#16 |
Data rejestracji: 27.11.2003
nie wiem jak z minusami, ale dzisiaj w delfinie łyknąłem 30 Verbatimów DVD+R srebrnych, 1,40PLN/szt. MCC-003...
| #ads | |
#17 |
Lord of the Sword
Data rejestracji: 06.04.2002
Z wałka te Verby jak rozumiem ? Podaj pełny zapis DVD Identifier ? Są x16 czy x8 ?
Jabba |
#18 |
Get a Mac!
Prosze :
---------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:TYG02] ---------------------------------------------------------------------------- Disc & Book Type : [DVD-R] - [DVD-ROM] Manufacturer Name : [Taiyo Yuden Co. Ltd.] Manufacturer ID : [TYG02] Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)] ---------------------------------------------------------------------------- ** INFO : Drive = HL-DT-ST DVDRAM GSA-4040B [FW A302] ** INFO : Write Capabilities = DVD+R DVD+RW ** INFO : Write Capabilities = DVD-R DVD-RW DVD-RAM ** INFO : Disc = [DVD-R:TYG02] ** INFO : Reference Speed : 1x DVD = 1385 kBps ** INFO : An Writeable Disc Is Recommended For Accurate Results ** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below ** INFO : GET PERFORMANCE Write Speed Descriptor(s) Descriptor #1 = 2770 kBps ( 2.00x) - [CLV/Non-Pure CAV] ** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command] ** WARNING : MODE SENSE Is Obsolete And Not Always Properly Supported Descriptor #1 = 2770 kBps ( 2.00x) - [CLV/Non-Pure CAV] ---------------------------------------------------------------------------- ** INFO : Hex Dump Of 'Media Code'-Block Listed Below ** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded ** INFO : Format 0Eh - Pre-Recorded Information In Lead-In 0000 : 01 40 c1 fd 9e d8 52 00 02 87 0d 10 66 78 80 00 .@....R.....fx.. 0010 : 03 54 59 47 30 32 00 00 04 00 00 00 00 00 00 00 .TYG02.......... 0020 : 05 aa a2 22 22 20 02 00 06 08 0e 11 87 78 80 00 ..."" .......x.. 0030 : 07 88 80 00 00 00 00 00 08 06 13 0d 10 0e 07 00 ................ 0040 : 09 97 07 0d 0b 78 88 00 0a 80 00 00 00 00 10 00 .....x.......... 0050 : 0b 06 18 17 85 78 75 00 0c d6 89 a8 92 01 20 00 .....xu....... . 0060 : 0d 10 00 d0 00 00 00 00 ........ ** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below ** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded ** INFO : Format 10h - Physical Format Information Of Control Data Zone 0000 : 25 0f 02 00 00 03 00 00 00 25 e3 3f 00 00 00 00 %........%.?.... ---------------------------------------------------------------------------- [ DVD Identifier - http://DVD.Identifier.CDfreaks.com ] ---------------------------------------------------------------------------- |
#19 |
Data rejestracji: 25.02.2003
Ja też kupiłem Verby DVD+R 8x cake 25 szt za 35 zł w Delfinie - MCC003
#20 |
.: Zapracowany :.
Data rejestracji: 23.01.2003
Może to głupie pytanie - ale gdzie się mieści ten cały Delfin
"Codziennie dowiaduje się czegoś nowego" - Pagerus
#21 | |
#22 | |
MiniDisc
![]() Data rejestracji: 01.02.2005
8 ) |
#23 | |
#24 |
.: Zapracowany :.
Dzięki za info
Ode mnie to niestety spory kawał drogi - a i Proline jakoś mi tak bardziej po drodze... no i płytki na których nagrywam są tam 5gr na sztuce tańsze
#25 |
Lord of the Sword
Jak polazłem dziś do Delfina to już nie było srebrnych Verbów. Ani plus, ani minus. Kupiłem 10 TDK (nosnik TTH01 - TTG nie ma). W cake tylko Verby PEARL (czyli CMC).
Jabba |
#26 |
Data rejestracji: 07.12.2004
PEARL raczej od Riteka
i nie polecam,tak samo jak proline w Poznaniu,takiej obsługi jeszcze nie widziałem na 50 płyt cdr 20 z błędami a na reklamację pół roku już czekam i pewnie się nie doczekam,w każdym bądź razie nie polecam Verbatim dvd+ i - Pearl jak sklepu Proline
Zaglosuj jak mozesz http://www.olay.pl/index.php?id=konk...78&vote=1&pg=0 http://www.olay.pl/index.php?id=konk...96&vote=1&pg=2 |
#27 |
Nie są złe u mnie na BENQ 1640 Vernbatim Pearl DVD-R x4 palą sią bardzo dobrze, a x8 dobrze
![]() Test x8 - nośnik RITEK G05
#28 |
możliwe tylko ja mam RitekR03a nie g05 tak jak ty
#29 |
R03 to DVD+Ra, G05 to DVD-R
#30 |
no zgadza się i przyznam ,że minusy palą się troszke lepiej niż +,ale ogólnie chyba wole od mcc
