Może to głupie pytanie - ale gdzie się mieści ten cały Delfin???
Ja też kupiłem Verby DVD+R 8x cake 25 szt za 35 zł w Delfinie - MCC003 :)
Prosze :
---------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:TYG02] ---------------------------------------------------------------------------- Disc & Book Type : [DVD-R] - [DVD-ROM] Manufacturer Name : [Taiyo Yuden Co. Ltd.] Manufacturer ID : [TYG02] Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)] ---------------------------------------------------------------------------- ** INFO : Drive = HL-DT-ST DVDRAM GSA-4040B [FW A302] ** INFO : Write Capabilities = DVD+R DVD+RW ** INFO : Write Capabilities = DVD-R DVD-RW DVD-RAM ** INFO : Disc = [DVD-R:TYG02] ** INFO : Reference Speed : 1x DVD = 1385 kBps ** INFO : An Writeable Disc Is Recommended For Accurate Results ** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below ** INFO : GET PERFORMANCE Write Speed Descriptor(s) Descriptor #1 = 2770 kBps ( 2.00x) - [CLV/Non-Pure CAV] ** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command] ** WARNING : MODE SENSE Is Obsolete And Not Always Properly Supported Descriptor #1 = 2770 kBps ( 2.00x) - [CLV/Non-Pure CAV] ---------------------------------------------------------------------------- ** INFO : Hex Dump Of 'Media Code'-Block Listed Below ** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded ** INFO : Format 0Eh - Pre-Recorded Information In Lead-In 0000 : 01 40 c1 fd 9e d8 52 00 02 87 0d 10 66 78 80 00 .@....R.....fx.. 0010 : 03 54 59 47 30 32 00 00 04 00 00 00 00 00 00 00 .TYG02.......... 0020 : 05 aa a2 22 22 20 02 00 06 08 0e 11 87 78 80 00 ..."" .......x.. 0030 : 07 88 80 00 00 00 00 00 08 06 13 0d 10 0e 07 00 ................ 0040 : 09 97 07 0d 0b 78 88 00 0a 80 00 00 00 00 10 00 .....x.......... 0050 : 0b 06 18 17 85 78 75 00 0c d6 89 a8 92 01 20 00 .....xu....... . 0060 : 0d 10 00 d0 00 00 00 00 ........ ** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below ** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded ** INFO : Format 10h - Physical Format Information Of Control Data Zone 0000 : 25 0f 02 00 00 03 00 00 00 25 e3 3f 00 00 00 00 %........%.?.... ---------------------------------------------------------------------------- [ DVD Identifier - http://DVD.Identifier.CDfreaks.com ] ---------------------------------------------------------------------------- |
Z wałka te Verby jak rozumiem ? Podaj pełny zapis DVD Identifier ? Są x16 czy x8 ?
Jabba |
nie wiem jak z minusami, ale dzisiaj w delfinie łyknąłem 30 Verbatimów DVD+R srebrnych, 1,40PLN/szt. MCC-003...
Dzisiaj lyknalem cake 25 sztuk DVD-R Verbatim... W ATIP maja wpisane TY, ale jakos nie chce mi sie wierzyc ze to ta firma, bo plyta strasznie tnie na moim stacjonarnym odtwarzaczu DVD. TY to amrka bliska MCC, wiec nie byloby takich walkow, gdyby to byl oryginalny produkt :-(. Czy ktos je testowal? Sa srebrne, deklarowana predkosc to 8 choc moja nagrywarka upeira sie, ze nie nagra ich wyzej niz 2x :-(. Od poprzednich odroznia je fakt, ze napisy "4.7GB 120min" i"8x Certified" napisane sa zwykla czcionka typu Arial, a nie ta charakterystyczna dla verbatima "futureska". Z kolei napis "DVD-R for recording" zostal zastapiony napisem "DVD-Recordable" napochanym rowniez ta ordynarna, prosta czcionka. Czy ktos to testowal? Moze zrobic testy na KProbe czy czyms innym i napisac ile jest to warte? W hurtowni poinformowano mnie ze tych "dawnych" verbow nie ma i raczej nie bedzie. WTF?
Płyta Verbatim Advanced AZO+ 16x Certified DVD-R
pudełko grube. Made in Taiwan ---------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:MCC 03RG20 ] ---------------------------------------------------------------------------- Disc & Book Type : [DVD-R] - [DVD-R] Manufacturer Name : [Mitsubishi Chemical Corp.] Manufacturer ID : [MCC 03RG20 ] Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)] ---------------------------------------------------------------------------- [ DVD Identifier - http://DVD.Identifier.CDfreaks.com ] ---------------------------------------------------------------------------- Skoro to MCC to może warto poszukać w pudełkach CAKE po 10 lu 25 sztuk ? Będzie na pewno tańsza. Bo tu ceny nie pamietam ale na pewno powyżej 2 zł. Jabba |
Byłem wczoraj w Delfinie - nadal nie ma srebrnych Verbatimów i pewnie już nie będzie. Kupiłem za to 20 cdrów Verbatim Pastel (TY). No i 5 DVD-R Pastel - niestety w slimach i cena dobija - 2,30 zł. To ciut za drogo jak na archiwizowanie seriali SF. Ciekawostka - nie było nawet TDK DVD-R (na wałku).
