Stary 03.01.2007, 20:13   #1
dread_darecki
Avatar użytkownika dread_darecki
Data rejestracji: 04.05.2006
dread_darecki w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Angry Laptop Toshiba i naped DVD Toshiba - padł po flashu biosu?
HELP
Laptop Toshiba Satellite Pro 4300 model 4320 - naped Toshiba SD-C2402 - /sprawny czasem przycina***322; sie na s***322;abszych DVD-r/ wersja firmware: 1317
- sprawdzam dostepnosc nowego na http://www.firmware.fr.st/
OK jest o wiele wyzszy: 1Y17
Sciagam, i ciesze sie ze moze poprawi mu sie odtwarzanie - czytam instrukcje:
** How to use VUP.EXE **
"VUP.EXE" is a flasher utility software for TOSHIBA CD/DVD-ROM ATAPI drives.
[Supported Drives (almost all TOSHIBA ATAPI drives)]
[Necessities]
PC, TOSHIBA CD/DVD-ROM drive, ******.hex (appropriate F/W file)
[Procedure]
1- Make sure that TOSHIBA CD/DVD-ROM drive is connected.
2- Run PC by MS-DOS mode.
3- Copy "VUPXX.EXE" & "******.HEX" to some directory in HDD.
4- Type "VUPXX ******.HEX" then hit RETURN-KEY.
5- Program finishes with the message of "Comparison : GOOD"
[Command line options]
-h[elp] : Display HELP Message
-v[ersion] : Display VUP Version
-irq (0 to F) : Set IRQ level by hexadecimal number.
-prt (Port No.) : Set I/O port address by hexadecimal number.
***** Specify both options (-irq and -prt) if use *****
-a[uto] : Auto mode. (Non-interactive)
*The utility does not prompt to input "Y/N".
-c[ontinue] : Flash continuously. (if many drives are connected)
*Finishing flash procedure, it returns to the initial
stage automatically.
(0 to 7) : Designate ID. (0rimary/Master -- 7:Quatenary/Slave)
(HEX file name) : Omitting the file name, the default name of "ROM.Hex"
is used.
Okej wszystko jasne - flashujemy - procedura posz***322;a prawid***322;owo, pojawi***322; sie napis "GOOD" wiec restart i... dupa
Przy botowaniu Bios sie drze:
"IDE #1 error"
i oczywiscie windows nie wykrywa napedu, BIOS tez - flasher tez go nie widzi - POMOOCY jak ta cholere ugryzc i zmusic do pracy z tym sprzetem co zrobi***322;em nie tak
UPDATE:
Uda***322;o sie ustalic ze naped podczas flashu przestawi***322; sie na SLAVE - po odinstalowaniu kontrolera IDE i "odswiezeniu" w winxp system wykrywa go jako secondary slave nawet dzia***322;a ale WOLNO tylko PIO - nero info tool go widzi ale nie moze sie na niego "wbic".
Po restarcie kompa windows ZN***211;W przestaje go widziec, jak tego z***322;oma przestawic na MASTER ?
Z poziomu DOS go nie widzi :[ - tylko windows i to po "kompinowaniu"
Szukam drugiej połówki... ale 0,7 tez może być ...
Ostatnio zmieniany przez dread_darecki : 03.01.2007 o godz. 21:59
dread_darecki jest offline
Stary 04.01.2007, 08:13   #2
dread_darecki
Thumbs up Znalazłem rozwiazanie
No i sprawa rozwiazana - wprawdzie po "hitlerowsku" ale foty mówia wszystko:
http://www.dschen.de/laptop_brenner/
Wszystkie czasy w strefie CET. Aktualna godzina: 12:08.
