 00 11 3b 24 21 06 01 00 00 12 01 24 21 07 00 00 00 16 0c 37 21 07 01 00 00 16 0e 37 21 08 00 00 00 19 0a 2b 21 08 01 00 00 19 0c 2b 21 09 00 00 00 1d 05 2e 21 09 01 00 00 1d 07 2e 21 0a 00 00 00 21 17 10 21 0a 01 00 00 21 19 10 21 0b 00 00 00 24 25 0b 21 0b 01 00 00 24 27 0b 21 0c 00 00 00 28 07 1d 21 0c 01 00 00 28 09 1d 21 0d 00 00 00 2b 12 02 21 0d 01 00 00 2b 14 02 21 0e 00 00 00 2f 2c 12 21 0e 01 00 00 2f 2e 12 21 0f 00 00 00 33 06 0a 21 0f 01 00 00 33 08 0a 21 10 00 00 00 35 2e 13 21 10 01 00 00 35 30 13 21 11 00 00 00 39 2b 0a 21 11 01 00 00 39 2d 0a 21 12 00 00 00 3e 0a 1c 21 12 01 00 00 3e 0c 1c 21 13 00 00 00 42 30 49 21 13 01 00 00 42 32 49 21 14 00 00 00 46 0e 31 21 14 01 00 00 46 10 31 01 aa 01 01 00 49 28 44 10:22:10 #38 Text 0 File ThreadedTransfer.cpp, Line 275 Pipe memory size 83836800 11:38:47 #39 Text 0 File WriterStatus.cpp, Line 245 <G: YAMAHA CRW4260> start writing Lead-Out at LBA 331418 (50E9Ah), length 0 blocks 11:40:24 #40 PHASE 37 File dlgbrnst.cpp, Line 2066 Burn process completed successfully at 1x (150 KB/s) 11:40:24 #41 Text 0 File AudioCompilationImpl.cpp, Line 863 DRM: DRM burn session terminated. 11:40:24 #42 Text 0 File AudioCompilationImpl.cpp, Line 892 DRM: Closing entire DRM handling. Bye. 11:40:24 #43 Text 0 File SCSIPTICommands.cpp, Line 454 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 11:40:24 #44 Text 0 File Cdrdrv.cpp, Line 12266 DriveLocker: UnLockVolume completed 11:40:24 #45 Text 0 File SCSIPTICommands.cpp, Line 617 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL |
10.07.2016, 12:50 | #3 |
Yamaha CRW4260t SCSI 1998r. fw.1.0g
Maxell Music XL-II 80 AudioCD-R Ritek MID:97m15s17f Made in China NERO 2014 x1 Jak widać dla niektórych nowszych napędów problemem jest taki wolny zapis i mają problem z odczytem tak zapisanej płyty... Ostatnio zmieniany przez czary2mary : 10.07.2016 o godz. 12:58 |
10.07.2016, 13:14 | #4 |
Data rejestracji: 21.02.2014
Jak oceniasz wypał, bo moim zdaniem kurcze, słabo
10.07.2016, 13:58 | #5 |
Dobrze jest... spójrz na test PX-760A \beta\jitter............beta prawie zero odchyłów \ jitter momentami w okolicy ~~5%....
Gdyby BenQ testował x1 było by dobrze... |
10.07.2016, 21:57 | #6 |
ogólnie podziwiam :-)
Every wish is only a journey away... |
11.07.2016, 10:54 | #7 |
No ja mam niemały problem z interpretacją tych wyników, przyznaję
Narobiłeś mi ochoty na yamahę, ciekawe jak poradzi sobie z AZO. Audio CD Verbatima chyba też mają podłoże AZO (coś, jak kiedyś seria Color CD-R). Oby więcej takich sprzętów |
11.07.2016, 13:00 | #8 | |
Maksymalny odczyt x6 ..... Trzeba pamiętać że sprzęt soft ma z 1998r , czyli strategie dla nośników CD-R x1-4 , jest trochę nowszy firmware 1.0q ale żeby zaktualizować sprzęt to trzeba kilka dyskietek napisać i pod DOS-em walczyć ....też trzeba zapomnieć o aktualizacji sprzętu na kontrolerze PC-E SCSI ..... To cud że rozpoznaje nowe nośniki i nagrywa.... |
11.07.2016, 19:04 | #9 |
Model F1E można za 100 PLN z hakiem w PL wyciągnąć, ale wyłącznie z sentymentu
Mi się strasznie podobają wizualnie te Yamahy - surowe takie, japońskie |
11.07.2016, 20:06 | #10 |
CRW F1 to inna bajka \ interfejs IDE\USB + soft z 2003r + wsparcie dla wszystkich nośników x48\52..... to jeden z najbardziej zaawansowanych technologicznie i techniczne napędów CD-RW............
26.07.2016, 21:32 | #11 |
Tym razem trochę późniejszy egzemplarz z sierpnia 1998r.. na przeglądzie ...zwraca uwagę jeszcze bardzo duża soczewka lasera oraz trzy chipy sterujące Yamaha .....
26.07.2016, 22:46 | #12 |
jak zawsze wilki szacunek :-)
nagrywarki CD sobie odpuszczam w zbiorach ale za to w tym tyg. zdobyłem ASUSA 24B3ST od pierwszego właściciela :-) przebieg znikomy zobaczymy ile płyt wypalił ;-) za 60zł z wysyłką
27.07.2016, 15:47 | #13 |
Skąd Wy to Panowie bierzecie? :-)
U mnie póki co na stanie przeważnie szrot.. |
28.07.2016, 04:55 | #14 |
28.07.2016, 13:01 | #15 |
Ͼ Ͽ
Podobne dyskusje | ||||
Problem z nagrywaniem CD-R 48x na Yamaha 6416 SCSI | a2fm | Napędy optyczne CD | 0 | 16.07.2003 07:40 |
YAMAHA F1 - SCSI vs IDE ?? | fido2001 | Napędy optyczne CD | 25 | 30.01.2003 00:16 |
Yamaha 8/4/24 SCSI i problem z nagrywaniem x8 | qba | Napędy optyczne CD | 1 | 07.04.2002 22:51 |
YAMAHA 2100 E i SCSI | tomek23 | Napędy optyczne CD | 0 | 25.03.2002 15:09 |
Jak wlaczyc dma w yamaha 2100s scsi ? (pilne) | Goro | Napędy optyczne CD | 0 | 21.10.2001 13:14 |
