Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
03.02.2024, 22:15 | #991 |
Data rejestracji: 09.01.2024
for file BDR-S11JX_FW153EU.exe
there is 2 folders extracted from it 11TM_BDR-S11JX_FW153EU 11T_BDR-S11JX_FW153EU if im flashing a 209D any idea which one I should use the TM one contains a kernal file the T one doesn't |
04.02.2024, 05:33 | #992 | |
Data rejestracji: 07.03.2017
11TM_BDR-S11JX_FW153EU.exe is for SAT 8801. If your 209D has hardware SAT 8600, use the SAT 8800 firmware. If your 209D is SAT 8601, use the SAT 8801 firmware. |
05.02.2024, 05:59 | #993 |
@jadburner
just so you know the 209d/m doesn't seem to wanna take the BDR-S11J-X firmware |
05.02.2024, 16:28 | #994 |
05.02.2024, 17:38 | #995 |
flash
05.02.2024, 18:21 | #996 |
05.02.2024, 18:26 | #997 |
type
05.02.2024, 18:32 | #998 |
05.02.2024, 18:43 | #999 |
flash
06.02.2024, 16:48 | #1000 | |
Data rejestracji: 08.11.2022
07.02.2024, 06:11 | #1001 |
flash
07.02.2024, 11:44 | #1002 |
Which firmware is your 209M currently on? Must be 1.54 or below. 1.55 contains the downgrade/crossflash protections already. Did you try the firmware and kernel files that jadburner gave you?
07.02.2024, 20:07 | #1003 |
07.02.2024, 21:45 | #1004 |
12.02.2024, 02:44 | #1005 |
Gość
Posty: n/a
I have the following 3 pioneer models (as listed on serial label) with the indicated stock pioneer firmware:
1) BDR-212V, Rev 1.01, Firmware date 2021-07-20 2) BDR-212DBK, Rev 1.02, Firmware date 2022-03-16 3) BDR-213ULBK, Rev 1.02, Firmware date 2022-04-06 Is it possible to receive a copy of BDRFlash to do the following crossflashes: BDR-212V and BDR-212DBK --> BDR-S12UHT v1.02 (firmware BDR-S12JBK_UHT_FW102EU.exe) BDR-213ULBK --> BDR-S13U-X v1.03 (firmware BDR-S13JX_UX_EX_CX_FW103EU.exe) From what I understand: 1) In all cases, the new model/firmware being crossflashed to: a) is compatible with the original old model/firmware. b) will enable BDXL writing and UHD ripping on the drive (using the appropriate software). c) is dated <= Nov 30, 2022 and thus not among the Pioneer firmwares that prevent crossflashing/downgrading and disable libredrive. 2) I won't be stuck with my choice of crossflashed firmware: if, for some reason I'm unhappy with the results, I can use BDRFlash again to crossflash to a different (compatible) firmware, provided I have the firmware (and kernel) files. Is this all correct? By all means, please advise if a different model/firmware version would be a better choice for any of the models, especially if I am choosing too high of firmware versions. Also, I would be doing the crossflashing over a sata to usb y-connector (Vantec CB-ST00U3). Please let me know if this could be problematic and if another connector (or direct sata to pc motherboard) is advisable. Thanks so much in advance to all the contributors to this excellent forum/topic, especially @blackened2687, who I understand is the OP and creator of the fantastic softwares DVRTool and BDRFlash, and @jadburner for his great and informative posts and helpful guidance! |
Tagi |
dvrtool, pioneer |
Podobne dyskusje | ||||
Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 07:55 |
Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 17:09 |
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 14:01 |
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 21:37 |
