Stary 07.01.2016, 18:10   #31
Pioneer DVR-116 DBK - full service ...
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_17-46-55.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_17-48-36.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_17-48-53.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_17-50-57.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_17-59-50.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-07_18-00-23.png
czary2mary jest offline
Stary 07.01.2016, 21:04   #32
seku
Avatar użytkownika seku
full znaczy ? flash corssflash dump i ?
seku jest offline
Stary 08.01.2016, 18:07   #33
Pioneer DVR-115 DBK
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-08_11-18-18.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-08_11-20-30.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-08_11-22-19.png
Stary 12.01.2016, 19:08   #34
@Blackened2687
Mój LiteOn iHAS124 F ma LightScribe....
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-12_18-22-48.png
Stary 14.01.2016, 12:33   #35
Pioneer DVR-112D na przeglądzie
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-22-40.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-23-57.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-24-30.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-25-43.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-29-38.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-14_10-30-14.png
Stary 19.01.2016, 13:03   #36
@Blackened2687
Jakiś problem jest z Pioneer DVR-215DBK firmware 1.13.. nie chce po aktualizacji wyjść z kernelmode ....wgrana aktualizacja do 1.22 fabrycznym instalatorem .
W przypadku aktualizacji gdy w napędzie jest firmware 1.22 wszystko jest już OK.....System W8.1 64bit .
Zgrałem firmware 1.13 bo chyba takiego jeszcze nie mamy ale nie pamiętam czy masz DVR-215 żeby przetestował u siebie jak to wygląda ?
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-23-40.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-24-49.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-27-17.png
Tak wygladają zrzuty z własnościami i zgranie softu..
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-17-04.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-18-36.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-19-19.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-19-58.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-18_17-20-24.png
Stary 19.01.2016, 18:21   #37
blackened2687
CDRinfoTeam
Data rejestracji: 19.04.2014
Dzi***281;kuj***281; za testy! Jestem bardzo zdziwionym takim skr***281;tem wydarze***324; - napisa***322;em Ci w PW...
blackened2687 jest offline
Stary 19.01.2016, 18:29   #38
Napisany przez blackened2687 Podgląd Wiadomości
Dziękuję za testy! Jestem bardzo zdziwionym takim skrętem wydarzeń - napisałem Ci w PW...
OK -jutro postaram się wykonać pracę domową zmykam do pracy
Stary 20.01.2016, 08:26   #39
@Blackened2687 złe wieści
Przy wgrywaniu do DVR-215D kernel i firmware 1.13 zawiecha programu i komputera , -wywaliło się na wgrywaniu firmware przy ~~50% tym razem XP ....
Walczę dalej
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-20_08-16-14.png
Stary 20.01.2016, 10:26   #40
blackened2687
CDRinfoTeam
Prosz***281;, zrób SPTI trace log z oficjalnego flasheru, a nie z DVRTool. Co***347; tu nie tak. Spróbuj z DVRFlash przeprowadzi***263; ten***380;e sam eksperyment (nie obowi***261;zkowo wgrywac kernel, nie ryzykuj!!!) i zawiadom mnie o wynikach.
Stary 20.01.2016, 10:53   #41
Proszę, zrób SPTI trace log z oficjalnego flasheru, a nie z DVRTool. Coś tu nie tak. Spróbuj z DVRFlash przeprowadzić tenże sam eksperyment (nie obowiązkowo wgrywac kernel, nie ryzykuj!!!) i zawiadom mnie o wynikach.
To to ja wiem ale nie jestem w stanie przywrócić go do firmware 1.13....
Po restarcie napęd był w jakimś dziwnym stanie kernelmode .....
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2151.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2152.png
Po wgraniu oficjalnym flasher 1.22 zawiecha instalatora i komputera na ~~20% Log SPTI również urwany\przerwany w tym momencie ...
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-20_09-00-54.jpg
Po restarcie napęd wrócił do życia do firmware 1.22 .....
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-20_08-39-42.png
Mam robić log z oficjalnego flash 1.22 do 1.22 ?
Przy firmware 1.22 wgrywa się bezproblemowo DVRTool więc chyba nie ma sensu testować tego samego na DVRFlash ?
Wysyłam zaraz Tobie soft DVR-215D 1.13 + log SPTI ile zdążyło się zapisać ...
Wydaje mi się że wgranie kernel i firmware przez DVRFlash też będzie z problemami ?
Stary 20.01.2016, 11:00   #42
blackened2687
CDRinfoTeam
Jednak sprawd***378; z DVRFlash - mo***380;na bez Trace SPTI, dostateczne b***281;dzie foto wyniku...
Stary 20.01.2016, 11:05   #43
OK - wgrywam sam firmware 1.13...
Stary 20.01.2016, 11:17   #44
Też fake
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-20_11-15-05.png
Na W8.1 fabrycznym flasher powrót do 1.22 bez problemu .... Nigdzie nie widzę fabrycznego 1.13 ? Może @cvs ma ?
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2016-01-20_11-19-30.png
Ostatnio zmieniany przez czary2mary : 20.01.2016 o godz. 11:22
Stary 23.01.2016, 20:55   #45
seku
PIONEER DVDRW DR-TD08HB 1T10-HP
@blackened2687 chcesz dumpy ? czy masz już ten model ?
-i
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-przechwytywanie-02.png
seku jest offline
dvrtool, pioneer
Opcje związane z dyskusją
Tryby wyświetlania
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 09:58.
