#16 |
| #ads | |
#17 |
#18 |
#19 |
MediaRange CD-R x52 Plasmon 97m27s18f
Plextor PX-W4012TU fw.1.07 Nero 2017 x8 log : Kod:
Windows 8 6.2 AMD64 Wow64Process Nero Version: 18.0.15.0 Internal Version: 18,0,15,0 Recorder : <PLEXTOR CD-R PX-W4012A> FW version: 1.07 - HA 1 TA 1 - 18.0.15.0 Device bus : <> HA 1 Host system bus : <USB 2> Drive buffer : 4096kB Bus Type : via Inquiry data CD/DVD-ROM : <HL-DT-ST DVDRAM GT30N > FW version: 1.01 - HA 1 TA 0 - 18.0.15.0 Device bus : <> HA 1 Host system bus : <IDE> === Scsi-Device-Map === DiskPeripheral : KINGSTON SV300S37A120G iaStor Port 0 ID 0 DMA: On DiskPeripheral : WDC WD7500BPKX-75HPJT0 iaStor Port 0 ID 1 DMA: Off CdRomPeripheral : HL-DT-ST DVDRAM GT30N iaStor Port 0 ID 2 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GT30N D: CdRom0 PLEXTOR CD-R PX-W4012A F: CdRom1 ======================= AutoRun : 0 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 4090MB (4189108kB) Free physical memory: 1934MB (1981184kB) Memory in use : 52 % Uncached PFiles: 0x0 Global Bus Type: default (0) Check supported media : Disabled (0) 17.5.2017 Obraz dysku 08:19:47 #1 Text 0 File SCSIPTICommands.cpp, Line 617 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 08:19:47 #2 Text 0 File Burncd.cpp, Line 3723 PLEXTOR CD-R PX-W4012A Włączono BURN-Proof 08:19:47 #3 PHASE 214 File dlgbrnst.cpp, Line 2108 Generation of disc structures started 08:19:47 #4 Text 0 File ThreadedTransferInterface.cpp, Line 1166 Removed 2 run-out blocks from end of track 1. Length: 345802 -> 345800. 08:19:47 #5 PHASE 215 File dlgbrnst.cpp, Line 2108 Generation of disc structures completed 08:19:47 #6 Text 0 File Burncd.cpp, Line 4086 Turn on Track-At-Once, using CD-R/RW media 08:19:47 #7 Text 0 File ThreadedTransferInterface.cpp, Line 1166 Removed 2 run-out blocks from end of track 1. Length: 345802 -> 345800. 08:19:47 #8 Text 0 File ThreadedTransferInterface.cpp, Line 1166 Removed 2 run-out blocks from end of track 1. Length: 345802 -> 345800. 08:19:47 #9 Text 0 File DlgWaitCD.cpp, Line 335 [F: CD-R PX-W4012A] Last possible write address on media: 359846 Last address to be written: 345801 08:19:47 #10 Text 0 File DlgWaitCD.cpp, Line 347 [F: CD-R PX-W4012A] Write in overburning mode: NO (enabled: CD) 08:19:47 #11 Text 0 File DlgWaitCD.cpp, Line 3127 Recorder: PLEXTOR CD-R PX-W4012A; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 08:19:47 #12 Text 0 File DlgWaitCD.cpp, Line 537 [F: CD-R PX-W4012A] >>> Protocol of DlgWaitCD activities: <<< ========================================= 08:19:47 #13 Text 0 File ThreadedTransferInterface.cpp, Line 879 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet) 2 indices, index0 (150) not provided original disc pos #0 + 345802 (345802) = #345802/76:50.52 not relocatable, disc pos for caching/writing not required/not required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 345800 blocks [F: PLEXTOR CD-R PX-W4012A] -------------------------------------------------------------- 08:19:47 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1095 Prepare [F: PLEXTOR CD-R PX-W4012A] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 708509696, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 345802 | 345802 | 0x00 345802 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 MediaType: CD-R 08:19:47 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1166 Removed 2 run-out blocks from end of track 1. Length: 345802 -> 345800. 