Sklep VAS (Tęczowa 57) odwiedziłem - również brak srebnych Verbów. A był może ktoś na giełdzie ? Jaka tam sytuacja ? Być może wybiorę się do Proline jeszcze ale to Rynek, więc dla mnie gorzej (auto trudno postawić, opłaty parkingowe). Czy na giełdzie ktos widział Blue Diamond CDR (Verbatima) ? Pozdrawiam Jabba |
jeszcze jeden wykresik, tylko już z mojego palnika ( wysłużona 401@411 poszła do żyda ), tak więc płytki są niczego sobie:
http://jaras.nd.e-wro.pl/burn/BENQ1.png w związku z powyższym wykresem mam jednak pytanie - czy to na pewno dobrze spalona płytka ( chodzi mi głównie o PIF ), bo już mi się kompletnie popierniczyły PI, PIF i PO i sam nie wiem co jest co i czego ile może być? edit: doczytałem, PIF nie ma być więcej niż 4, więc teoretycznie jest lipa - w praktyce filmik przelatuje w konsoli bez najmniejszego zacięcia... a żeby nie tworzyć osobnego tematu mam też takie pytanko - czy ktoś się może spotkał i wie co to za błąd w NERO CD/DVD Speed -> "NO ADDITIONAL SENSE INFORMATION (000000)" <- występujący podczas ( najczęściej pod koniec ) sprawdzania płytki. edit: pomyślałem, po aktualizacji firmware'u problem zniknął :cool: edit: srebrnych verbów 8x jest podobno jeszcze sporo na skrzyżowaniu GUBIŃSKIEJ ze STRZEGOMSKĄ w kiosku koło budy z knyszami 8 )( 1,80PLN ) i na Hali Strzegomskiej ( czyli naprzeciwko tego kiosku po 2,40PLN ). edit2: a jednak problem z powyższym błędem nie zniknął i jeśli ktoś wie o co chodzi byłbym wdzięczny za info. za to wykresy się poprawiły :piwo:: http://jaras.nd.e-wro.pl/burn/BENQ2.png |
napewno inna partia, ja kupowałem w małym sklepiku i jak już kiedyś pisałem z całeko cake-a 25 w szystkie płytki miały spore PIF-y w tych samych miejscach na dodatek strawdziłem i nagrałem płytkę w innym palniku i to samo coś verbatim sie ostatnio pogarsza chociaż bywa o tak: Verb +R x8 BOX ale made in Taiwan za 2,59zł |
czyli jednak wina nagrywarki i starego firmware:
http://jaras.nd.e-wro.pl/burn/BENQ.png dziwi tylko fakt, iż to ten sam palnik co kolegi MZiol, który to twierdzi, iż płytki są nienajlepsze. może trafiłem inną partię... edit: oczywiście mowa o tych verbach z makro. edit2: płyta palona 8x. |
MCC-004-00 - niedługo wrzucę wykresik...
edit: ktoś chce odkupić te płytki może? u mnie te 16-stki DVDDecrypter rozpoznaje jako max 2,4 a KProbe daje średnią ilość PI ok. 1300 (( |
w Makro na 99% będą od MCC, ale pudełkowe, bo cena zabija ( ponad 3PLN ) i wolno schodzą. mają też TDK ( 1,80PLN ) i VERBY ( 1,89PLN ) na szpulach po 10 pakowane - po południu, jeśli odnajdę zaginione, kupione wczoraj w makro, 2 szpulki verbów x16, na których "POCHODZENIE" oznaczone jest jako "INDIE", dam znać co to takiego.
To będę się musiał udac do Proline. Na razie kupiłem 10 TDK DVD-R. A CDRy chyba faktycznie trzeba będzie kupić na Allegro.
TDK DVD-R 1x-8x ---------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:TTG02] ---------------------------------------------------------------------------- Disc & Book Type : [DVD-R] - [DVD-R] Manufacturer Name : [TDK Corp.] Manufacturer ID : [TTG02] Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)] DVD-R Verbatim Pastel 8x Certified (15 zł x5 szt - Media Markt) ---------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:TYG02] ---------------------------------------------------------------------------- Disc & Book Type : [DVD-R] - [DVD-R] Manufacturer Name : [Taiyo Yuden Co. Ltd.] Manufacturer ID : [TYG02] Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)] Verbatim Digital Movie ---------------------------------------------------------------------------- Unique Disc Identifier : [DVD+R:MCC-002-000] ---------------------------------------------------------------------------- Disc & Book Type : [DVD+R] - [DVD+R] Manufacturer Name : [Mitsubishi Chemical Corp.] Manufacturer ID : [MCC] Media Type ID : [002] Product Revision : [Not Specified] Blank Disc Capacity : [Not Supported By Method 2] Recording Speeds : [1x-2.4x , 4x] [Method 2 Might Not Always Detect All Speeds] Jabba |
| Wszystkie czasy w strefie CET. Aktualna godzina: 21:27. |
