Stary 05.11.2006, 19:52   #1
lee99
DrBackup
Avatar użytkownika lee99
Data rejestracji: 28.05.2005
lee99 zaczyna zdobywać reputację <1 - 49 pkt>
Talking Platinum DVD+R DL 8x 8.5GB (RITEK S04 01)
Dzisiaj znowu kolejny nośnik "na tapecie". Tym razem jest to dwuwarstwowa płytka firmy Platinum. Cena sklepowa 10 PLN
Za moment wykresy jakości w programie Nero CD-DVD Speed 4.7.0.0
I 18:52:45 ImgBurn Version 2.1.0.0 started!
I 18:52:45 Microsoft Windows XP Professional (5.1, Build 2600 : Dodatek Service Pack 2)
I 18:52:45 Initialising SPTI...
I 18:52:45 Searching for SCSI / ATAPI devices...
I 18:52:45 Found 1 DVD***177;RW and 1 DVD***177;RW/RAM!
I 18:54:50 Operation Started!
I 18:54:50 Source File: D:\***.img
I 18:54:50 Source File Sectors: 4*048*736 (MODE1/2048)
I 18:54:50 Source File Size: 8*291*811*328 bytes
I 18:54:50 Source File Volume Identifier: ***
I 18:54:50 Source File Implementation Identifier: Daikin U.S. Comtec Lab
I 18:54:50 Source File File System(s): ISO9660; UDF (1,02)
I 18:54:50 Destination Device: [1:2:0] _NEC DVD_RW ND-4571A 1-02 (G (ATA)
I 18:54:50 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-01) (Speeds: 4x; 6x; 8x)
I 18:54:50 Destination Media Sectors: 4*173*824
I 18:54:50 Write Mode: DVD
I 18:54:50 Write Type: DAO
I 18:54:50 Write Speed: MAX
I 18:54:50 Link Size: Auto
I 18:54:50 Test Mode: No
I 18:54:50 BURN-Proof: Enabled
I 18:55:12 Optimal L1 Data Zone Start LBA: 2031440 (VTS_01, PGC: 1, Cell: 8, Vob/Cell ID: 1/8, Time: 01:03:04, SPLIP: No)
I 18:55:12 Optimal L0 Data Zone Capacity: 2*031*440
I 18:55:12 Optimal L0 Data Zone Method: IFO Cell Boundary, 'SPLIP' Flag Not Set
I 18:55:46 Filling Buffer...
I 18:55:46 Writing LeadIn...
I 18:55:48 Writing Image...
I 18:55:48 Writing Layer 0... (LBA: 0 - 2031439)
I 19:04:07 Writing Layer 1... (LBA: 2031440 - 4048735)
I 19:12:48 Synchronising Cache...
I 19:12:49 Closing Track...
I 19:13:10 Finalising Disc...
I 19:13:46 Image MD5: 0fd35f66f802c31d584a9a0c6b2c583c
I 19:13:46 Exporting Graph Data...
I 19:13:46 Graph Data File: D:\_NEC_DVD_RW_ND-4571A_1-02_2006-11-05_18-54_RITEK-S04-01_MAX_***.ibg
I 19:13:46 Export Successfully Completed!
I 19:13:46 Operation Successfully Completed! - Duration: 00:18:55
I 19:13:46 Average Write Rate: 7*938 KB/s (5.7x) - Maximum Write Rate: 11*500 KB/s (8.3x)
I 19:13:46 Cycling Tray before Verify...
I 19:14:16 Device Ready!
I 19:14:17 Operation Started!
I 19:14:17 Source Device: [1:2:0] _NEC DVD_RW ND-4571A 1-02 (G (ATA)
I 19:14:17 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RITEK-S04-01) (Speeds: 4x; 6x; 8x)
I 19:14:17 Image File: D:\***.img
I 19:14:17 Image File Sectors: 4*048*736 (MODE1/2048)
I 19:14:17 Image File Size: 8*291*811*328 bytes
I 19:14:17 Image File Volume Identifier: ***
I 19:14:17 Image File Implementation Identifier: Daikin U.S. Comtec Lab
I 19:14:17 Image File File System(s): ISO9660; UDF (1,02)
I 19:14:17 Verifying Sectors...
I 19:33:46 Device MD5: 0fd35f66f802c31d584a9a0c6b2c583c
I 19:33:46 Image MD5: 0fd35f66f802c31d584a9a0c6b2c583c
I 19:33:50 Exporting Graph Data...
I 19:33:50 Graph Data File: D:\_NEC_DVD_RW_ND-4571A_1-02_2006-11-05_18-54_RITEK-S04-01_MAX_***.ibg
I 19:33:50 Export Successfully Completed!
