Stary 20.06.2022, 16:22   #781
seku
Avatar użytkownika seku
if there is a chance i can try it :-) i have 209D :-)
seku jest offline
Stary 21.06.2022, 19:56   #782
blackened2687
CDRinfoTeam
Data rejestracji: 19.04.2014
Yes, of course. Sprawdź PW
blackened2687 jest offline
Stary 08.11.2022, 11:30   #783
Oinker
Data rejestracji: 08.11.2022
Oinker w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Red face
Napisany przez blackened2687 Podgląd Wiadomości
Hope you allow me to try it, too. :o
Btw, if there's a kernel required, is it enough to unpack the updater exe and use the two files that get extracted in the BINARY folder then? They are about the same size, just have different filenames, e.g. the 208M firmware 1.40 had files S8301000.140 (69 kb) and S8301001.140 (1833 kb), the 1.50 firmware has 131 (69 kb) and 132 (1836 kb), i.e. there is no additional encryption of any kind on the newer files?
And is it correct that there is no 1.53 available for the S11 like there is for the 211M model (i.e. the EBK/UBK drives)?
Oinker jest offline
Stary 09.11.2022, 18:45   #784
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez Oinker Podgląd Wiadomości
Welcome to the forums, Oinker! I'm glad you were finally able to get registered.
With respect to the S11, you can find 1.53 firmware for the BDR-S11J-BK and BDR-S11J-X here.
Some, but not all, official flashers from Pioneer include both a kernel and firmware, which you can extract from the unpacked EXE. However, some flashers include only the firmware. In that case you need to either extract the kernel from a drive you have, or use one from the extensive archive that blackened2687 is assembling.
A really neat feature of the latest version of BDRFlash is that you can drag and drop an official flasher on top of the program and it will automatically extract the firmware and (if it exists) the kernel in the same directory as the flasher. Many thanks to blackened2687 for adding that feature.
Hopefully you'll hear from blackened2687 soon, but he is very busy lately.
jadburner jest offline
Stary 10.11.2022, 09:30   #785
Oinker
Oh, thanks jadburner! I usually checked this page for firmware updates:
https://pioneer.jp/device_e/product-...v00001r_e.html
And there is only one for the 211EBK/UBK drives.
I don't mind waiting, blackened2687 being busy is a positive thing here.
Looking forward to the firmware archive.
Oinker jest offline
Stary 11.11.2022, 04:40   #786
jadburner
It's unfortunate that Pioneer has more than one web site with firmware updates. It would be much simpler if they had just one site with all of them. Probably there are so many variations of their drives that they can't keep track of them either.
Stary 01.12.2022, 14:10   #787
Oinker
Red face
Thanks to blackened2687 and jadburner my 208Ds are 208Ms now.
File Type: png 208Dto208M.png (50.4 KB, 1071 oglądane)
Oinker jest offline
Stary 22.12.2022, 20:37   #788
carbonat82
Data rejestracji: 22.12.2022
carbonat82 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello i have a BDR-212DBK drive and i would like to flash it to an 212UBK. Is it only possible with the BDRTool or is there a nother method?
carbonat82 jest offline
Stary 29.12.2022, 05:16   #789
jadburner
Napisany przez carbonat82 Podgląd Wiadomości
BDRFlash is the tool you need. I'm not aware of another method.
Stary 25.01.2023, 19:44   #790
tsi12
Data rejestracji: 25.01.2023
tsi12 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello. Is there possibility to limit cd reading speed with DVRTool on DVR-XD10T?
tsi12 jest offline
Stary 27.01.2023, 19:46   #791
SEBAW
Stary użytkownik
Avatar użytkownika SEBAW
Data rejestracji: 09.06.2002
Use Opti Drive Speed. The program is free. Opti Drive Speed.
SEBAW jest offline
Stary 29.01.2023, 17:45   #792
tsi12
Napisany przez SEBAW Podgląd Wiadomości
It seems not compatible with specified model.
tsi12 jest offline
Stary 07.02.2023, 20:44   #793
BigJoe
Data rejestracji: 07.02.2023
BigJoe w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello,
i´m trying to crossflash my Pioneer Drive. All tries with DVRTool from Post 1 haven´t worked. I have extracted the Firmware Binarys (131 and 132) from the official Updater but no success to Flash them to the Drive.
I´m looking for the introduced BDRFlash Tool, but couldn´t find it. Can someone help out?
Awesome what you guys are doing here.
Thanks in advance.
BigJoe jest offline
Stary 08.02.2023, 04:57   #794
jadburner
Napisany przez BigJoe Podgląd Wiadomości
Hello,
Welcome to the forums, BigJoe!
What drives are you trying to crossflash to/from?
Stary 08.02.2023, 10:01   #795
BigJoe
Hello jadburner,
Thank you.
A BDR-XD07T i want to crossflash to BDR-XD07TUHD.
BigJoe jest offline
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 07:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 17:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 14:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 21:37
Wszystkie czasy w strefie CET. Aktualna godzina: 17:40.
