Stary 05.04.2017, 05:57   #16
MediaRange CD-R x52 Plasmon 97m27s18f
Pioneer BDR-PR1EPDV fw.1.01
NERO 2017 x10
Stary 03.05.2017, 06:50   #17
Pioneer DVR-116DBK fw.1.09
ImgBurn 2.5.8.0 x32 --> ~~26
Stary 13.05.2017, 08:05   #18
LG GCE-8526B fw.1.03
ImgBurn 2.5.8.0 x8
Stary 17.05.2017, 11:20   #19
Plextor PX-W4012TU fw.1.07
Nero 2017 x8
log :
Kod:
Windows 8 6.2
AMD64
Wow64Process
Nero Version: 18.0.15.0
Internal Version: 18,0,15,0
Recorder         : <PLEXTOR CD-R   PX-W4012A>     FW version: 1.07 - HA 1 TA 1 - 18.0.15.0
 Device bus      :  <>                            HA 1
 Host system bus :  <USB 2>
 Drive buffer    :  4096kB
 Bus Type        :  via Inquiry data
CD/DVD-ROM       : <HL-DT-ST DVDRAM GT30N    >    FW version: 1.01 - HA 1 TA 0 - 18.0.15.0
 Host system bus :  <IDE>
=== Scsi-Device-Map ===
DiskPeripheral       : KINGSTON SV300S37A120G          iaStor Port 0 ID 0  DMA: On
DiskPeripheral       : WDC WD7500BPKX-75HPJT0          iaStor Port 0 ID 1  DMA: Off
CdRomPeripheral      : HL-DT-ST DVDRAM GT30N           iaStor Port 0 ID 2  DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GT30N      D:   CdRom0
PLEXTOR CD-R   PX-W4012A   F:   CdRom1
AutoRun : 0
Excluded drive IDs:
BUFE           : 0
Physical memory     : 4090MB (4189108kB)
Free physical memory: 1934MB (1981184kB)
Memory in use       : 52 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
17.5.2017
Obraz dysku
08:19:47	#1 Text 0 File SCSIPTICommands.cpp, Line 617
08:19:47	#2 Text 0 File Burncd.cpp, Line 3723
	Włączono BURN-Proof
08:19:47	#3 PHASE 214 File dlgbrnst.cpp, Line 2108
	Generation of disc structures started
08:19:47	#4 Text 0 File ThreadedTransferInterface.cpp, Line 1166
	Removed 2 run-out blocks from end of track 1. Length: 345802 -> 345800.
08:19:47	#5 PHASE 215 File dlgbrnst.cpp, Line 2108
	Generation of disc structures completed
08:19:47	#6 Text 0 File Burncd.cpp, Line 4086
	Turn on Track-At-Once, using CD-R/RW media
08:19:47	#7 Text 0 File ThreadedTransferInterface.cpp, Line 1166
08:19:47	#8 Text 0 File ThreadedTransferInterface.cpp, Line 1166
08:19:47	#9 Text 0 File DlgWaitCD.cpp, Line 335
	[F: CD-R   PX-W4012A] Last possible write address on media:   359846
	Last address to be written:             345801
08:19:47	#10 Text 0 File DlgWaitCD.cpp, Line 347
	[F: CD-R   PX-W4012A] Write in overburning mode: NO (enabled: CD)
08:19:47	#11 Text 0 File DlgWaitCD.cpp, Line 3127
	Recorder: PLEXTOR CD-R   PX-W4012A;
	   CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
	   ATIP Data:
	     Special    Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
	     Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
08:19:47	#12 Text 0 File DlgWaitCD.cpp, Line 537
	[F: CD-R   PX-W4012A] >>> Protocol of DlgWaitCD activities: <<<
08:19:47	#13 Text 0 File ThreadedTransferInterface.cpp, Line 879
	 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
	    original disc pos #0 + 345802 (345802) = #345802/76:50.52
	    not relocatable, disc pos for caching/writing not required/not required
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 345800 blocks [F: PLEXTOR CD-R   PX-W4012A]
08:19:47	#14 Text 0 File ThreadedTransferInterface.cpp, Line 1095
	Prepare [F: PLEXTOR CD-R   PX-W4012A] for write in TAO
	DAO infos:
	 MCN: ""
	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0        307200     708509696, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	     -150 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
	     -150 |        1 |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x41 |   345802 |   345802 | 0x00
	   345802 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
	MediaType: CD-R
08:19:47	#15 Text 0 File ThreadedTransferInterface.cpp, Line 1166
08:19:47	#16 Text 0 File SCSIPTICommands.cpp, Line 404
08:19:47	#17 Text 0 File Burncd.cpp, Line 4984
	Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
08:19:48	#18 PHASE 24 File dlgbrnst.cpp, Line 2108
	Caching of files started
08:19:48	#19 Text 0 File Burncd.cpp, Line 5106
	Cache writing successful.
