Stary 09.04.2025, 09:54   #1
pepst
Data rejestracji: 15.02.2010
pepst niedługo stanie się sławny ;) <50 - 149 pkt>pepst niedługo stanie się sławny ;) <50 - 149 pkt>
Princo DVD-R DL
Optiarc DVD RW AD-5200A 1.09, 6,44 GB burned at 4x
MID: PRINCORDL32
sold as "Platinum 4,7 GB 8x DVD-R" (misprint)
made in Taiwan
Princo DVD-R DL-disc_quality_07-aprila-2025.png   Princo DVD-R DL-transfer_rate_07-aprila-2025.png
pepst jest offline   Odpowiedz cytując ten post
Stary 09.04.2025, 09:56   #2
pepst
Lite-On eNAU608 5 CL02, 6,73 GB burned at 3x
MID: PRINCORDL32
made in Taiwan
Princo DVD-R DL-disc_quality_07-aprila-2025-lt.png   Princo DVD-R DL-transfer_rate_07-aprila-2025-lt.png
Stary 09.04.2025, 14:15   #3
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Dual Layer discs sold as 4,7 GB?
Oinker jest offline   Odpowiedz cytując ten post
Stary 09.04.2025, 20:39   #4
pepst
Napisany przez Oinker Podgląd Wiadomości
Exactly. Maybe to avoid compatibility and quality problems. So that the customer would not be tempted to burn the media as a dual layer and avoid problems with the transition between layers.
Stary 10.04.2025, 00:40   #5
Oinker
But this media requires DL compatible drives, thus I don't see the point of selling this as 4,7 GB discs. Really weird. Maybe some mixup of either disc and/or label?
Stary 10.04.2025, 12:37   #6
pepst
Most likely. They are still available, if you want to test them by yourself: https://www.aliexpress.com/item/1005005324410136.html
Stary 18.04.2025, 20:35   #7
pepst
Optiarc DVD RW AD-5200A 1.09, 7,77 GB burned at 6x
MID: PRINCORDL32
made in Taiwan
Stary 28.04.2025, 16:57   #8
pepst
LG GSA-H12N UL02, 7,11 GB burned at 2x (only available speed)
MID: PRINCORDL32
made in Taiwan
Princo DVD-R DL-disc_quality_28-aprila-2025.png   Princo DVD-R DL-transfer_rate_28-aprila-2025-trt.png
Stary 15.05.2025, 13:03   #9
pepst
Optiarc DVD RW AD-5200A 1.09, 7,04 GB burned at 4x
MID: PRINCORDL32
sold as "Platinum 4,7 GB 8x DVD-R" (misprint)made in Taiwan
Princo DVD-R DL-disc_quality_15-maja-2025.png   Princo DVD-R DL-transfer_rate_15-maja-2025-2.png
Stary 20.09.2025, 21:22   #10
pepst
Lite-On ATAPI iHBS212 2 HL05, 7.54 GB burned at 8x speed
sold as "Platinum 4.7 GB 8x DVD-R"
MID: PRINCORDL32
manufactured in Taiwan
Princo DVD-R DL-disc_quality_20-septembra-2025-2.png   Princo DVD-R DL-transfer_rate_20-septembra-2025.png
Stary 21.09.2025, 20:58   #11
pepst
Lite-On ATAPI iHBS212 2 HL05, 7,72 GB burned at 4x
MID: PRINCORDL32
Stary 04.11.2025, 14:40   #12
pepst
Lite-On ATAPI iHBS212 2 HL05, 7,32 GB burned at 4x
MID: PRINCORDL32
Princo DVD-R DL-disc_quality_04-novembra-2025.png   Princo DVD-R DL-transfer_rate_04-novembra-2025.png
Stary 24.01.2026, 19:14   #13
pepst
Lite-On ATAPI iHBS212 2 HL05, 6,64 GB burned at 4x speed
MID: PRINCORDL32
Stary 24.01.2026, 19:16   #14
pepst
Lite-On ATAPI iHBS212 2 HL05, 7,35 GB burned at 4x speed
MID: PRINCORDL32
dl, dvd-r, princo
Wszystkie czasy w strefie CET. Aktualna godzina: 00:18.
