Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
20.07.2017, 10:33 | #631 |
Efficient? Where do you have such OEM Compaq?
http://www.cdrinfo.pl/hardware/20801...ioneer-DVR-A04 Can you ask for pictures like looks and factory labels? Is it possible to factory update to newer firmware? I have DVR-A04 and DVR-104 \ 2 Pioneer DVR-A04 Pioneer DVR-104\2 |
21.07.2017, 03:36 | #632 |
Data rejestracji: 07.03.2017
I got the drive off of eBay a few years ago. Apparently it came from a Compaq desktop. I have not tried any burns yet, since I was hoping to upgrade the firmware first. I tried flashing with Pioneer firmware, bit it would not work.
Here's some photos of the drive: |
21.07.2017, 07:25 | #633 |
CDRinfoTeam
Data rejestracji: 19.04.2014
jadburner, thank you very much for the screenshots and drive photos!
If you will decide to crossflash the drive, I will advice not to do it with DVRTool, until I'll test it personally on this drive. We had troubles with DVR-105 crossflashing twice - both times something went wrong and DVRTool hung after sendng the first part of kernel file (apparently waiting the response from the device) - as a result, two drives now require to flash the system controller using an external hardware (which I don't have). Since DVR-104 drives are rare, i will advice not to use DVRTool for their crossflashing, until everything will be tested. |
21.07.2017, 08:09 | #634 |
@jadburner
Thank you very much for the photos. I have never met a version with a black front panel. @blackened2687 Do you have any kernel for DVR-A04 \ 104 ? I have never met nor seen anywhere? |
21.07.2017, 19:28 | #635 | |
21.07.2017, 19:42 | #636 |
22.07.2017, 09:53 | #637 | |
I recently watched Pioneer DVR-S201 but it was so damaged and damaged that I could not fix it. |
22.07.2017, 20:26 | #638 | |
22.07.2017, 22:38 | #639 |
Pioneer DVR-X152 external drive:
22.07.2017, 23:39 | #640 | |
We have practically no Pioneer DVR-S101 \ S201. I know only one place in Poland that used to have and used DVR-S201 .... Too bad you no longer have a SCSI or SCSI adapter working .... Please put this unique model with a picture in our museum. Muzeum\Mauzoleum DVD |
23.07.2017, 06:56 | #641 |
DVRTool 1.0298j Beta
24.07.2017, 01:23 | #642 | |
I'll see if I can do about getting it hooked up... |
24.07.2017, 07:05 | #643 | |
I only have the oldest DVR-103 \ A03. Here is a sample test @ Blackened2687 [Muzeum] Pioneer DVR-A03 - 2001r |
27.07.2017, 07:43 | #644 |
Pioneer DVD-116LJ:
28.07.2017, 07:05 | #645 |
Pioneer A09XLB1:
Tagi |
dvrtool, pioneer |
Opcje związane z dyskusją | |
Tryby wyświetlania | |
Podobne dyskusje | ||||
Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 08:55 |
Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 18:09 |
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 15:01 |
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 22:37 |
