kurcze nie wiem czemu mi wczoraj nie wyświetliło odpowiedzi ale apropos engineu riddicka - to nie jest engine doom 3, to autorski engine chłopaków z starbreeze... cytat: "Technical Features
* Normal Mapping is a bleeding-edge technique that allows the Riddick engine to render, light, and shadow a flat textured surface as if it were complex 3D geometry. The texture is first built as a 3D object in a modeling program, and a series of maps and shaders allow the engine to render and light the texture and give the appearance that it has the same complex geometry that it was constructed with, even though now, it is actually a flat surface. The game's use of Normal Mapping means that ALL of the characters in the game feature a stunning level of detail. Everything from unique lighting based on the surface texture of their clothing, to very realistic muscularity ***8211; the days of blocky arms and square biceps are gone. * Per-pixel lighting/dynamic lighting allows the game to light surfaces on a per-pixel basis in real-time and achieve a much more complex lighting formula, which includes diffuse and specular shading and projection mapping. This means that static and dynamic objects are lit precisely and with incredibly realism. * The Riddick game's engine features a stencil shadowing model that allows both static and dynamic objects to have realistic shadows, even self-shadowing, all in real-time. This effect compliments the per-pixel lighting/dynamic lighting, and helps achieve the highly realistic dark/light contrast in Riddick, the game. * The Riddick engine supports full rag-doll physics, allowing the player to experience a vivid and realistic reaction to combat, as enemies react dynamically to weapon fire, both while they're alive, and while they're dead." :) i taka mała ciekawostka, vin diesel podczas promocji riddicka na e3 2004 http://media.filmforce.ign.com/artic...g_2140197.html a to jaka gra? http://img61.imageshack.us/img61/1967/ajn0uh.th.jpg |
Zdaje się, że to ten sam engine. Ehh... te plastikowe mordy, ale idzie przywyknąć, a gameplay pierwsza klasa.
tak, ten engine jest podobny do dooma ale odnoszę wrażenie, że jest wydajniejszy czy może raczej lepiej zoptymalizowany...co tam doom 3 ma na noc! :) a moze by tak ktoś odpowiedział n apytanie jaka to gra? huh?
Powiedzmy, że Doom tak dość niemrawo momentami u mnie chodził, a tu mi wygląda, że engine jest podobny.. |
Zależy co masz na myśli mówiąc "nieziemskie". :taktak:
Ok, przekonali***347;cie mnie, przy najbli***380;szej okazji sobie sprawi***281; :)
Mam tylko nadziej***281;, ***380;e nie ma ona jaki***347; nieziemskich wymaga***324;? Wygl***261;da nie***378;le, ale swoje lata ju***380; te***380; ma.. |
dziw mnie bierze, że jeszce nie ma kontynuacji tej gry.Potęga w swiecie zalewanym doomami i quakeami. pięknie wyglądała(nadal wygląda bo gram),fajna fabuła,zajefajni przeciwnicy(po zauważeniu zmiany w otoczeniu(zgaszona lampa!!! lub zwłoki) szukają przyczyny lub podnoszą alarm....a jak fajnie przeklinają...fiuuuu :), no i nie należą do tępaków, fajnie się bronią. klimat gry zywcem zaczerpnięty z filmu, a i głos samego vina diesla...koleś ma za***iście głęboki wokal, zresztą resztę głównych ról też osadzono fajnymi głosami aktorów (michael rooker np.) ps. lampy rozbija się za***iscie !!! i extra można podejść do gościa od tyłu i skręcić mu kark, odgłosy i efekty broni!!!...jedyna wada....krótka ps2. i tak dla mnie najlepszym fpsem jest, był i będzie quake 1, a zaraz po nim duke nukem atomic edition "he he what a mess" no to pytanko...jaka to gra, dodam tylko, ze jest ona całkowicie ZA DARMO :) http://img63.imageshack.us/img63/6422/13lu2.th.jpghttp://img233.imageshack.us/img233/8929/27xr.th.jpg |
@Berion
Spoko rozumiem :) Nie wszyscy pewnie tez ***347;ledz***261; ka***380;de nowo***347;ci. Co do samego FFXIII to sam troch***281; tego nie kapuje... :P To b***281;d***261; dwie FFXIII i obie na PS3 ? Czy na PS3 b***281;dzie jedna a reszta na telefony kom***243;rkowe i takie pierdo***322;y... :P Nie kapuje :D Pozdrawiam |
@Darek_K
FFXIII - tylko nie pytaj który, tytułu nie pamiętam. Nie wiem czy te Twoje 'nagięcie' zasad się ludziom spodoba. Ja nie mam nic przeciw, ale tu prawie nikt nie gra na konsolach, tym bardziej w jRPGi :taktak: @andrzejj9 Oczywiście, że warto! To jeden z najlepszych FPSów ostatnich lat i najlepsza gra oparta na filmie... lub: jedyna gra oparta (luźno) na filmie, która jest jedną z najlepszych fps-ów. |
Witam.
To moze ja troche nagne zasady i zapodam obrazek z gry ktora jeszcze nie zostala wydana :D http://img209.imageshack.us/img209/4...d0011la.th.jpg Co to za gra ? :D Pozdrawiam Serdecznie |
To ja z racji tego ze mi firewall blokuje obrazki na forum a niechce mi sie wylaczac i nikt nic nie wrzucil, bede zgadywal co to za gra jest. Moze SETTLERS I ?? |
| Wszystkie czasy w strefie CET. Aktualna godzina: 00:07. |