I 19:33:50 Operation Successfully Completed! - Duration: 00:19:29
I 19:33:50 Average Verify Rate: 6*926 KB/s (5.0x) - Maximum Verify Rate: 10*003 KB/s (7.2x)
File Type: jpg PLATINUM.jpg (121.7 KB, 2622 oglądane)
File Type: png Ritek-S04-01.png (156.0 KB, 575 oglądane)
NEC ND 4571A@1.02BT+RPC1(Nówka z serwisu od 2008/02/25 ) oraz GH20LS10@FL01(+riplock patch) R.I.P. SAMSUNG SH-224GB@SB00 (od 2017/01/06 )
lee99 jest offline
Stary 05.11.2006, 21:19   #2
lee99
DrBackup
Thumbs down Że tak powiem nie specjalnie to wygląda
Odczyt Liteonem hmmm...po zmianie warstwy napęd jak widać zaznaczone na zielono pierwszy wykres miał problem z odczytem ciekawe to biorąc pod uwagę wcześniejszy post i weryfikacje na nec.
Równiez Jitter bardzo rośnie aż do 16,6% max
File Type: png odczyt_x4_liteon.png (138.3 KB, 505 oglądane)
lee99 jest offline
Stary 05.11.2006, 21:28   #3
madmax2
Godzina 5-ta minut 30-ści
Avatar użytkownika madmax2
Data rejestracji: 06.10.2002
Pro***347;ba. Zr***243;b jeszcze test transferu na Litku.
Pozdrawiam.
Lepiej powiedzieć:
Lepiej powiedzieć:
Lepiej powiedzieć:
madmax2 jest offline
Stary 05.11.2006, 21:41   #4
lee99
DrBackup
Testuje sam odczyt na Necu bo wiem ***380;e nie zabardzo nadaje si***281; do test***243;w PIE/PIF no ale niewiem czy ten nap***281;d Liteona mi dali sprawny do ko***324;ca z serwisu kurcze ech
Ostatnio wypala***322;em Verbatima na nim i p***322;yta zosta***322;a wywalona do kosza...
http://forum.cdrinfo.pl/no-niki-opty...mkm-001-a.html
Ale jak***261; pr***281;dko***347;***263; ustawi***263; ? Bo je***380;eli z Jitter to max 4x powy***380;ej nie jest wy***347;wietlany dlatego zrobiony test jest z pr***281;dko***347;ci***261; w***322;a***347;nie tak***261;
EDIT
Robie teraz test na Nec a potem my***347;le ***380;e mo***380;e programem KProbe2 zrobie jeszcze raz test Liteonem
Ostatnio zmieniany przez lee99 : 05.11.2006 o godz. 21:52 Powód: EDIT
lee99 jest offline
Stary 05.11.2006, 22:21   #5
lee99
DrBackup
Post Odczyt na nec
Skanowanie PIE/PIF z 1ECC
wykorzystanie procesora podczas testu troche wysokie z uwagi na inne procesy działające w systemie
File Type: png odczyt_nec.png (128.0 KB, 395 oglądane)
File Type: png odczyt_nec_x8.png (129.0 KB, 386 oglądane)
lee99 jest offline
Stary 05.11.2006, 22:48   #6
lee99
DrBackup
Post Czy Nero CD-DVD Speed 4.7.0.0 czasem jest coś nie tego?
Data/Czas testu : 2006-11-05 22:44:13
Napęd : 1-0-3-0 H:LITE-ON DVDRW SHW-160P6S PS0B
Płyta : DVD+R DL , RITEKS04 [RiTEK Corporation]
Prędkość odczytu : 4x
Suma bloków ECC (PI/PIF) : 8/1
Zeskanowany zakres : 0 - 4048770
Liczba próbek : 169027
Liczba problemów : 0
PI Maksymalnie : 87
PI Średnio : 26,53
PI Suma : 752425
PIF Maksymalnie : 7
PIF Średnio : 0,06
PIF Suma : 1609
Tak to bardzo ciekawe o co tu chodzi ?
File Type: png liteon_kprobe_x4.png (132.2 KB, 380 oglądane)
lee99 jest offline
Stary 05.11.2006, 23:13   #7
lee99
DrBackup
Question cd...