08:19:48	#20 PHASE 25 File dlgbrnst.cpp, Line 2108
	Caching of files completed
08:19:48	#21 PHASE 36 File dlgbrnst.cpp, Line 2108
	Burn process started at 8x (1*200 KB/s)
08:19:48	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
08:19:48	#23 Text 0 File Mmc.cpp, Line 21661
	Set BUFE: BURN-Proof -> ON
08:19:48	#24 Text 0 File ThreadedTransfer.cpp, Line 275
	Pipe memory size 83836800
08:29:43	#25 Text 0 File Mmc.cpp, Line 17260
	<PLEXTOR CD-R   PX-W4012A> start Close Track #2
08:29:44	#26 SPTI -1169 File SCSIPassThrough.cpp, Line 225
	CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1169)
	CDB Data:   0x51 00 00 00 00 00 00 00 20 00 00 00
	Sense Key:  0x02 (KEY_NOT_READY)
	Sense Code: 0x04
	Sense Qual: 0x08
	Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08
	Buffer x0762c240: Len x20
08:30:18	#27 PHASE 160 File dlgbrnst.cpp, Line 2108
	The write has been done at 8x (1*200 KB/s) speed by PoweRec
08:30:18	#28 Text 0 File Burncd.cpp, Line 5767
	Błąd niedopełnienia bufora uniknięty 4 raz(y)!
08:30:34	#29 Text 0 File SCSIPTICommands.cpp, Line 454
08:30:34	#30 Text 0 File Cdrdrv.cpp, Line 12297
08:30:34	#31 Text 0 File SCSIPTICommands.cpp, Line 617
Stary 29.05.2017, 16:48   #20
BTC-BCE-2410IM fw.A.23
ImgBurn 2.5.8.0 x12
Stary 01.06.2017, 07:54   #21
Teac CD-W58E fw.1.0A
ImgBurn 2.5.8.0 x8
Stary 21.06.2017, 06:06   #22
PLextor PX-800A fw.1.00
ImgBurn 2.5.8.0 x8
Stary 01.07.2017, 06:11   #23
Pioneer DVR-110DBK fw.1.41
ImgBurn 2.5.8.0 x4
Stary 03.11.2017, 08:37   #24
MediaRange 52x CD-R ATIP :97m27s18f Plasmon (Made in China)
Pioneer BDR-S11JX fw.1.02
ImgBurn 2.5.8.0 x10
Stary 06.11.2017, 12:35   #25
PioData DVR-S21DBK fw.1.D9
ImgBurn 2.5.8.0 x32
Stary 18.11.2017, 07:59   #26
Pioneer DVR-108 fw.1.20
ImgBurn 2.5.8.0 x16
Stary 25.12.2017, 07:54   #27
Pioneer DVR-107D fw.1.22
ImgBurn 2.5.8.0 x8
Stary 20.03.2018, 07:22   #28
Plextor PX-712A fw.1.09
ImgBurn 2.5.8.0 x8
Stary 18.09.2018, 05:16   #29
Plextor PX-L890SA fw.1.07
ImgBurn 2.5.8.0 x32
Stary 09.10.2018, 06:56   #30
LG WH16NS60 fw.1.01
ImgBurn 2.5.8.0 x16
Audio CD vs rip Flac - dlaczego brzmi gorzej deton24 Audio/Stacjonarne nagrywarki i nośniki CD-R Audio 12 11.07.2015 00:08
DTS jako Audio CD możliwe - sposób konwersji i wymagania (opis) scalak77 Audio/Stacjonarne nagrywarki i nośniki CD-R Audio 15 18.04.2012 09:30
problem z cd ? przeciez czyta cd -_- zubaaa Hardware 1 21.02.2009 01:23
Odczyt z uszkodzonego CD gion Napędy optyczne CD 5 31.01.2009 23:56
[Muzyka] Dawno temu w...Polsce - przegrywalnie płyt CD Jabba the Hutt Film i Muzyka 15 23.01.2009 14:34
Wszystkie czasy w strefie CET. Aktualna godzina: 07:36.
