Stary 04.10.2005, 13:41   #16
JarasMSR
Avatar użytkownika JarasMSR
Data rejestracji: 27.11.2003
JarasMSR zaczyna zdobywać reputację <1 - 49 pkt>
nie wiem jak z minusami, ale dzisiaj w delfinie łyknąłem 30 Verbatimów DVD+R srebrnych, 1,40PLN/szt. MCC-003...
JarasMSR jest offline
Stary 04.10.2005, 22:27   #17
Jabba the Hutt
Lord of the Sword
Data rejestracji: 06.04.2002
Z wałka te Verby jak rozumiem ? Podaj pełny zapis DVD Identifier ? Są x16 czy x8 ?
Jabba
SITH LORD
Jabba the Hutt jest offline
Stary 05.10.2005, 00:15   #18
M@X
Get a Mac!
Avatar użytkownika M@X
Data rejestracji: 18.04.2003
Prosze :
Unique Disc Identifier : [DVD-R:TYG02]
Disc & Book Type : [DVD-R] - [DVD-ROM]
Manufacturer Name : [Taiyo Yuden Co. Ltd.]
Manufacturer ID : [TYG02]
Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)]
** INFO : Drive = HL-DT-ST DVDRAM GSA-4040B [FW A302]
** INFO : Write Capabilities = DVD+R DVD+RW
** INFO : Write Capabilities = DVD-R DVD-RW DVD-RAM
** INFO : Disc = [DVD-R:TYG02]
** INFO : Reference Speed : 1x DVD = 1385 kBps
** INFO : An Writeable Disc Is Recommended For Accurate Results
** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below
** INFO : GET PERFORMANCE Write Speed Descriptor(s)
Descriptor #1 = 2770 kBps ( 2.00x) - [CLV/Non-Pure CAV]
** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command]
** WARNING : MODE SENSE Is Obsolete And Not Always Properly Supported
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 c1 fd 9e d8 52 00 02 87 0d 10 66 78 80 00 .@....R.....fx..
0010 : 03 54 59 47 30 32 00 00 04 00 00 00 00 00 00 00 .TYG02..........
0020 : 05 aa a2 22 22 20 02 00 06 08 0e 11 87 78 80 00 ..."" .......x..
0030 : 07 88 80 00 00 00 00 00 08 06 13 0d 10 0e 07 00 ................
0040 : 09 97 07 0d 0b 78 88 00 0a 80 00 00 00 00 10 00 .....x..........
0050 : 0b 06 18 17 85 78 75 00 0c d6 89 a8 92 01 20 00 .....xu....... .
0060 : 0d 10 00 d0 00 00 00 00 ........
** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
** INFO : Format 10h - Physical Format Information Of Control Data Zone
0000 : 25 0f 02 00 00 03 00 00 00 25 e3 3f 00 00 00 00 %........%.?....
[ DVD Identifier - http://DVD.Identifier.CDfreaks.com ]
M@X jest offline
Stary 05.10.2005, 08:29   #19
kowanski
Avatar użytkownika kowanski
Data rejestracji: 25.02.2003
Ja też kupiłem Verby DVD+R 8x cake 25 szt za 35 zł w Delfinie - MCC003
kowanski jest offline
Stary 05.10.2005, 08:37   #20
Pagerus
.: Zapracowany :.
Avatar użytkownika Pagerus
Data rejestracji: 23.01.2003
Pagerus niedługo stanie się sławny ;) <50 - 149 pkt>Pagerus niedługo stanie się sławny ;) <50 - 149 pkt>
Może to głupie pytanie - ale gdzie się mieści ten cały Delfin
"Codziennie dowiaduje się czegoś nowego" - Pagerus
Pagerus jest offline
Stary 05.10.2005, 08:59   #21
JarasMSR
Napisany przez Jabba the Hutt
Jabba
poszły już, bo to dla kumpla były, ale raczej na 100% 8x.
Stary 05.10.2005, 09:30   #22
melag
MiniDisc
Avatar użytkownika melag
Data rejestracji: 01.02.2005
Napisany przez kowanski
Ja kupiłem cake`25 (1,35zł) za 33,75zł w Proline też MCC 003
8 )
melag jest offline
Stary 05.10.2005, 12:24   #23
kowanski
Napisany przez Pagerus
www.delfin-cdr.pl
Stary 05.10.2005, 14:34   #24
Pagerus
.: Zapracowany :.
Dzięki za info Ode mnie to niestety spory kawał drogi - a i Proline jakoś mi tak bardziej po drodze... no i płytki na których nagrywam są tam 5gr na sztuce tańsze
Stary 10.10.2005, 21:09   #25
Jabba the Hutt
Lord of the Sword
Jak polazłem dziś do Delfina to już nie było srebrnych Verbów. Ani plus, ani minus. Kupiłem 10 TDK (nosnik TTH01 - TTG nie ma). W cake tylko Verby PEARL (czyli CMC).
Jabba
SITH LORD
Stary 14.11.2005, 00:14   #26
devil-80
Avatar użytkownika devil-80
Data rejestracji: 07.12.2004
devil-80 zaczyna zdobywać reputację <1 - 49 pkt>
PEARL raczej od Ritekai nie polecam,tak samo jak proline w Poznaniu,takiej obsługi jeszcze nie widziałem na 50 płyt cdr 20 z błędami a na reklamację pół roku już czekam i pewnie się nie doczekam,w każdym bądź razie nie polecam Verbatim dvd+ i - Pearl jak sklepu Proline
devil-80 jest offline
Stary 14.11.2005, 09:12   #27
kowanski
Nie są złe u mnie na BENQ 1640 Vernbatim Pearl DVD-R x4 palą sią bardzo dobrze, a x8 dobrze
Test x8 - nośnik RITEK G05
Stary 14.11.2005, 09:16   #28
devil-80
możliwe tylko ja mam RitekR03a nie g05 tak jak ty
Stary 14.11.2005, 10:11   #29
kowanski
R03 to DVD+Ra, G05 to DVD-R
Stary 14.11.2005, 10:37   #30
devil-80
no zgadza się i przyznam ,że minusy palą się troszke lepiej niż +,ale ogólnie chyba wole od mcc
Wszystkie czasy w strefie CET. Aktualna godzina: 09:18.