Data/Czas testu : 2006-11-05 23:03:59
Prędkość odczytu : Maksymalna
Zeskanowany zakres : 0 - 4048734
Liczba próbek : 151604
PI Maksymalnie : 290
PI Średnio : 46,00
PI Suma : 1245589
PIF Maksymalnie : 162
PIF Średnio : 0,10
PIF Suma : 2582
File Type: png liteon_kprobe_max.png (130.4 KB, 348 oglądane)
lee99 jest offline
Stary 06.11.2006, 11:20   #8
lee99
DrBackup
Lightbulb Ostatni test
komentarze mile widziane
File Type: png dvdinfopro_max.png (47.6 KB, 419 oglądane)
File Type: png bad_crc.png (77.0 KB, 412 oglądane)
lee99 jest offline
Stary 06.11.2006, 14:43   #9
Napisany przez lee99 Podgląd Wiadomości
a co tu komentować? jest dobrze. litek daje radę a partia płytek jest dobra.
ed hunter jest offline
Stary 06.11.2006, 14:57   #10
lee99
DrBackup
No tak ale mnie dziwia różnice w wynikach no ale może tak ma być??
Najnowsze nero cd-dvd speed jest chyba troche niedopracowane z leksza mówiąc...
lee99 jest offline
Stary 02.12.2006, 18:10   #11
kurczak80
Data rejestracji: 07.05.2005
kurczak80 zaczyna zdobywać reputację <1 - 49 pkt>
Witam zakupi***322;em kilka sztuk tych platinium***243;w i mam pytanko w jakiej pr***281;dko***347;ci nagrywa***263; najlepiej.Nagrywarka LG gsa 4167b.Jest to kopia zapasowa gry za cene p***322;ytki 7z***322; szkoda zniszczy***263; orygina***322;.Moja p***322;yta ma id cmc.mag.d04 i pr***281;dko***347;***263; niby na p***322;ycie 8x a wykrywa 2.4.
Ostatnio zmieniany przez kurczak80 : 02.12.2006 o godz. 18:15
kurczak80 jest offline
Stary 02.12.2006, 19:12   #12
siwymariusz
Data rejestracji: 15.06.2002
Napisany przez kurczak80 Podgląd Wiadomości
Witam zakupiłem kilka sztuk tych platiniumów i mam pytanko w jakiej prędkości nagrywać najlepiej.Nagrywarka LG gsa 4167b.Jest to kopia zapasowa gry za cene płytki 7zł szkoda zniszczyć oryginał.Moja płyta ma id cmc.mag.d04 i prędkość niby na płycie 8x a wykrywa 2.4.
Mam takie same płytki i w Benq 1640 pokazuje zapis 2.4 mimo ze na płycie pisze 8 a samsung 182M pozwala na x4 ??
siwymariusz jest offline
Stary 04.02.2007, 19:56   #13
kowanski
Avatar użytkownika kowanski
Napisany przez siwymariusz Podgląd Wiadomości
Wystarczy wgrać bios BSRB
RITEK S04-001 8x,6x,4x,2.4x
Media Code Speed Edit V 1.0.9.6
Firmware: BENQ DVD DD DW1640 BSRB
Bootcode:
Overall supported media types: 253
DVD+R9 supported media types: 22
DVD+R supported media types: 95
DVD+RW supported media types: 17
DVD-R9 supported media types: 3
DVD-R supported media types: 78
DVD-RW supported media types: 38
CMC MAG D01-000 2.4x
CMC MAG D02-000 8x,6x,4x,2.4x
CMC MAG D03-064 8x,6x,4x,2.4x
CMC MAG D04-000 8x,6x,4x,2.4x
INFOME D01-000 2.4x
MBIPG101 R10-065 8x,6x,4x,2.4x
MKM 001-000 8x,6x,4x,2.4x
MKM 003-000 8x,6x,4x,2.4x
PHILIPS CD2-000 2.4x
PHILIPS PD2-000 2.4x
PRODISC D01-000 2.4x
RICOHJPN D00-001 2.4x
RICOHJPN D01-001 2.4x
RICOHJPN D01-002 8x,6x,4x,2.4x
RICOHJPN D01-067 8x,6x,4x,2.4x
RITEK D01-001 2.4x
RITEK D03-001 8x,6x,4x,2.4x
RITEK D03-130 8x,6x,4x,2.4x
RITEK S04-066 8x,6x,4x,2.4x
RITEK X01-001 2.4x
kowanski jest offline
Stary 02.12.2006, 19:36   #14
Firmware nagrywarki pozwala tylko na tak***261; pr***281;dko***347;***263;.
joujoujou jest offline
Stary 02.12.2006, 23:29   #15
kurczak80
Kurcze na nowy firmware to si***281; chyba ju***380; do niej nie doczekam a tak pozatym to te p***322;ytki od cmc wog***243;le dobre s***261; czy szrot nie mam mozliwo***347;ci test***243;w na Lg.
Wszystkie czasy w strefie CET. Aktualna godzina: 04:29.
