Stary 21.04.2024, 17:40   #1
pepst
Data rejestracji: 15.02.2010
pepst niedługo stanie się sławny ;) <50 - 149 pkt>pepst niedługo stanie się sławny ;) <50 - 149 pkt>
3A Media 1-2x DVD-R
Very early and rare media from Austrian producer 3A Media. At the time of production, the manufacturer did not yet have its own MID codes, nor were generic MID codes available from Plasmon or Interaxia (as in the days of 4x and 8x media), so at the start of production 3A Media either used the MID code from production line supplier Steag Hamatech (SHT001) or used no MID code at all. In both cases the supplier of the stampers was Plasmon.
I'm attaching an informative test on a drive that is not ideal for testing, but 10+ years ago, when I was heavily into CD and DVD media testing, it gave at least very roughly comparable results to Benq and Plextor drives.
I have the drives to test (Benq, Plextor, LiteON), but I can't find an IDE/SATA to USB converter at the moment. If I find one, I will complete the tests with a proper drive.
The data was burned with the same drive (Lite-On eNAU608 5 CL02) at 2x speed.
3A Media 1-2x DVD-R-20240421_172936.jpg   3A Media 1-2x DVD-R-20240421_173011.jpg   3A Media 1-2x DVD-R-20240421_173139.jpg   3A Media 1-2x DVD-R-3a-media.jpg   3A Media 1-2x DVD-R-3a-media-trt.jpg
Ostatnio zmieniany przez pepst : 21.04.2024 o godz. 19:09
pepst jest offline   Odpowiedz cytując ten post
1-2x, 3a, dvd-r, media
Wszystkie czasy w strefie CET. Aktualna godzina: 09:25.
