How can it be recognised? i do have old (pre 2024) and new ones of these. I will open up a new 10pcs pack and provide a scan in a day (and save the old ones)
If indeed non-Sony disks have already gone, I assume that the code will apparently be either a different format or with noticeable differences. for example here are my retail disks SONY 128GB, bought from Amazon Japan had such codes: in February 2024 slim 5 pcs- 16DJ132SA in November 2024 cake 25 pcs -16DJ1608B in January 2025 cake 25 pcs- 16DJ1608B Similar codes are on many disks for example BDR-DL Verbat-Imf-000 Mitsubishi Verbatim -> CMC Verbatim: Mitsubishi Kagaku Media: DBRF 606V... Mitsubishi Chemical Media: DBRF 606W... fresh CMC Verbatim: DBRF 0618..., DBRF 0619... |
I have looked many scans of SONY NQ1-001 on this forum and on the internet in general.
the best scans were at 2x write speed, 4x worse, 6x usually even worse. The scans at 2x are so good, I haven't seen 3 layer 100 gb disks with better results than these 4 layer Sony disks Pioneer BDR-S12J-X FW 1.01 Imgburn 2x OPC on retail Sony 128Gb 5 in slim box code -16DJ132SA Optidrive does not show all picture unfortunately: https://i.ibb.co/5gB8f7PM/rec.png https://i.ibb.co/Cs2ssv5N/sony-R128-...e2009pio2x.jpg Pioneer BDR-S12J-X FW 1.01 Imgburn 2x OPC off retail Sony 128Gb 5 in clim box code -16DJ132SA https://i.ibb.co/kVwJCqjr/sony-R128-...o-S12jx-2x.jpg Pioneer BDR-S12J-X FW 1.03 Imgburn 2x OPC off cake 25pcs Sony 128Gb code -16DJ1608B https://i.ibb.co/GfKc2nt8/sony-R128-...jx-2xscan4.jpg |
Ritek discs no longer have the Sony information printed on them. Ritek/RiData discs have the same information.
I don't know if the packaging differs between these releases. |
Ilość załączników: 2
SONY-NQ1 slimline case 5-Pack BNR4VAPS4 from end of 2018 (the case is from Panasonic).
burned @ 2x (with DM) WH16NS48, scan @4x "ring" code:16DD191MV |
Ilość załączników: 4
SONY-NQ1, 25 pieces spindle (S4PPGD4RB25) from April 2020 (the case is from Panasonic). Without Sony Corporation Logo
burned @ 2x (with DM) WH16NS48, scan @ 4x "ring" code:16DD191MV -> same disk as BNR4VAPS4 from 2018 |
Ilość załączników: 3
SONY-NQ1 10 pieces spindle (S4PPBD4RB10), from May 2025
burned @ 2x (with DM) WH16NS48, scan @4x "ring" code: 16DJ1702B |
SONY-NQ1 from ODC1500R cartridge from July 2017 (retail version of Sony 128GB discs weren't available at that time!)
burned @4x (no DM) WH16NS48, scan @6x no "ring" code, but some kind of stamper code for each layer in the BCA (very, very hard to see....!) PDQ-0005-L0-1 PDQ-1015-L1-1 (no typo, really 1015) PDQ-2005-L2-1 PDQ-3005-L3-1 |
Very stable quality. Have you checked the degradation of 2017, 2018->2025? Is there a noticeable difference by scans? My first SONY 128 Gb is only 1.5 years old |
Wszystkie czasy w strefie CET. Aktualna godzina: 15:49. |