08:19:47 #16 Text 0 File SCSIPTICommands.cpp, Line 404 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 08:19:47 #17 Text 0 File Burncd.cpp, Line 4984 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 08:19:48 #18 PHASE 24 File dlgbrnst.cpp, Line 2108 Caching of files started 08:19:48 #19 Text 0 File Burncd.cpp, Line 5106 Cache writing successful. 08:19:48 #20 PHASE 25 File dlgbrnst.cpp, Line 2108 Caching of files completed 08:19:48 #21 PHASE 36 File dlgbrnst.cpp, Line 2108 Burn process started at 8x (1*200 KB/s) 08:19:48 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 08:19:48 #23 Text 0 File Mmc.cpp, Line 21661 Set BUFE: BURN-Proof -> ON 08:19:48 #24 Text 0 File ThreadedTransfer.cpp, Line 275 Pipe memory size 83836800 08:29:43 #25 Text 0 File Mmc.cpp, Line 17260 <PLEXTOR CD-R PX-W4012A> start Close Track #2 08:29:44 #26 SPTI -1169 File SCSIPassThrough.cpp, Line 225 CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1169) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x04 Sense Qual: 0x08 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08 Buffer x0762c240: Len x20 08:30:18 #27 PHASE 160 File dlgbrnst.cpp, Line 2108 The write has been done at 8x (1*200 KB/s) speed by PoweRec 08:30:18 #28 Text 0 File Burncd.cpp, Line 5767 Błąd niedopełnienia bufora uniknięty 4 raz(y)! 08:30:34 #29 Text 0 File SCSIPTICommands.cpp, Line 454 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 08:30:34 #30 Text 0 File Cdrdrv.cpp, Line 12297 DriveLocker: UnLockVolume completed 08:30:34 #31 Text 0 File SCSIPTICommands.cpp, Line 617 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL ![]() ![]() ![]() ![]() ![]()
#20 |
#21 |
#22 |
#23 |
#24 |
MediaRange 52x CD-R ATIP :97m27s18f Plasmon (Made in China)
Pioneer BDR-S11JX fw.1.02 ImgBurn 2.5.8.0 x10 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#25 |
PioData DVR-S21DBK fw.1.D9 ImgBurn 2.5.8.0 x32 ![]() ![]() ![]() ![]() ![]() ![]()
#26 |
Pioneer DVR-108 fw.1.20 ImgBurn 2.5.8.0 x16 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#27 |
Pioneer DVR-107D fw.1.22 ImgBurn 2.5.8.0 x8 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#28 |
Plextor PX-712A fw.1.09 ImgBurn 2.5.8.0 x8 ![]() ![]() ![]() ![]() ![]()
#29 |
Plextor PX-L890SA fw.1.07 ImgBurn 2.5.8.0 x32 ![]() ![]() ![]() ![]() ![]()
#30 |
| Audio CD vs rip Flac - dlaczego brzmi gorzej | deton24 | Audio/Stacjonarne nagrywarki i nośniki CD-R Audio | 12 | 11.07.2015 00:08 |
| DTS jako Audio CD możliwe - sposób konwersji i wymagania (opis) | scalak77 | Audio/Stacjonarne nagrywarki i nośniki CD-R Audio | 15 | 18.04.2012 09:30 |
| problem z cd ? przeciez czyta cd -_- | zubaaa | Hardware | 1 | 21.02.2009 01:23 |
| Odczyt z uszkodzonego CD | gion | Napędy optyczne CD | 5 | 31.01.2009 23:56 |
| [Muzyka] Dawno temu w...Polsce - przegrywalnie płyt CD | Jabba the Hutt | Film i Muzyka | 15 | 23.01.2009 14:34 |
