Jabba |
te płytki są do dupy - na 8 padło mi 4 :( zaraz na początku nagrywania. kupiłem je w IdealPC ale na szczęście zgodzili się mi je wymienić...
Verbatim DVD+R 1-2,4x
Płyta Verbatim DVD+R 1-2,4x ; cake box (25 szt).
Info z DVDInfo pro : MediaInformation Region information N/A not a DVD-VIDEO Media code/Manufacturer ID CMC MAG R01 Format Capacity 4096.00GB(4398.05 Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Media Id Code Speed 2.4x 3324KBps Available Write Descriptor CLV 2.4x 3324KBps Data area starting sector 30000h Data area end sector 7FFFFFFFh Linear Density 0.267um/bit Track Density 0.74um/track Number of Layers 1 Dane z Nero CD Speed : Manufacturer : CMC Code : CMC MAG Disc Type : DVD+R Usage : General Recording Layer : - Recording Speed : 2.5 X Capacity : 4.38 GB 4700375040 Bytes Additional Capacity : - Overburn Capacity : - Cena w Delfinie (Breslau) - 9 zł A więc niedobrze, mamy produkt CMC Magnetics... :( Jabba |
TDK DVD+R 1-4x
Płyta TDK DVD+R 1-4x, Made in Taiwan
Dane z DVDInfo : Region information N/A not a DVD-VIDEO Media code/Manufacturer ID RICOHJPNR01 Format Capacity 4096.00GB(4398.05 Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Media Id Code Speed 4.0x 5540KBps Available Write Descriptor CLV 4.0x 5540KBps Available Write Descriptor CLV 2.4x 3324KBps Data area starting sector 30000h Data area end sector 7FFFFFFFh Linear Density 0.267um/bit Track Density 0.74um/track Number of Layers 1 Cena w Delfinie (Breslau) - 9 zł Jabba |
Re: Re: Re: zaloze sie ze x2
AKOSS x1 - cena wysyłkowo w ładnym pudełku ok. 4.6, w Opolu Quanto 5.9 :)
nagrane ok. 20 , problemy z 3, nagrywarka Lg-Gm4020b DVDINFO: Media Information Region information N/A not a DVD-VIDEO Media code/Manufacturer ID NANYAP1861 Format Capacity Blank Free Blocks 412352512 Free Capacity 4.38GB(4.71GB) Book Type DVD-R Media Type DVD-R Media Id Code Speed 2.0x 2770KBps Available Write Descriptor CLV 2.0x 2770KBps Available Write Descriptor CLV 1.0x 1385KBps Write Strategy Speed 1.0x 1385KBp Data area starting sector 30000h Linear Density 0.267um/bit Track Density 0.74um/track Number of Layers 1 |
TDK DVD-RW 1-2x
TDK DVD-RW 1-2x ; Made in Japan
Dane z Nero CD Speed : Manufacturer : TDK Code : TDK502sakuM3 Disc Type : DVD-RW Usage : General Recording Layer : - Recording Speed : 1 X - 2 X Capacity : 4.38 GB 4707321856 Bytes Additional Capacity : - Overburn Capacity : - Smart Burn Media Check : Drive Type = DVD DUAL Disc Type = DVD-RW Manufacturer Maybe = TDK Corporation Smart-Burn Speed Limit = Wrt(2.0X),Rd(6.0X) Cena w Delfinie (Breslau) - 15 zł. Jabba |
Ja mam przeniesiona kolekcje VHS na biale, pozbawione nadruku Princo x1. Robilem to sukcesywnie od stycznia i wypalilem okolo 300 sztuk. Jak dotad sie odtwarzaja, ale przed swietami zrobie gruntowny przeglad. Riteki i Ricohy bez zmian. No i trzymam to wszystko w ciemnej komodzie, w czarnych pudelkach. |
Od naklejki, to plyta moze jedynie dostac ciut wiekszych wibracji, ktore tylko spoteguja ilosc bledow fizycznie znajdujacych sie na plycie... Jak CobraVerde pisal, firmowe-oklejone plytki czytaja sie spokojnie - markowa i dobrze wypalona plyta, nawet z naklejka, czyta sie dobrze... u mnie tez firmowe plytki z naklejkami czytaja sie bez problemow, natomiast wszystkie ale to wszystkie ESPERANZY i PRINCO jakie mam albo juz wyladowaly w koszu, albo czekaja na RIP na HDD, i ponowne nagranie danych na czyms lepszym...
zaloze sie ze x2
bo sony ich nie pali x4, ale jedna uwaga
te ktore ja nagrywalem princo biale bez nadruku x4, wszystkie sa jak narazie ok. z tym ze nic nie nalepialem na nie ! wiec moze to wina tych nalepek ? |
pozdrawiam Salmander |
Wierze, jedna sztuka to malo by cos o plytkach powiedziec, zastanawiajace sa jedynie te "niereguralnosci" tzn. jakby odpryski przy samym srodku plyty,
na marginesie uwaga odnosnie płyt DVD-r Esperanza x4 , ciekawe ze spotkalem sie z dwoma "wersjami" rozniacymi sie nadrukami... ale jak na razie chodza bez problmu obie, w "Nero CD-DVD Speed" wykres optymalny tylko wlasnie, pytanie, jak dlugo... (musze jeszcze sprawdzic czy dane w Dvdinfo sa takie same). |
Oczywiście Verbatim i TDK rządzą ! Jabba |
| Wszystkie czasy w strefie CET. Aktualna godzina: 10:20. |
